Forum » Navijanje » Bios 8rda+
Bios 8rda+
l-note ::
Tegale is TE strani.
Mainboard model name: 8RDA+
BIOS filename: 8RDA3716.BIN (A800)
Updates in this version:
• Update BPL version to 3.09 for increased memory stability
Updates included from previous version:
• Set memory frequency by SPD
• Disable PS2 KB/Mouse swap function
• Add Auto option for DIMM voltage adjustments
• Resolved strange mouse behavior of the PS2 mouse upon Win98SE resume
• Show "nForce2 Ultra 400 Support" at post screen
OwcA ::
.bin posnameš na prazno disketo, nato med POSTanjem pritisneš ALT in F2.
kuglvinkl ::
Am, glede na to, da si očitno še začetnik, ti predlagam, ne, mater imam široko srce...
Overview
The BIOS (Basic Input Output System) of a mainboard is software stored on an EEPROM chip which helps the mainboard to function correctly and communicate with devices on the PCB surfaces and also secondary devices and software protocols that are attached to or running on the mainboard respectively.
Sometimes we find it necessary to update the BIOS image files in order to make allowance for newer processors, newer operating systems, enhance device compatibility, add features or increase performance and stability. To upgrade the BIOS, one has to subject their machine to the simple process of flashing.
Flashing the BIOS
There are two ways in which we recommend the end user flashes their BIOS. They will be termed as follows :
The ALT+F2 Method
The Boot Disk Method
The ALT+F2 method may not be available on older mainboards with older BIOS, in such cases it is necessary to carry out the Boot Disk Method.
The ALT+F2 Method
Download the required BIOS image file from the EPoX website.
Copy or extract the BIOS image file (named xxxxxxxx.bin) to a blank floppy disk with no bad sectors on it.
Restart the machine with the floppy disk in the floppy drive
When prompted at machine initialization, press ALT+F2 to begin performing the flashing of the BIOS.
The BIOS will automatically flash and reboot the machine.
After this, press DEL to enter the BIOS setup and select to "LOAD OPTIMIZED DEFAULTS". After doing this select to "SAVE & EXIT"
Please note that this does not create a backup of the BIOS binary file.
This does not require you to have a bootable floppy disk.
1. Create a bootable floppy disk in accordance with the instructions laid out in the manual of your particular operating system. This bootable floppy needs to be able to boot to a DOS console capable of executing normal MS-DOS batch and executable files.
2. Download the required BIOS image file from the EPoX website.
3. Ensure the mainboard is set at LOAD OPTIMIZED DEFAULTS and is not overclocked in any way.
4. Copy to this floppy disk this latest copy of AWDFLASH version 8.24f and also a copy of the BIOS binary image file called xxxxxxxx.bin
5. Insert the diskette into drive A, reboot your system and boot from the diskette.
6. When booting is finished, type awdflash *.bin /sn/py/cc/ (dependant of the name of the BIOS image file) and
7. then press return to run BIOS upgrade program.
8. After this, press DEL to enter the BIOS setup and select to "LOAD OPTIMIZED DEFAULTS". After doing this select to "SAVE & EXIT"
9. Please note that this does not create a backup of the BIOS binary file.
10. For Command line help on Award Flash utility, type AWDFLASH/? at the command prompt and press return.
Overview
Flashing the BIOS
The ALT+F2 Method
The ALT+F2 Method
| » | Piskanje kompa in ta se ne prizge!Oddelek: Strojna oprema | 1915 (1768) | Morph3us |
| » | Narobe flashan bios na Asus CUSL2-C Black PearlOddelek: Pomoč in nasveti | 2557 (2232) | SkIDiver |
| » | QDI Kudoz 7x KT400 napačen biosOddelek: Pomoč in nasveti | 1867 (1800) | kihc |
| » | Šla plata ob updatu biosa?Oddelek: Pomoč in nasveti | 1854 (1507) | ru7 |
| » | Katero od teh dveh EPOX plat? (strani: 1 2 )Oddelek: Kaj kupiti | 6963 (6327) | krucymucy |
