Nero-Burning Rom in Win2000?
kuntek ::
Kaj naj nastavim, da bodo lahko vsi userji v Win2000 lahko pekli CDje z Nerotom? Zdaj lahko peče samo Admin, ker Nero drugim userjem teži, da ne morejo uporabljat CD-RWja.
Nisi edini , ki imaš s tem težave.
sem iskal po forumu , pa so neke imaginarne local policy razlagali ..... itd , če kdo ve se tudi jaz priporočam.
Lime ::
Jaz se tudi priporočam za rešitev. Sicer po Win XP, ampak mislim da je isti šmorn.
V Nerotu pod help je razlaga:
The way Nero solves this problem is to allow system administrators to assign during installation a group of users the rights to record CDs on the system. If an administrator wants to allow or disallow CD recording for certain users, it is enough to make the user member of this group or to remove the group membership of that user. If everybody should get the right to record CDs, the recording rights should be assigned to the group "Users".
In some situations, it might be convenient for the administrator to change the group assigned CD recording permissions. Nero has a new property page with title "Security". This page can be opened by using the menu command "File"->"Preferences". Administrators may edit and normal users may only view the group name of the users, that have the permission to burn CDs. Any changes of these settings become effictive after the next system restart. Uninstalling Nero will cause the recording CD rights to be removed again.
Imel sem verzijo 5.5.6.x ,sedaj imam verzijo 5.5.7.4 , pa žal vem za ta help , ampa tega tam ni ?
sasox ::
So racunalniki v domeni ali brez?
kuntek ::
Jaz nočem pečt v mreži ampak na enem računalniku (sasox - saj veš). Verjetno imamo vsi isti problem. Če user nima Administratorskih pravic potem ne more pečt CDjev. Malo nerodno se je odjavit in prijavit kot Admin, če hočeš pečt. In ostalim, ki uporabljajo moj računalnik ne bom dal Admin pravic.
McHregec ::
Jst sm mel iste probleme v WinXp potem sem pa namestil Nero 5.5.8.0 in dela brez problemov.
Destroyer Of The Worlds.
Lime ::
Meni tudi ta nova verzija ne dela. Dela samo pod administratorjem.
kuntek ::
Tudi meni niti z novo verzijo ne dela. Nikjer pa ne najdem kje bi lahko to kot Admin nastavil. ANDREJ, NA POMOČ!!!
Tiger ::
Jaz sicer nisem andrej ampak...
Poskusi tole:
Control Panel -> Administrative Tools -> Local Security Policy -> Local Policies -> Security Options -> Restrict CD-ROM access to locally logged-on users only --> ENABLED
To naj bi menda delovalo, so pa potem drugi problemi, recimo s to opcijo potem ne moreš inštalirati nič od MS Office produktov.
McHusch ::
kaj pa Run As Different User možnost, pa pol naštimaš da Nero laufa pod administratorjevem accountu.
MadMax ::
TUKAJ najbrz ni se nihce firbcal?
Nero 5.5 released!
Check out the new features introduced here!
Known issues:
Under Windows 2000, Administrator privileges are required to burn CD's
Release date: April 30th, 2001
Saj vse pise.... Pa brez Googla.
Lime ::
Ja, samo to je za stare verzije. Nova naj bi to že vsebovala.
Lime ::
BINGO!!!
TIGER hvala. DELUJE!!!
win srv 2003 - file sharing
Oddelek: Operacijski sistemi
192569 (1734) Eureka
Zaščita DVD diska
Oddelek: Programska oprema
312791 (2201) bosmla
Kako varen je Microsoftov požarni zid? (strani: 1 2 )
Oddelek: Novice / Varnost
537243 (7243) gumby
Nero + teacW516EB
91278 (1191) PupaSuchen
WIN 2000 BOOT ?
131844 (1709) rookie
