Radeon 8500,9000 ali 9100
2
3
ferjan ::
ATi je pre 6 meseci najavio svoje Radeon 9000 i 9000 Pro GPU-ove, koji su trebali da zamene Radeon 8500 LE kartice u low-end, dok su Radeon 9500/9500Pro/9700/9700Pro namenjeni mid i high-end tržištu. Pošto su se 9500/9500 Pro akceleratori pojavili 6 meseci kasnije, Radeon 8500/8500 LE karte su se i dalje prodavale, jer su imale performanse negde između 9000Pro i 9500 modela, i pristupačnu cenu. Pošto su ATi-jeva skladišta i dalje puna Radeon 8500 procesora, kompanija je odlučila da ih predstavi na tržištu kao Radeon 9100 GPU, dajući novo ime starom, ali i dalje konkurentnom, proizvodu. ATi-jev prodajni asortiman sada izgleda ovako :
RADEON 9000: 4 rendering pipelines with 1 TMU per each, 1 Vertex Shader processor, DirectX 8.1 support, core-clock: 250MHz, memory clock: 400MHz. Cena 60$.
RADEON 9000 PRO: 4 rendering pipelines with 1 TMU per each, 1 Vertex Shader processor, DirectX 8.1 support, core-clock: 275MHz, memory clock: 550MHz. Cena 80$.
RADEON 9100: 4 rendering pipelines with 2 TMU per each, 1 Vertex Shader processor, 1 T&L unit; DirectX 8.1 support, core-clock: 250MHz, memory clock: 500MHz. Cena nepoznata.
RADEON 9500 64MB: 4 rendering pipelines with 1 TMU per each, 4 Vertex Shader processors, DirectX 9.0 support, core-clock: 275MHz, memory clock: 540MHz, memory bus: 128 bit. Cena 150$.
RADEON 9500 128MB: 4 rendering pipelines with 1 TMU per each, 4 Vertex Shader processors, DirectX 9.0 support, core-clock: 275MHz, memory clock: 540MHz, memory bus: 256 bit. Cena 170$.
RADEON 9500 PRO 128MB: 8 rendering pipelines with 1 TMU per each, 4 Vertex Shader processors, DirectX 9.0 support, core-clock: 275MHz, memory clock: 540MHz, memory bus: 128 bit. Cena 190$.
RADEON 9700: 8 rendering pipelines with 1 TMU per each, 4 Vertex Shader processors, DirectX 9.0 support, core-clock: 275MHz, memory clock: 540MHz, memory bus: 256 bit. Cena 260$.
RADEON 9700 PRO: 8 rendering pipelines with 1 TMU per each, 4 Vertex Shader processors, DirectX 9.0 support, core-clock: 325MHz, memory clock: 620MHz, memory bus: 256 bit. Cena 290$.
Sodeč po zgornjem besedilu ter spodnjemu testu se definitivno bolj splača vzeti radeona 9100.
http://www.xbitlabs.com/video/rad9000-6...
Clone: kje se ga dobi za 27k??
boštjan ::
nojus ::
jest sem se odlocil za 9100, juri dobim za 26k sit (janus trade). od sapphire-ta
ps. komi cakam :D
sovražim Gargamela.
mlav ::
Tudi jaz sem se odločil in kupil 9100. Imam pa problem. Nimam pravih driverjev. Mi kdo lahko pomaga kje jih dobiti.8-O
||_^_|| ::
catalyst 3.0. www.ati.com
B-Stard ::
Dej prosim naj nekdo ki je kupil 9100 pove kako se obnese. Recimo kak 3dmark,igre,itd
mlav ::
Na tej strani je test nekaj grafičnih kartic, med njimi tudi Radeon.
http://www.xbitlabs.com/video/6-value-r...
vmlejnik ::
ja ampak med njimi na zalost ni radeona 9100 :/
A ga ze ima kdo? Lp
nojus ::
jest mam :D
vreden svojega $$$
sovražim Gargamela.
vmlejnik ::
¸katerega proizvajalca? nam zaupas se konfiguracijo in 3dmark score? ;) Lp
boštjan ::
sicer nimam karte, a sem najdel 2 testa 9100.
prvi je od gigabytovega 9100 drugi pa od sapphire 9100.V obeh primerih je primerjalni test z 9000pro
kuglvinkl ::
OK, tisti, ki jih imate, je na PCBju dodatni RAMDAC ali ne?
Khm, zdele vidim, da ima ta Gigabytov 350 MHz RAMDAC in samo enega. Ok, za prvo so se verjetno zmotili, ker gre kljub vsemu za R200 core, ta pa ima 400MHZ in ziher niso šli spreminjat. je pa še ena možnost, namrel, da _drugi_ RAMDAC laufa pri 350 MHz.
To bo spet dilem in nategovanj...
boštjan ::
v ramdac se nisem nič spuščal in ne gledal na giga oz.sapphire stran,zato te vprašam kaj tam nič nena piše,če je dual ali samo en?
vmlejnik ::
Ce je 9100 res zaklenjen 250/230 a je pol mozno dat gor bios od 8500 pa ga laufat recimo na 275/275? Sej sta kartice iste baje ;) ?
boštjan ::
jaz sem nekje vido forum ko je en dal na 8500LE od 9100 bios gor.
vmlejnik ::
ja to je znano..da se lahka ;) pol more it verjetno tud obratno ... tak mi vsaj logika pravi ;)
boštjan ::
Clone ::
Rud jst mam Radeona 9100 64MB firma pa je Sapphire. V 3D Marku imam pa 9234 točk na 1024*768*32 brez anti aliasinga in z trilinear filteringom.
Škatla pa je sledeča:
ABIT KX7 333
AMD Athlon XP 1800+
256MB Ram 400DDR
pa omenjena grafična
ter disk na 7200 obratov
P.S. (Pa nič od tega ni navito)
Uglavnem Sapphire Radeon 9100 SE splača za ubogih 27K Sit
Clone ::
AJA pa tudi NFS6 dela na FULL brez poblema, ker na radeonu 8500 LE ni delal. UT2003 mi mal šteka zaradi rama, baje ga je treba met 512, SOF2 je ql, uglavnem zatika se samo UT2003 pa še to zarad rama.
nojus ::
samo potrdim clona
ginav tako kot je napisal
sovražim Gargamela.
freejack ::
Eno vprašanje;
Glede Catalyst 3.0 gonilnikov; greš na ATIjevo stran, skočiš DLLjat catalyst 3.0, te vpraša za OS (ok, WinXP), te vpraša za grafično (ok, a se sam men zdi, al Radeona 9100 ni na seznamu)? Kaj pol izbereš 8500? 8500LE, 128Mb, itd. itd., al kaj drugega?
Ok, ne se smejat, ampak jst res ne vem. :\
freejack ::
Aja, pa neki še. Tisti, ki ste kupli grafo v KFM (velenje), zanima me, kk je vent pritrjen na tisto grafo? Z zatiči al lepilom? Ker mam glih Crystal Orba naročenega, pa bi rad vedel, če bi blo treba it še lepilo nabavit?
10x
p.s. kje v velenju je pa sploh KFM (sn namreč iz SG, pa nimam pojma :D )
boštjan ::
TEL: (03) 898 1100 tle je telefonska in jih pitaj,glede 9100 gonilnkov.na ati strani jih ni ker tudi kartice ati ni izdal,tako kot 9500 non pro ne boš najdo na ati strani.vleči dol iz sapphirove strani.
freejack ::
10x
Sn popoldan klical, pa jih menda jutr dobijo. Bom šel preverit. Aha, a da od Saphire je grafa, zanimivo. 10x še 1x.
SaS ::
Zanima me kje v SLO se da dobiti GIGABYTE GV-R9100 in koliko je cena??
___________________
........SYSTEM ERROR
......F*** THE SYSTEM
___________________
boštjan ::
gigabyte je izdal 9100?1.slišim.jaz sem samo slišo da sta sapphire in powercolor izdala 9100.
mogoče pa se glede gigbyta motim,a na njihovi strani 9100 ni.
freejack,tako za 9100 dobiš driverje na sapphire web site.
freejack ::
Pismo, še zdej razmišljam al bi šel jutr po 9100 v KFM, al bi za1x še obdržal GF2 Pro, al bi celo GF4 MX 460 šel kupit. Čist sn zmeden. ;(( ;( :'(
boštjan ::
MX 460 jaz ne bi,saj niti DX8.1 ne podpira,26k za 9100 pa tudi ni dosti
freejack ::
Že res, sam 9100 karta (mislim da) nima hladilnih teles na RAMih (bi jih moral gor nalimat), ima nek vent nižje klase, ki je prilepljen (karta ne uporablja pritrjevanja z zatiči), pa še zdej nimam pojma katere gonilnike bi uporabil (sapphire ma radeon series ver 7.81, right? ampak pri zgornjima testoma je pa uporabljen Catalyst 3.0(6.14.01.6255) gonilnik (če se ne motim)).Poleg tega da sem še privrženec nVidie, me pa Sapphire Radeon 9100 kr fejst mika, sam pismo ko se ne morn odločit.
(p.s.eno vzpodbudno za 9100 še rečete, pa ga grem kr jutr kupit) :D
boštjan ::
lahko uporabljaš tudi catalyst3.0.hitrejša od mx 460 in lepša slika v 2D
ferjan ::
Kje v LJ (in okolici) bi bil najbolj ugoden nakup Radeona 9100? Točno kateri in koliko stane.
boštjan ::
mlacom 25k
freejack ::
Ok, zdej si me pa prepričal. :D
Jutr pokličem v KFM, pa če ne bo mel že pripravljenega, ko uletim v trgovino, zečnem sam streljat. :D
[v četrrek dobim še pa Crystal Orba, da bom še tega nalimal gor, pol morn še pa rebra nekje staknit (beri: Conrad)...:D ]
boštjan ::
TUKAJ pa maš 128MB verzijo za 27700
freejack ::
My very own, radeon 9100. So beautiful, so fast, so ATI. :D Dons nardim backupe datotek (sam še 20Gb >:D ), jutr sformatiram, naložim nov sistem, pol pa sam še 3DMark. :D
ferjan ::
boštjan: Mlacom ima R9100 samo na ceniku, dobijo pa jo šele sredi prihodnega tedna (če verjameš)...drugače pa dam raje jurja več in kupim drugje.
SaS ::
Povejte kje se da dobiti radeona 9100, ker jih nikjer nimajo, le na ceniki večinoma!
Pri KFM ga tudi nimajo, vsaj na cenuku ne!
Dajte kake linke do strani!!
___________________
___________________
GTi ::
Počakte še mau ljudeki, da mau več 8500-ic sFLASHajo >:D
freejack ::
SaS: (s KFM cenika, dons dopoldne sn bil pri njih)
Radeon 9100 64M DDR DVI-D TVO (250/230) 26.040 SIT
Kar so naročali, je že "šlo", saj je blo v naprej rezervirano. Moral bi jih poklicat, pa vprašat, če jih še dobijo.
telefon:03 / 898 1100
boštjan ::
SaS in vsi tisti,ki hočejo 9100,bo treba poklicat in pač rezervirat
freejack ::
No pa sem uspel pognat 3DMark; 7379 pik. (btw. vse še na default, nisem uspel še kaj navit :D )
Aja, konfiguracija je v podpisu.
boštjan ::
tisti ki mate 9100 poglejte če ma ta kartica 2 ramdaca
freejack ::
Mislim, da ma sam enga, sam ne me držat za besedo. [1x Internal(350)]
ferjan ::
Saphirov R9100 (64 in 128) ima sigurno podporo dveh zaslonov. Mislim pa, da je podpora dvema zaslonoma za razliko od starih radeonov pri R9100 integrirana v enem čipu.
Tudi mene za drugi stavek ne držati za besedo ker nisem popolnoma prepričan.
kuglvinkl ::
Po čem sklepaš, da ima podporo? Zaradi dodatnega DVI izhoda? To absolutno ne pomeni, da sta gor dva RAMDACa. Je samo indic, da obstaja možnost :).
Kakor jaz vem, dajejo na R9100 R200 jedra. In ta _nimajo_ dveh RAMDACov. Tko da mora bit drugi obvezno na PCBju (R9000 ima dva že v jedru).
Morte vedeti, da si ATI in partnerji Hydravision jako široko predstavljajo. Namreč, prpopajo nalepko, da karta popdira HydraV tudi, če ima samo en RAMDAC, ker pod to oznako smatrajo že monitor + TV... .
Bom našel eno slikco R8500 kjer je označeno, kej mora bit drugi RAMDAC.
kuglvinkl ::
ferjan ::
če bi prebral specifikacije na strani do katere sem dal povezavo bi videl da piše "Dual monitor support and DVD playback"...kar pomoje pomeni, da podpira dva monitorja istočasno....drugače bi verjetno napisali Dual display support. pa tudi v Mlacomu so mi zatrdili, da ima takoimenovani twinview.....seveda pa obstaja možnost, da oboji lažejo.
ferjan ::
ooo poglej poglej....vidim, da je celo na slikci (na strani do katere sem dal link) prispajkan drugi ramdac točno tam, kjer si narisal, da ga ni.
skratka kupiti bo treba Saphirovega R9100....yupiii komaj čakam torek.
ferjan ::
še slikca....samo ime fajla od te slikce me še malo moti :(
kuglvinkl ::
Da bi šel Mlacom spraševat...
Sicer pa je odgovor preprost oz. kako ugotoviti če sta gor dva. Na karto obesiš dva monitorja in nastaviš različne ločljivosti za vsak monitors posebej. Če ti to delam sta gor dva.
Kot rečeno, PR in ATi ...
2
3
Katero grafično kupiti do 30k?! (strani: 1 2 3 )
13910134 (8376) js
Izbral bom med temi karticami, toda katero?
311766 (1415) Dr_M
Gafikulja do kakšnih 25k sit
362329 (1619) goku :)
Sapphire RADEON 9000 Pro in 9100 (strani: 1 2 )
885731 (4358) Oblivion
Razocaranje 3dmark
332175 (1772) ali3n
