Forum » Loža » G force
G force
tadvet ::
Malo sem bral po internetu, ker me je pač zanimalo kolk G prenese človek. V bistvu sem bil presenečen nad trditvami, da normalen človek lahko prenese le tam do 9G, če nanj deluje ta sila nekaj minut. Izjema so seveda avtomobilske nesreče, kjer hitro pride do 40G, ampak je sila trenutna in na telo deluje le kratek čas, zato je preživetje možno. A obstajajo kje ti "vrtiljaki" točnega izraza sploh ne poznam, kjer trenirajo piloti lovcev in v katere bi se lahko vsedel ter stvar poskusil ? Ali je to omogočeno le tem pilotom. ?
Zanima me pa tudi kolk G proizvede normalen vrtiljak v zabaviščnem parku če kdo ve?
carcar ::
I believe you can bleed from your nose, but not before you die. If you experience 12 G's for more than a few seconds, your pretty much dead. However, not even fighter pilots experience this. Fighter pilots experience around 7-8 G's and that requires training. Roller coasters and thrill rides only go up to 5 G's, maybe 5.5 G's, never more. Intimidator 305 at Kings Dominion experienced around 4.5 G's, I believe, for an extended period of time. Many people blacked out because of the G's, so they added trim brakes to the first drop. However, this is the only coaster I have ever felt weak on.
You only feel pressure on your chest, pushing you into your seat. However, many people have a different tolerance of G Forces. Some people can black out at 3-4 G's, while others can withstand up to 6 G's. It's all different.
Avenger ::
Tistem se reče centrifuga, sicer pa preber tole: High-G training @ Wikipedia
Verjetno kot civilist tega ne moreš nikjer probat, bi pa tud mene zanimalo, če bi se dalo...
guest #44 ::
Komot se da. Montiraj 2kW motor na en otroški vrtiljak (+ ojačitve), pa ga pali.
Nekdo je govoru da prenesemo tud do 150G če je le trenutna sila.
Vrjamem pa da je odvisno od človeka. Trening, konstitucija telesa,... Pomojem pomaga če si "žilav", ker tko mišice uspejo razporedit kri bolj enakomerno.
To me je vedno zanimalo...zakaj babe, še posebno bolj zamaščene dobijo takoj plavice? Moški ne tolko, še posebno bolj suhi oz mišičasti.
ivanuscha ::
Kakšne plavice? Jst sem šel na vlak smrti ki je imel do nekaj čez 3G in ne bi šu še enkrat :D
noraguta ::
mah natolcevanja
13 komot , pa je sam james bond.
čak noris bi si pr 6g šele čik pržgov.
guest #44 ::
Ko Chuck norris nardi roundhouse kick se v njegovi vrtilni osi naredi manjša črna luknja!
| » | Manj znane igre (strani: 1 2 3 4 )Oddelek: Igre | 49364 (22104) | D3m |
| » | Studying in SloveniaOddelek: Šola | 7667 (4359) | BivšiUser2 |
| » | Personality test... (strani: 1 2 )Oddelek: Loža | 7799 (6675) | XShaeboX |
| » | Diskriminacija kot posledica (strani: 1 2 )Oddelek: Loža | 7001 (6024) | Thomas |
