padec telefona
padec telefona
Ikspe ::
Kolegici je padel telefon in zgleda da je pobralo nekaj pikslov. Se jih da kako zbudit?
msjr ::
Tole sem nekje zbrskal, vprašanje če dela:
  1. Turn off your computer/phone.
  2. Get yourself a damp cloth, so that you don't scratch your screen.
  3. Apply pressure to the area where the dead pixel is. Do not put pressure anywhere else, as this may make more dead pixels.
    While applying pressure, turn on your computer and screen/phone .
  4. Remove pressure and the dead pixel should be gone. This works as the liquid in the liquid crystal has not spread into each little pixel. This liquid is used with the backlight on your monitor, allowing different amounts of light through which give off different colours.
Asus prenosnik N551JM - vrnitev kupnine
224364 (3213) xxpolhecxx
Mrtev piksel na zaslonu novega prenosnika (strani: 1 2 )
Oddelek: Zvok in slika
8416136 (14239) coffeetime12
Mrtev pixel - kako ga skriti?
81395 (1226) Valvoline
G force
61665 (1570) guest #44
Jest mam virus a?!
142804 (2561) Kriko
