Forum » Problemi človeštva » Novopečeni diktator Venezuele Maduro
Karaya 52 ::
NavadniNimda je izjavil:
Seveda so bili tudi moji sorodniki nalagani, sistematično, načrtno in dosledno, da bi bili bolj vdani služabniki Partije.
Jp. Toliko so pretrpeli za partijske laži, da danes iz principa težko stopijo korak nazaj. Tragično pravzaprav.
Karaya 52> Jp. Toliko so pretrpeli za partijske laži, da danes iz principa težko stopijo korak nazaj. Tragično pravzaprav.
Še bolj tragično je, da njihovi kolegi z zahoda niso na boljšem.
klanjsekII ::
Propad ja. Slovenija je bila ob koncu 2SV približno na isti ravni kot Avstrija.
Kako približno? Za tole bi rad dobil link. Ker pred drugo SV je bilo območje Balkana najbolj zaostalo področje širše Evrope. In po 2sv je bila povprečna letna stopnja real. rasti v YU (do leta 87) 4,9% (V Slo še višja). In Avstrija ni rasla hitreje kot 5% na leto. Torej ne bluzi.
Poleg tega zavajaš, ker si za tisto razliko vzel leto, ki označuje ogromen padec BDP v Slo in to ne zaradi marksizma, ampak zaradi izgube skupnega trga/razpada YU.
Beri in se izobražuj:
In addition, the region was considered to be one of the poorest, least developed areas in Europe at that time (1926-1939), burdened with high levels of illiteracy, infant and premature mortality, income inequality and poverty. As indicated by Ananijevic-Pandey (1994), life expectancy at birth in post- Second-World-War Yugoslavia was among the lowest in Europe (men 54.8 and women 56.8 years). By 1985, the situation had improved significantly. Life expectancy at birth increased to 68.3 years for men and to 73.6 years for women (ibid., p. 339), an average increase of 30 percent. Even more impressive were the results regarding premature mortality, measured by the crude rate of years of potential life lost. Data for the 1970 – 1990 period indicate that this number “fell from 12,762.6 to 6,320 per 100.000 population aged 0-64 (ibid.), a 50 percent decrease. Similar improvements can be found when analyzing education statistics. As indicated by Farmerie (1972), in the 1945 – 1970 period, illiteracy has been cut in half, “the quality and number of schools have substantially increased, vocational and technical education has greatly expanded, and pupil enrollment has tripled” (p. 148).
Table 1: Estimates of Relative Economic Development, GDP per capita, current international dollars – Yugoslavia/Post-Yugoslav republics vs. Austria and USA, 1985-2009.
1985 1990 2000 2009
Austria = 100
Yugoslavia/
Post-Yugoslav
republics 56.40 44.10 31.27 31.34
USA = 100
Yugoslavia/
Post-Yugoslav
republics 46.80 38.10 25.76 26.62
Sources: 1985-1990: Vojnić, (1993, p. 75); 2000-2009:World Bank World Development Indicators (http://data.worldbank.org/indicator/NY...., accessed on Feb. 2012, own calculations.
Torej leta 1986 je bila Yu na 56% AUT in BDP per capita v Slo je bila cca. 2x višji od Yu povprečja. Torej računaj in ne nabijaj laži.
Ananijevic-Pandey, J. (1994). Premature Mortality in Former Yugoslavia. European Journal of Epidemiology, 10(3), 339-341.
1985 1990 2000 2009
Austria = 100
Yugoslavia/
Post-Yugoslav
USA = 100
Yugoslavia/
Post-Yugoslav
- spremenila: klanjsekII ()
Oki ::
Jawohl!
klanjsekII> Beri in se izobražuj:
Odsvetujem argumentiranje: Fantje kolaborantje ga preskočijo, ker jim gre v nos.
Se tudi ne morejo sprijazniti, da so "zločinski povojni poboji" evropska norma, ki ni omejena na nobeno posamezno državo, ker so se zgodili praktično povsod - v različnih obsegih. Francozi nič ne objokujejo svojih, Nemci ne svojih, le pri nas smo (pravilno) ugotovili, da je treba povojne poboje obsoditi, iz česar je nekdo potem potegnil (napačen) sklep, da smo poboje skrivali zaradi njihove zločinskosti (in ne zato, ker predstavljajo skrajno nacionalistična romarska središča, ki je razlog, ki so ga navedle druge države, ki so izvensodne poboje pometle pod preprogo in prepovedale pokopavanja in obeležja).
Še večje težave imajo z dejstvom, da je spoštovanje zasebne lastnine del družbene pogodbe, ki lahko pride samo s spoštovanjem celotnega dogovora in da ko enkrat tak dogovor razpade, nihče več ne garantira ničesar. Premladi (s tem mislim preveč naivni) so, da bi razumeli, kaj je v resnici boljševizem in zakaj ga bodo doživeli, če bodo vztrajali na idiotski premisi, da je tržni kapitalizem po meri najbogatejših karkoli drugega kot ena od mnogih oblik fašizma.
NavadniNimda ::
Jawohl!
Ja, ampak so povsod bili tudi procesi pred sodiščem, dokumentirani, z dokazi in pričevanji žrtev. Tudi v Rusiji. In tudi v Jugoslaviji za večino nemških in italijanskih zločincev.
Glede kvizlingov (sodelavcev z okupatorjem) je tako, da so recimo v Franciji, Norveški in povsod drugod izvajali procese pred sodiščem. Edino v socialistićni Jugoslaviji so jih množično poklofali brez sodnih pobojev, potem pa to sramotna dejstva desetletja s terorjem skrivali pred sabo in pred svetom. So že vedeli zakaj, faloti komunistarski.
Hvaležni smo lahko našim prvim zaveznikom Američanom, da so s pomočjo superiorne satelitske tehnologije hitro najdli prekopano zemljo na predelih Srebrenice v letu 1995, kjer so le nekaj dni pred tem oborožene tolpe Jugoslovanske Ljudske Armade izvajale večdnevne "radne zadatke" in klofale na tisoče ujetnikov, žena in otrok, taka je pač vojna "na ovim prostorima". Popolnoma po istem kopitu, kot leta 1945. In so tudi mislili, pepčki naduvani, da jim bo že spet uspelo prešvercati "svojo resnico" v 21. stoletje. Uspešni letalski napadi, ki so kmalu sledili, so popucali z enim najbolj zločinskih režimov Evrope 20. stoletja. And will do so again if called for, make no mistake!
Jugoslavia in/ali socializem NIKOLI VEČ!
- spremenilo: NavadniNimda ()
jebiveter2 ::
Dejmo rajš definirat te zadeve na način.
Nočemo več sranja ki ga socializem prinaša, hočemo pa vse njegove prednosti. Ok ?
Brane22 ::
Ne samo to, ampak tudi ni jasno, za koga naj bi to veljalo.
Praktično vse zahodne države imajo močne socialne elemente.
Tudi če bi ti ratalo po nekem čudežu ukiniti te, bi imel v naslednji minuti revolucijo.
Kdo potem noče nikoli več socializma ?
Saj štekam prvilačnost libertarstva in se v solidni meri strinjam s tem ampak teli predavatelji stalno dajejo vtis kot da je to dnevna praksa. Če je, kje ?
Američani so našli marsikaj s svojo superiorno tehnologijo. Marsikaj se je izkazalo kot wapor.
Tudi Srebrenici kaže tako. Ne traja sojenje Šekiju slučajno 11 let.
In ni slučajno obviselo od vseh začetnih obtožb na "sovražnem govoru".
In BTW, zakaj misliš da je Bosna izgubila svojo tožno proti Srbiji za genocid ?
Saj z bulletproof fotko, ki si jo navedel in satelitskim posnetkom "superiorne tehnologije" bi to moralo biti 5 minut dela, če prav razumem...
- spremenilo: Brane22 ()
jebiveter2 ::
Pja, zakaj bi se sploh brigal kako poimenuješ neko neučinkovito tvrtko ki se imenuje PRC, USA, capitalistic republic of lalala, liberalistic canada etc.
To je tko kot da bi frocu dal ime Žiga namesto Jure in pričakoval 42% boljše ocene v šoli.
Nonsense.
Politični sistem mora biti prvo kot prvo, popolnoma samostojen, drugo, učinkovit, in tretje, prilagojen trenutnemu položaju.
Npr. S kapitalističnim sistemom ni popolnoma nič narobe vse dokler imajo vsi dovolj penezov da poskrbijo zase in za svojo družino. Ko pa tega nimajo so pa preprosto v pizdi.
Socializem je sistem revežev, nič drugega. Bogatim je vseeno za ta jajca, ki jih moramo mi žvečiti da preživimo.
Nonsense.
NavadniNimda ::
Ne vem. Jaz nisem z nikomer skregan in nimam nobenih sovražnih ali hudobnih nagnjenj ali želja do nikogar v Jugoslaviji. Zdele ploskam vsem narodom bivše Juge, ki se pospešeno vklapljajo v sodobnico 21. stoletja.
Rasa, nacionalnost, barva kože, vera, ideologija in podobne reči so osebna reč, zločin je kogarkoli klofati zarat tega. Upam, da se strinjamo.
Hočem eno svobodno, odprto, globalno civilizacijo, kjer bo vsem dovoljeno živeti, trgovati, se izražati in sploh početi kar jim paše, kakopak v okviru pravne države. Hočem minimalistično globalno ustavo, ki bo postavila stvari tako, kot bi morale biti že od vedno. Kolektivnih nacionalnih, verskih, rasnih, ideoloških in kakršnihkoli drugih prisilnih združenj ali državnih tvorb ne priznavam več, ker so povzročile že preveč vojn, gorja in trpljenja. Hočem osebno in gospodarsko svobodo človeka. Time to move on!
jebiveter2 ::
Time to move on!
Kam ?
V sisteme ki nam jih drugi servirajo na pladnju pod pretvezo da je to ja dobro za nas ?
V sisteme ki smo jih ustvarili sami ?
NavadniNimda ::
jebiveter2 je izjavil:
Time to move on!
Kam ?
V osebno svobodo, lastne odločitve veljajo. Punkozarac imam nekih "voditeljev" ki zganjajo kolektivizem (v nacionalnem, ideološkem, verskem, rasnem, itd.) smislu. Osebna svoboda je prva, združevanje na takih in drugačnih osnovah je legitimno - ampak NE, če je prisilno. Upam, da se zdaj štekamo.
NavadniNimda> Hočem osebno in gospodarsko svobodo človeka.
Vidiš, jaz tudi, v tem vrstnem redu. Eni menijo, da so davki previsoki in da to posega v gospodarsko svobodo človeka. Jaz se s tem ne strinjam: Kafkovski ustroj birokratske države posega v osebno svobodo človeka - ekonomske mu pa ne jemlje. V resnici lahko v naši državi obsceno obogatiš, če si dober poslovnež, ne moreš pa zgraditi "sonaravnega hotela" v TNP, če ne poznaš vseh političnih veljakov, ki bi ti bili za zadostno protiuslugo ukriviti zakonodajo tako, da bi zanj lahko dobil dovoljenje (kar je popolnoma nepovezano s strokovnimi razlogi za ali proti takšni gradnji).
NavadniNimda> Osebna svoboda je prva, združevanje na takih in drugačnih osnovah je legitimno - ampak NE, če je prisilno. Upam, da se zdaj štekamo.
Karaya se ne bo strinjal: Pravi, da so sindikati že zdaj preveč močni in preveč povezani s politiko, ne moti pa ga, da enako velja tudi za oligarhijo.
dstr17_ ::
Kolektivnih nacionalnih, verskih, rasnih, ideoloških in kakršnihkoli drugih prisilnih združenj ali državnih tvorb ne priznavam več, ker so povzročile že preveč vojn, gorja in trpljenja.Korporacije in oligarhija so pa seveda čisti kot solza.
Obstaja razlog zakaj so nastale države in enakost pred zakonom.
donfilipo ::
Se opravičujem ker mi nekako ne znese več prežati sproti stalno na vsak 'donesek' in komentirati ali argumentirati, ..je tudi civilno življenje in nekaj dela
..zato malo pozno, pa vseeno:
Gre pač za ideološki spor in pretežno ideološko argumentacijo opremljeno z zmerljivkami. Nekatere so vsaj meni, kadar sem vsaj za silo 'preluftan' /kar pomeni da nisem non-stop pred mašino//, ...kar sila zabavne. In poučne. Morda pomanjkanje argumentacije.
Tole bi izpostavil, je pa od NavadnegaNimđe. Socializem ni naraven. IN: evolucija je edino kar velja, sociologija je bull. Nekako tako. Boli v motečem poenostavljanju, izpeljanka se lahko postavi takole: 'kresneš če si močnejši, posiliš mu ženo, pobiješ otroke bati se moraš samo alfa samca, ki pa uvede ponavadi naravno neke posebni sorte socializem?
Mislim rad bi vedel, kaj je tako naravnega v kapitalizmu in kera pička idiotska lahko zagovarja, da se da namesto sociologije pri resnih spoznanjih uporabljati namesto antropologije, psihologije in sociologije kar evolucijo?
In times of Universal Deceit, telling the truth
becomes revolutionary act. Orwell
- spremenilo: donfilipo ()
NavadniNimda ::
Se opravičujem ker mi nekako ne znese več prežati sproti stalno na vsak 'donesek' in komentirati ali argumentirati, ..je tudi civilno življenje in nekaj dela..zato malo pozno, pa vseeno:
Tole si dobro izpostavil. Morebiti dodam tisto glede sociologije, saj si preveč "po domače" tole povedal. Sociologija je veda, ki preučuje družbene odnose. Veda, znanost. To je treba podpirati, na njo se lahko sklicujemo, uporabljamo jo tudi pri tehnološkem razvoju (edini, ki ga cenim in kdaj resno bral: Alan Toffler), in sploh širi obzorja civilizacije.
Ko pa postane sama sebi namen v stilu "tole ni dobro, dejmo raje vsiliti, da bo takole", pa sociologija prestopi boundaries znanosti in vstopa na področje alkemije. Po kmečko povedano, gravitacije NE moreš zanemariti, negirati, ali se sprenevedati, da je ni. Ali še bolj po proletarsko: pohlep in strah sta človeški čustvi, mentalni stanji, teh pa NE moreš odpraviti z dekretom, pa če se unile mentalni wannabe programerček Luxić na tintaro postavi in plapola z uhlji od razburjenja. :D
Kot si rekel, Don Félipe, sociologija je znanost. Ampak znanosti so tudi fizika, matematika in ekonomija. In te naravoslovno-evolucijske znanosti dokazujejo (in dokažejo), da je podležeča realnost vsega, tudi odnosov med individuumi, v temelju stohastična in s tem ne ravno predvidljiva. Kar je subjektivnega pri človeku, bo ostalo subjektivno še naprej. Pojma, kot je Zavest, ki je popolnoma oseben in zaseben, se NE da programirati & podružbiti, pa tudi če se moram sklicevati na prejšnji odgovor, precizneje zadnji stavek.
donfilipo ::
A jebi ga druga pesma. Mnogo bolja
Ni več sociodarwinizem v službi kapitala
, ampak nekakšna morala, da smo poleg družbenih in sočutečih tudi požrešna bitja. Well smo!
Nič več: 'jaz ker mam milijarde, sem evolucijsko višje na lestvici in mi zato pripadajo, ...ampak, ...če bi tu tudi imel to srečo, znanje in požrešnost, bi jih eventuelno lahko imel tudi. Ali pa zadel na tomboli
In na koncu: ni pri družbenih vedah zakonov gravitacije, ali en sam zakon evolucije. Vedno znova je sociologija in spremljevalke. Stohastične res, ampak stohastično je še marsikaj, kar velja za točno določljivo in napovedljivo. Vsaj za par dni naprej. Recimo vreme. Pa še kaj veliko bolj prislovnično preciznega bi našli.
Karaya 52 ::
klanjsekII je izjavil:
Balkan je bil zaostal, Slovenija kot bivše ozemlje K.u.K. je bila precej bolj razvita od zaostalega Juga. Js sm ti dal točne podatke. Pokomentiraj še prepad med Češko in Avstrijo pa rezultate agrarne reforme Pol Pota. Titovega frenda.
Evropska norma za tiste, ki so še na drugi strani civilizacijskega prepada in ki so potem nadaljevali s Srebrenico. Primer Tomasice, ki jo je Republika Srpska zakrivala dve desetletji. Ovirala izkop tako kot so ovirali izkop Hude jame. Potomci klavcev. Na Balkanu je že težko kopati, da nebi naleteli na trupla razoroženih, ki so jih strahopetci streljali v tilnike. Če se jim je sploh dalo porabljati metke, drugače so jih s krampom. Nekatere so izstradali, recimo 40 slovenskih otrok (stari manj kot 5 let) v gradu Ormož, pogreb je bil letos oktobra (ovadili so Mačka). Slovenski mediji niso poročali, so pa prišli Avstrijci in Hrvati. Tako da jype, lahko mirno pozabiš, na "evropsko normo klanja". Si odrezan od akcij, ki potekajo na mednarodni ravni.
Najnovejše odkritje, Tomašica:
In s tem se bo nadaljevalo. To lahko garantiram. Padle so že tri kazenske ovadbe bivših udbašev (Slovencev), ki so izvajali likvidacije po Evropi. Ovadbe so bile vložene v Avstriji. Potomci klavcev so svoje starše zaščitili in sprejeli zakone, po katerih umori zastarajo. In kar je še najbolj vzpodbujajoče, da se apologeti titoizma vsakič ustrelijo v koleno, ko odprejo usta na to temo.
Karaya 52> Evropska norma za tiste, ki so še na drugi strani civilizacijskega prepada
Ja. Na eni strani Švedska in Švica, na drugi pa vsi ostali, brez izjeme.
Karaya 52> Si odrezan od akcij, ki potekajo na mednarodni ravni.
By choice, ker nočem sodelovati pri zločinih.
- spremenilo: jype ()
Brane22 ::
Eh, spet ti jebeni komunisti:
Tri leta v zaporu brez obsodbe
Tip sicer ne govori, kako je blo z WC papirjem, a domnevam da so tolpe glede tega opravile svoje...
Brane22 ::
NavadniNimda ::
OMFG, Tomašica, tole je pa čisto sveže. Sem mau pogledal po netu, tole je spet še en dokaz za genocid, gre za vsaj tisoč trupel. Ni čudno, da se unim zločincem v Haagu podaljšuje čas trajanja procesa.
Zanimivo je, da je tole Tomašico na dan privlekel en od vojakov Jugoslovanske Narodne Armije - ki so po končanih pokolih dobili zadatak, da prikrijejo sledi zločina - ker ga je premagala lastna Vest:
Secrets are hard to keep, and it was a former Serb soldier, originally part of the team tasked with hiding the bodies, who came forward in April (2013, op. Navadni Nimda) unable to live with the guilt he has carried for 21 years. Time is finally delivering justice and laying ghosts to rest.
Link na članek:
WorldNews @ NBCNEWS.com
Brane22 ::
Super. Sem takoj za to, da za tovrsten krivce uvedejo tudi smrtno kazen, če je treba.
Ampak kaj ima to s socializmom per se ?
NavadniNimda ::
Socializem ima prvo mesto pri tovrstnem početju v zgodovini. Tako so pri nas delali leta 1945, tako so delali 1991-1999. In seveda malo po malo tudi vmes, kot vemo iz pričevanj.
Bistvo je sedaj v tem, da se vse te zločine razišče. Ne gre toliko za maščevanje nad krivci, nekateri so že pomrli, eni se kesajo, tretjim se je zmešalo od hudega, itd. Pomembno je, da se take stvari več ne bodo nikoli več nikjer na svetu dogajale, to je vse, kar nas mora brigati.
Popolna odprtost držav, popolna odprtost mednarodne trgovine, popolna inkluzivnost vseh narodov, ras, kultur; popolna izmenjava idej, znanosti, prometa, itd., edino tako se dolgoročno prepreči možnost takih zločinov... Včerajšnji podpis šesterice z Iranom daje upanje v to smer. Tudi vsaj delna pozitivna rešitev sirske problematike glede kemičnega orožja na relaciji USA/Putin nam lahko vliva zmerni optimizem za bodočnost. Ko bodo nekoč na koncu mir sklenili še Izraelci in Iran s Hezbullahom, bomo pa na pragu nove dobe! (nič prej)
NavadniNimda> Popolna odprtost držav, popolna odprtost mednarodne trgovine, popolna inkluzivnost vseh narodov, ras, kultur; popolna izmenjava idej, znanosti, prometa, itd., edino tako se dolgoročno prepreči možnost takih zločinov...
Ampak tebe nismo videli protestirat proti obsodbi in kaznovanju Manninga, ki je "odprl" enega od zadnjih ameriških vojnih zločinov, niti se te ne spomnim zahtevat, da se Busha privede v Haag.
T-h-o-r ::
damn, kaj je s tem forumom
sicer so vas že vprašali - kaj ima socializem s čemerkoli opraviti, sploh po letu '91 lol
- spremenilo: T-h-o-r ()
NavadniNimda ::
Ne, niste. In ne boste. Upam, da zato ne bom končal v kakem Gulagu, kot je za nasprotnike ene in edine vzeličavne Ideologije že napovedal partijski ideolog Žižek oni dan.
Dokler so tu ZDA, tudi če ga kdaj sem pa tja poserjejo pri kaki stvari, smo lahko prepričani, da nam razne Mongoloidne ideologije ne bodo pokvarile vsakdana.
NavadniNimda ::
V čem so recimo pred nacionalisti ?
V ničemer. Nacionalizem in socializem pašeta skupaj, takole: nacional-socializem.
Rusi so zgubili 27+ MIO ljudi na vzhodni fronti...
Rusi so dali neprecenljiv in verjetno odločilen doprinos k zmagi nad nacional-socializmom. Škoda le, da niso odpravili lastnega komunizma iz betic in ureditve. V Nemčiji so to uspeli popolnoma izkoreniniti, kakopak z Ameriško pomočjo, še z ustavo in zakoni je prepovedan. Nemci se tega držijo, kot se spodobi za zrel in civiliziran narod. V življenju obstajajo bolj pomembne reči, kot se histerično vdinjati ideologiji.
Slovence nas še čaka, da doživimo razsvetlitev in se odrečemo socializmu, ki je samo prefrigana trikrat prefarbana podvarianta komunizmov in nacional-socializmov. Skenslat je treba socializem iz ustave in zakonsko prepovedat razne "manifeste", ki negirajo dosežke civilizacije in EU - točno na isti način, kot so to naredili Nemci!
damn, kaj je s tem forumomSocializma je preveč, prisilne sociane države je preveč, vpletanja države v gospodarske zadeve državljanov je preveč, davčne progresije je preveč, po drugi strani je premalo prostega trga, premalo osebne in gospdoarske svobode in takorekoč nič pravne države. Socialna država je samo prefrigana prevara, kako prešvercati socializem iz 20. stoletja v sedanjost. Potrebno se mu je upreti v stilu "mrš, imam bolj pomembne reči za početi v življenju, kot se pepčkati z vsiljenimi ideologijami!".
Ma ne seri. Na zahodu so popucali precej kvizlingov brez nekih sodnih procesov. Recimo ZDA so pospravile v Nemčiji okoli milijona zajetih vojakov, ki bi morali biti obravnavani v skladu z vojnim pravom. Pa jih niso. Saj jih niso postrelili. Samo pustili so jih umreti od lakote. Precej tabu tema na zahodu, ampak kak dokument pride na plano zadnje čase.
Kar se tile Francije, so bili povojni sodni procesi farsa in se jih je precej izkoriščalo za čisto maščevalne namene. Ovajanje sosedov ipd. Francozi so pač edini zahodni komunisti, pa jim je to domače ...
Norveška je na hitro počedila. Kvizlingi so sodelovali z okupatorji in bili "odstranjeni". Zadeva zaključena.
Partizani so naredili isto, kvazi sodni proces in metek ... Nič nenavadnega za zmagovalce v vojni.
Skratka, vsi evropski narodi so to uredili po vojni in danes se s tem ukvarjajo samo zgodovinarji. V Sloveniji pa kar cel narod, kar samo pomeni da jih partizani niso popucali dovolj ...
Danes bi sodelavci z okupatorjem radi celo neke privilegije, ki jih ne gredo. Pravzaprav bi morali biti tiho, da se jih ne spravi še enkrat na sodišče. Namreč zločini proti človeštvu ne zastarajo ...
Je pa zadnji čas da se s tem neha. Ker energijo je treba potrošit za kaj bolj koristnega ...
- spremenil: Invictus ()
WarpedGone ::
Evo junaka.
In v kaki drugi temi on poln pravičništva, kako da on pa že ne zagovarja pobojev, itd.
Fuj in fej invictus in fuj in fej vsi moderatorji SloTecha ki takele izpade mirno prenašajo.
SloTech je zaradi takih zadev le še eno socialnacionalistično trobilo.
Zbogom in hvala za vse ribe
Brane22 ::
"Pašeta skupaj" v smislu da so jih skupaj zapasale kolonialne sile in torej "njim tako paše" ?
Ni res, oboji imajo soliden socialni program. Ne me zdaj silit da ti grem iskat vnebovpijoče primere, škoda časa.
Res ? In to je v čem točno drugače od modernih sojenj teroristom modernih kolonijalnih sil ? V makebelieve "sodnem procesu"...
NavadniNimda> Dokler so tu ZDA, tudi če ga kdaj sem pa tja poserjejo pri kaki stvari, smo lahko prepričani, da nam razne Mongoloidne ideologije ne bodo pokvarile vsakdana.
No, vsekakor boš končal v Gulagu. Dokler zagovarjaš fašizem poljubne vrste, ker je to praktično, si česarkoli drugega niti ne zaslužiš. Ker naša mongoloidna ideologija je vredna življenj njenih nasprotnikov, vključno s tvojim, ker zagotavlja lepši jutri za vse nas, ki ne bomo kolateralna škoda.
Karaya 52 ::
WarpedGone je izjavil:
Evo junaka.
Ta Invictus je itak glasen samo na forumu, ko sem mu dvakrat dal priložnost, da mi nekaj svojih nebuloz v obraz pove, pa je poniknil. Toliko o njegovem pogumu.
Ne samo da je strahopetec, še laže na veliko. Američani izstradali milijon nemških vojakov? Na francoskih tleh je po vojni umrlo 30.000 nemških vojakov in vsi imajo grobove. Seveda priviligiranci, ki so prišli gor po revoluciji radi pletejo mite, ki jih ne morejo podkrepiti s materialnimi dokazi. Milijon trupel se ne da skriti. Pravzaprav so jugoslavnski klavci v Jugoslaviji likvidirali približno polovico nemških vojakov, 90.000 do 150.000-200.000. Kako slabo so to skrili pa se vidi pri vsakem večjem grabenem posegu. Največ nemških vojakov se ni vrnilo iz Rusije, tam pa je cifra res milijon.
- spremenil: Karaya 52 ()
NavadniNimda ::
Lahko se na titowko postaviš, pa mene vseeno ne boš videl, da bi me takele pritlehne komunistićne grožnje uspele iz tira vreči. Sem proti nasilju, če pride že spet do demosocializma bom naredil tisto, kar naredi vsak pameten človek v brezupni situaciji: pošlje vse skupaj nekam in se prične vdinjati alkoholizmu.:D
Brane22 ::
Mislim,d a govori o tem:
Eisenhower's Holocaust
IIRC je voajški zdravnik z USA strani, ki je bil uradno zadolžen za skrb za "zdravje internirancev" napisal knjigo o tem.
Karaya 52 ::
Knjigo je napisal? Car. Škoda da še danes ni nikomur uspelo najti teh posmrtnih ostankov, glede na to, da zločine partizanske in JNA vojske, najdejo v skoraj vsakih občini.
Brane22 ::
Mogoče zato ker ni interesa ?
Kdo je našel posmrtne ostanke ki jih omenjaš in kdaj ?
So jih "našli", ko j e bil ali ko ni bilo interesa ?
Sploh pa, ni kaj iskati. Stvar je znana.
Karaya 52 ::
Poanta je v tem da Nemci nočejo odpirati neke teme ki ima tako ali tako znan konec. Navadno sranje.
Pri nas se pa to lepo počne ... No, sem se zmotil pri cifri ... Je bilo 1,7 milijona vojakov. Moj fotr je celo poznal monterja iz Nemčije, ki je uspel uiti iz takega tabora. Tako da sam za to vem tam okoli 25 let ...
Kako lepo vse verjamete Američanom ...
Nobene. Kar poglej demokratično pravni Guantanamo ... Pa ti bo vse jasno.
Gulag na zahodni način ...
Ti imaš seveda za sabo vedno cel kup argumentov ... Kje sem jih že videl ? trobljenje da so vse zajebali komunisti, pač zame ni argument.
Evo junaka.
Brane22 ::
Buaha... v tvoji glavi je stvar zaključena ja. Moraš verjeti.![]()
Se opravičujem.
Lahko bi vedel da je stvar zaključena ko na Balkanu nekega vojačka zaboli vest in prizna pokol.
Ampak ko veliko živino "kampa" na zahodni strani zapeče toliko da napiše knjigo o svojih izkušnjah med delom v tem "kampu" ( katerega popolni nadzor je imel) potem je to v moji glavi.
In razlika ? V komunističnem nazoru pravične razdelitve profita podjetja.
To je to. Enkrat pošlješ multinacionalko u kurac in že ti začnejo smrdeti trupla po omarah.
Aja še to. Zaradi kurčevo komunističnega principa delitve dodane vrednosti je ta ovjaček ukužen s socializmom/komunizmom od trenutka ko pride v stik z njim. Če recimo služi rok v JNA in kadarkoli potem ubije koga ali oropa banko, je za to seveda kriva kurčeva JNA. Kdo bi drugi, seveda.
Socialistična krivda se očitno podeduje po vertikali in prenaša po horizontali. Zdravila očitno ni.
To ne velja samo v komunizmu. Tudi v nacizmu. Izgovarjanje za svoja dejanja na višje inštance. Befehl ist Befehl. Pa ni važno kaj narediš.
Sicer pa situacija danes ni nič boljša.
Vse za demokracijo in Boga (če poslušam Američane).
Karaya 52 ::
Jaja, to bo, sm Angie klical in je potrdila.
Jaja, to bo, sm Angie klical in je potrdila.Pa cifro si popravil iz milijon na milijon sedemsto in to samo na podlagi linka, ki je podpisan z "uknown author". Materialnih dokazov pa 0. Samo znova in znova dokazuješ v kakšni stiski si, ker pač MORAŠ verjeti, da je partija bila enako slabo kot vsi ostali, drugače bi se ti pol življenja sesulo.
Zakaj bi bil v stiski?
Zate še en link ...
http://justice4germans.com/2013/06/20/t...
Sicer po tvojih standardih tako ne bo kredibilen ... Ampak vseeno, si bo kdo prebral ...
Karaya 52 ::
WarpedGone ::
Od kje si pa to potegnu? Js bi mogu karkoli argumentirat?
Tvoja:
ne potrebuje čisto nobene kontraargumentacije ampak samo radirko in naziv.
Ampak ker si Pravilno Politično Pofarban, se ti na ST tega ni bati.
Oh ja, tukaj sam omeniš komuniste/domobrance, pa postane vsaka debata brezzvezna ...
Kolk fuck up morate biti da verjamete tem zgodbicam. A vas mame niso dovolj dolgo dojile?
Brane22 ::
In to je psoebno v čem ? Za praktično vsako taborišče, kjer papirji niso bili vodeni "v nulo" ali sploh imaš cel spekter ocen. Za Jasenovac se gibljejo IIRC 1:4 ali nekaj takega.
Odvisno kaj šteješ pod dokaz. Imaš številna pričevanja in knjige. Če šteje pričevanje nekega vojačka JNA zakaj ne bi štela knjiga šefa zdravnikov v "kampu" ?
Sploh pa, ta zadeva ni bila takrat ako zelo skrivana, ker so bili Švabi "zalega". Takrat nemce itak ni nihče kaj dosti vprašal, pozneje pa so se te stvari pometle pod tabuje in to je to. AFAIK je v Nemčiji KAZNIVO DEJANJE nasprotovati tovrstnim "zgodovinskim resnicam", tudi če imaš materialne dokaze.
Karaya 52 ::
Če je to tvoj dokazni standard potem je precej nizek. Vse knjige in pričevanja so nabijanja, dokler na terenu ne najdejo milijon sedemsto ali koliko trupel. Pa ne milijon sedemsto. 1000 ali 10000 ali 1000000. Vsaj nekaj. Tako pa ni nič... ne da ni nič, Nemce so pokopali in imajo grobove. Tisti tvoj AFAIK je seveda BS.
Brane22 ::
To je VAŠ standard. Malo prej je tip mahal s fotko žrtve kot dokazom "zločinske JNA". Takrat je bla očitno dost že fotka.
1. kako je lahko "nabijanje" pričevanje mnogih prič, nekaterih na upravnih mestih ? Če je to nabijanje, zakaj se potem sklicuješ na Haag ? Saj tam sodijo praktično izključno na podlagi takih nabijanj.
BTW, AFAIK pri Srebrenici niti za eno truplo ne morejo dokazati načina smrti - da so torej umrli v pobojih ravno tam, ne pa v prejšnjih borbah itd. Ampak to te zgleda ne moti.
2. AFAIK ne prikrivajo števila trupel ampak način smrti. URadno se je takrat umiralo na veliko zaradi različnih bolezni in pomanjkanja in ta trupla so bila uradno knjižena pod to postavko. "Višja sila".
| » | Venezuelske kriptovalute petro še vedno ni (strani: 1 2 )Oddelek: Novice / Kriptovalute | 22815 (19626) | zmaugy |
| » | Karl Marx .... Kapital 2.0....ali kaj drugega (strani: 1 2 3 4 5 6 )Oddelek: Problemi človeštva | 50227 (42433) | donfilipo |
| » | Elektro Turnšek in optikaOddelek: Omrežja in internet | 4615 (2204) | KTr1sk |
