Forum » Pomoč in nasveti » http - https
http - https
spacemarko ::
Problem sem poskušal rešiti sam, vendar mi ni najbolj uspelo. Pa me zanima vaše mnenje.
In sicer se mi dogaja naslednje:
Na eni internetni strani mi izpiše sledeče-
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, support@aditnetwork.com and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Apache/2.2.22 (Ubuntu) Server at aditnetwork.com Port 443
Ko sem jih kontaktiral so rekli, da je iz njihove strani vse vredu.
Nato sem iskal kaj pomeni zadnji stavek:
Pa sem našel tole:
Bad Request
Your browser sent a request that this server could not understand.
Reason: You're speaking plain HTTP to an SSL-enabled server port.
Instead use the HTTPS scheme to access this URL, please.
Hint: https://adit002/
Apache/2.2.22 (Ubuntu) Server at adit002 Port 443
Če prav razumem bi se URL naslov moral začeti z HTTPS.
In tu se mi zatakne, kajti URL se začne z HTTPS.
Malo več sem se razpisal, vendar upam, da bo kdo imel kakšne ideje in pomoč kaj mi je storiti.
Imam Wndowse XP sp3 in uporabljam FF.
Pa sem našel tole:
Bad Request
spacemarko ::
Lepo prosim.
Kaj to pomeni? Kje to naredim oz. nastavim?
You might consider using .htaccess rules instead, something like:
RewriteCond %{SERVER_PORT} 80
RewriteCond %{REQUEST_URI} (optional pattern additional url matching)
RewriteRule ^(.*)$ https://test.example.com/$1 [L]
if you want to force http just replace 80 with 443 and https with http.
spacemarko ::
Ja je to ta stran.
Ampak se moraš logirat notri. To mi tudi še uspe. Nato pa so notri sobe v katere se je treba logirati z drugim geslom in od tu naprej se mi zatakne.
Me meče ven. Medtem ko prijatelji nimajo problema.
Kaj je to tisto kar sem v drugem postu objavil? Ali lahko to kje spremenim? In ali je možno da če to spremenim da mi bo potem vse delovalo?
Se opravičujem za vnaprej ampak danes popoldne ne bom več mogel odgovarjati. Bom pa z veseljem pregledal odgovore zvečer.
Hvala
Hvala
| ! | Postavitev Apache serverja s podporo za PHP in MySQL (strani: 1 2 3 4 5 6 7 )Oddelek: Izdelava spletišč | 276875 (20776) | miko22 |
| » | Apache in Node.JSOddelek: Izdelava spletišč | 2633 (2319) | dunda |
| » | Apache - localhost JA, IP naslov NEOddelek: Omrežja in internet | 7286 (7145) | ManDriver |
| » | http + ftp serverOddelek: Programska oprema | 2026 (1811) | Spajky |
| » | News Publisher POMOC ?Oddelek: Omrežja in internet | 1200 (1113) | Elemen_T |
