Forum » Izdelava spletišč » Bumpbox (artViper)
Bumpbox (artViper)
aljaz92 ::
Zdravo, eno težavo imam pri html kodi. V svoj html bi rad vstavu bumpbox iz spletne strani artviper (http://www.artviper.net/website-tools/b...
Navodila so sledeča: (http://www.artviper.net/bumpbox-demo/in...
1.) Copy the files you have found in the RAR file to the root of your website ( usually htdocs/ ).
2.) After copying the files, open the website you wish to edit and add the following lines right before the closing body tag (
3.)Now choose and apply a class name to all links that should trigger bumpbox. In the end, your links should look like this, here we use "bump" as the class name:
4.) To activate bumpbox, we need to add (at least) the following script call:
This enables bumpbox, and you are now ready to use it for the first time. Yet, there are a lot more options you can define to adjust the appearance of bumpbox to your liking.
Vse to sem naredil pred konec body tag sem dodal ti dve vrstici:
stvar ne deluje ko klikneš na link ti preprosto odpre pdf v brskalniku, potem sem dodal še vrstico iz 4. točke pod ti dve vrstici tako da konec htmlja zgleda takole:
Sedaj ko osvežim html sploh ne morem klikniti na link da bi mi odprlo pdf.
Mogoče kdo ve v čem je problem ali pa če je že kdo uproabljal to ?
Hvala za pomoč.
</body>):
<script type="text/javascript" src="js/mootools.js"></script> <script type="text/javascript" src="js/bumpbox-2.0.1.js"></script>
<a href="http://www.artviper.de" class="bump">SEO</a>
<script type="text/javascript"> doBump('.bump'); </script>This enables bumpbox, and you are now ready to use it for the first time. Yet, there are a lot more options you can define to adjust the appearance of bumpbox to your liking.
Hvala za pomoč.
- spremenil: aljaz92 ()
| » | SMB povezava Winows 10 s Synology NASOddelek: Operacijski sistemi | 4421 (3687) | dukedl |
| » | 2 napaki pri HTML5 validaciji! Kako jih odpraviti?Oddelek: Izdelava spletišč | 1304 (1018) | slitkx |
| » | Download vsebine strani s JSOddelek: Izdelava spletišč | 3165 (2463) | MrBrdo |
| » | IIS problemiOddelek: Omrežja in internet | 2111 (1829) | extr3m3 |
| » | [php] phplotOddelek: Izdelava spletišč | 1575 (1424) | slovencl |
