Šifriranje folderja/container na PC brez pravic
Bellzmet ::
Rad bi imel šifriran folder ali file container na računalniku Win 7 na katerem nimam administratorskih pravic. Se pravi ne morem namestiti npr. Truecrypta na PC (če prav razumem sedaj VEraCrypt?).
Kako bi se to dalo?
GupeM ::
Najdi portable verzijo, katere ni potrebno nameščati. Lahko jo imaš recimo na USB ključku in jo poganjaš kar z njega. Seveda pa jo lahko skopiraš tudi v folder na disku in poganjaš od tam.
---> You need administrator privileges in order to be able to run VeraCrypt in portable mode <---- (vir)
Bellzmet je izjavil:
AC_DC ::
Lahko kriptiraš folder:
S tem, da:
- imena fajlov ostanejo kot so (vidna, nekriptirana)
- možno samo na Pro, Enterprise in Ultimate različici Windows 7
AC_DC je izjavil:
https://www.grc.com/misc/truecrypt/true...
https://securityinabox.org/en/guide/tru...
poglavje 6
Using TrueCrypt Without Administrator Privileges
In Windows, a user who does not have administrator privileges can use TrueCrypt, but only after a system administrator installs TrueCrypt on the system. The reason for that is that TrueCrypt needs a device driver to provide transparent on-the-fly encryption/decryption, and users without administrator privileges cannot install/start device drivers in Windows.
After a system administrator installs TrueCrypt on the system, users without administrator privileges will be able to run TrueCrypt, mount/dismount any type of TrueCrypt volume, load/save data from/to it, and create file-hosted TrueCrypt volumes on the system. However, users without administrator privileges cannot encrypt/format partitions, cannot create NTFS volumes, cannot install/uninstall TrueCrypt, cannot change passwords/keyfiles for TrueCrypt partitions/devices, cannot backup/restore headers of TrueCrypt partitions/devices, and they cannot run TrueCrypt in ‘portable’ mode.
Warning: No matter what kind of software you use, as regards personal privacy in most cases, it is not safe to work with sensitive data under systems where you do not have administrator privileges, as the administrator can easily capture and copy your sensitive data, including passwords and keys.
Vir: http://andryou.com/truecrypt/docs/non-a...
Zadnji odstavek je v rdečem okvirju...
  • spremenil: MrStein ()
Bellzmet ::
@mrstein: kriptiranje folderja žal ne dela, zopet zgleda težava z pravicami. "Napaka pri uveljavljanju atributov" "...trenutni uporabniški račun..."
A sploh imaš ponujeno opcijo? Kateri Windows imaš? Pro? Home? Na Pro bi naj delovalo. Samo vklopiš in fertik. Če ne, napiši bolj točno, kaj narediš in kaj se zgodi.
Tule je sicer opis, kako EFS lahko vklopiš in uporabiš na Windows 7 Home: http://klonkers.blogspot.si/2013/09/enc...
Ter za bonus: kako 3rd party encypted container mountaš na Windows brez admin pravic: http://www.heise.de/ct/artikel/SecurSti...
(žal bolj proof-of-concept kot pa končni izdelek)
Bellzmet ::
Imam Enterprise. Opcija je ponujena, ko jo zaštartam napiše "Napaka pri uveljavljanju atributov datoteke. ... Zahtevane operacije ni mogoče dokončati. Računalnik mora biti zaupano posredovanje, trenutni uporabniški račun pa mora biti konfiguriran za dovoljenje posredovanja."
Google it
(bi bilo dobro angleško verzijo dobiti, mogoče lahko jezik začasno spremeniš).
Možno, da je administrator kake omejitve naredil. Končno besedo bo imel vedno admin. Če je zloben, ti z lahkoto lahko prebere vse (šifrirane) podatke.
sodnicaN ::
kupi si en 64 ali 128 gb usb kljucek daj gor en linux in bootaj z njega
boš imel lahko vse pravice in vse kriptirano
al si pa najdi nek exploit za dobit administratorske pravice
Zaščita datotek
172700 (2109) fosil
Uporaba TrueCrypt
Oddelek: Programska oprema
124151 (3134) Jupito
TrueCrypt 5.0 (strani: 1 2 )
Oddelek: Novice / Zasebnost
7012851 (10263) poweroff
Varovanje podatkov na prenosnem disku
192609 (2322) SasoS
Ultimate USB Key - skrita particija (in nekaj dodatkov..)
52431 (2318) OmaDesala
