Win 7 licenciranje - prehod na virtualne delovne postaje
harmony ::
Zanima me ali je potrebno kupiti nove licence v kolikor bi v podjetju izvedli prehod na virtualne delovne postaje.
Ali so obstojece licence vredu?
kloko ::
Odvisno, kakšne licence imate sedaj, nič ne poveš? OEM licenc npr. ki so vezane na točno določen računalnik, se že ne sme prenašati.
L.p., Kloko
harmony ::
kloko je izjavil:
L.p., Kloko
Res je, premalo sem napisal. OEM licence so. Okej odgovor sem sicer v vmesnem casu ze pridobil.
jukoz ::
http://www.microsoft.com/oem/en/Pages/s...
Q. Can I install OEM on a virtual machine (VMware)?
A. You may install OEM in a virtual environment as long as you have a separate license for each instance of the software. It is fine to use the OEM version as long as it is properly licensed. To be clear, a separate version of software must be installed for both the "standard" and "virtual" installations.
Po mojem razumevanju se torej da, dokler je na isti mašini.
Windows licenca (strani: 1 2 )
5021627 (14862) Dman
Windows 7 problem pri prenosu licence
Oddelek: Operacijski sistemi
163969 (3599) opeter
Poceni Win8
4410860 (9669) Mare2
OEM Software ni vezan na hardware?
82407 (2156) jan01
Kje kupit Windows XP Pro in koliko stane?
385336 (4286) bond007
