prenosnik asus k50c kako v bios
amigo_no1 ::
Kako na prenosniku asus k50c priti v bios je vprašanje (kaj pritisniti).V navodilih o tem ne piše čisto nič, z googlom si takistom nisem mogel pomagati.Med bootanjem ne piše nič, edino prikaže še Asusov ExpressGate program.
http://www.asus.com/Notebooks/Versatile...
http://forum.notebookreview.com/asus/38...
ExpressGate - Based on Linux, this utility features a graphical user interface, web browser, Skype, and a chat client based on Pidgin. It allows users to fully utilize these features without having to boot into Windows. Using ExpressGate instead of Windows does not help conserve battery life. A fun feature, but not necessary.
  • spremenilo: amigo_no1 ()
RejZoR ::
Zelo odvisno. Običajnomoraš stisnit tipko Delete, pri nekaterih je Insert, pri enih F2 itd itd. Pri mojem Compaq-u moraš stisnit Esc, da se pojavi menu, šele tam izberem kaj hočem naredit naprej (boot opcije, BIOS itd). A v navodilih nič ne piše?
logout ::
V navodilih za uporabo tega NB piše:
"If you need to run the BIOS setup to set or modify the system configuration, press [F2] upon bootup to enter the BIOS setup"
L.p., Kloko
amigo_no1 ::
Že vidim zakaj nisem našel:
na asusovi strani imajo 2 verziji navodil, jaz sem prebral samo krajšo verzijo (24 strani) 1.44 MB :P.
K50/X5D Series Hardware User's Manual for English Edition (E4574)
File Size
1,44 (MBytes) 2009.05.15 update
vs
K50/X5D Series Hardware electronic User's Manual for English Edition (E4547)
File Size
6,58 (MBytes) 2009.05.15 update
Neuspelo navijanje Intel core 2 quad 9550 (strani: 1 2 )
Oddelek: Navijanje
7115594 (14044) Domobrancek
Težava: zagon sistema
14988 (876) amigo_no1
Bodo Dellovi uporabniki pričeli pogosteje uporabljati Linux?
104072 (3530) desperados
Laptop - vprašanje
61147 (1047) Robocop1
Bios 8rda+
Oddelek: Navijanje
71349 (1247) kuglvinkl
