Mrtev pixel - kako ga skriti?
krispe ::
Pozdravljeni!
Ker imam en mrtev pixel in sem se sprijaznil z dejstvom, da je unfixable, sem se odločil, da ga nekako skrijem/naredim manj vidnega ker res izstopa.
Torej pixel je modre barve in je sicer skoraj na podnu monitorja, a ob črnem ozadju se ga res precej vidi.
Imate kakšno idejo kako bi ga naredil manj vidnega/izstopajočega?
LP in hvala za morebiten odg.
MSI Z97 MPower/i7 4790K + H110/GTX 970/8GB 1866Mhz/SSD 830/760T/LG 34"
jakinal ::
Modro ozadje?
bluefish ::
Lahko za finto poskusiš še tole:
Fixing a Stuck LCD Pixel Pressure Method:
This method works by attempting to spread liquid from the liquid crystal into the stuck pixel via the use of pressure.
1. Turn your LCD monitor off
2. Locate a soft cloth and a ballpoint pen or other tool with a dull point. ( a stylus works well)
3. Using the cloth to avoid scratching or damaging the screen, apply pressure using the pen or stylus to the stuck pixel
4. With pressure still applied, turn your LCD monitor on
5. Remove pressure and if your lucky, the stuck pixel will be gone
Fixing a Stuck LCD Pixel Tap Method:
This method works by attempting to spread liquid from the liquid crystal into the stuck pixel via the use of shock.
1. Turn your LCD monitor on
2. Set your desktop background color to black
3. Locate a rounded slightly pointed object (a marker cap works well)
4. Using the rounded slightly pointed object, gently tap the stuck pixel
5. Gradually increase the pressure used on each tap until the pixel corrects itself
krispe ::
Jakinal, precej gledam filme in takrat ob temnejšem ozadju zelo odstopa. Na namizju sem pa drugače res naštimal bolj modro ozadje tak, da ga vsaj takrat ne rabim gledat :D
Bluefish, te metode sem že vse probal. Sem imel en "stuck" pixel, ki se ga je dalo popraviti z enim samim pritiskom nanj:D. Tale pa je očitno mrtev, saj ne glede na to kako močno pritisnem ni pozitivnega rezultata :8)
Furbo ::
Potem ga pa prebarvaj v črno. :D
krispe ::
Ja to sem že tudi razmišljal. Vendar to bi naredil res takrat če nebi bilo druge možnosti.
Bi pa verjetno siva barva bila najboljša izbira v tem primeru?
krispe ::
Sem pisal na funtech in pravi, da ne jemajo nazaj monitorjev. LOL
Še kakšen predlog?
BALAST ::
Nadeni si modra očala ko gledaš filme. 8-)
Valvoline ::
Dell U3415W / ultra wide
Oddelek: Zvok in slika
397856 (5651) Wolfman
Asus prenosnik N551JM - vrnitev kupnine
224372 (3221) xxpolhecxx
Dead or Stuck Pixel na novem monitorju
242839 (2164) galu
Menjava LCDja pri prenosniku
102103 (1235) cortez
Mrtev pixel na ekranu prenosnika
101909 (1704) gslo
