Forum » Problemi človeštva » Zima, ki ni zima
Zima, ki ni zima
globalna80 ::
Zakaj prihaja do globalnih sprememb?
Že Pitagora, veliki mistik, je rekel da ima vse mero in število.
Sonce s svojimi planeti vključno z Zemljo potuje skozi 12 nebesnih znamenj. Cela pot traja 25.920 let. Bližamo se koncu tega obdobja in začetku novega. Pojavlja se čiščenje na poti do velike preobrazbe. Bližamo se središču galaksije kjer je močna energija in svetloba, ki je vir energije in informacije.
Znanost je dekla kapitala.
Great spirits have always found violent opposition from mediocre minds.
Albert Einstein
Albert Einstein
- spremenilo: globalna80 ()
globalna80 ::
Vse kar pride v orbito našega sončnega sistema vpliva tudi na naše vreme. To ima velik vpliv na klimo, magnetno polje, elektromagnetno sfero.
Albert Einstein
Albert Einstein
gendale ::
globalna80 a bi mal varikine
http://pastebin.com/QiWny5dV
danes zjutraj sem začutil mrzel veter iz severa. očitno prihaja zima.
GregiB ::
@ Mipe... great... pri tebi sneg, pri meni pa še vedno toplo... vsi happy...
Mipe ::
Toplota je precenjena. Ugotavljam, da bolje delam, ko je nekoliko hladno (a ne prehladno). V toplem se polenimo.
Mr Hilter ::
Pametno razmišljaš:
Klaudios Galenos (133–200 A.C.), vulgarly Galen, – another illustrious Greek physician, admirer of Hippokrates and polygraph on medical matters – took up the idea and elaborated on it. He assumed an influence of the climate on the mix of body fluids which would then determine the character, or temperament (sic), of a person. Thus body and soul of the inhabitants of the cold and wet north were wild and savage, while those of the people in the hot and dry south were meek and flaccid. And it was only in the well-mixed – temperate – zone that people lived with superior properties in regard to good judgment and intellect, the Greeks naturally and, perhaps, the Romans.
GoodSatanist ::
Matev ::
Sneg potrebujemo, in to pod nujno!
a da se boš ti z zalto žličko v ustih smučal in sankal?
jaz snega čisto nič ne potrebujem
Mipe ::
Matev ::
Aja, pa sneg je dober za naravo.
a zato je v državah ki ne poznajo snega tako slaba narava?
predvsem zato, da promet obtiči ali pa se vsaj upočasni
če želiš obtičati se niti na cesto ne spravi - pa boš obtičal doma
Mipe ::
Matev: zato, ker so pri nas rastline aklimatizirane za sneg, v tistih državah pa ne. To bi pa ja lahko že vedel.
In ne želim obtičati, ravno nasprotno, promet me ovira. Sem namreč pešec in imam poln kufer nekulturnih voznikov. Glede na tvoj odnos domnevam, da si eden njih.
gendale ::
tuki je treba upoštevad, da je uporabnik matev bolj tak mehkužec, ki ne prenese mraza
taki ob pravih zimah pocrkajo in je logično da si ne želi zime
za prave moške pa zima seveda ni problem
Matev ::
ja me zanima kaj bi rekel ko bi moral 1x skidati sneg
lahko je govoriti če živiš kot bubrek v loju
Mipe ::
Kaj imaš proti kidanju snega? S to izjavo si ravno svetu sporočil, da si delomrznež. Najbrž celo smeti ne odneseš, ne da bi godrnjal.
Matev ::
imam proti temu da ljudje želijo slabo drugemu
odgovor mipeta na vprašanje zakaj si želi snega...
odg: predvsem zato, da promet obtiči ali pa se vsaj upočasni.
žalostno
gendale ::
ti že veš
od pomankanja fizične aktivnosti so vsi tvoji organi obdani s par cm špeha
Berserker ::
Mislim da snega pod 1500m sploh ne rabimo. Bi raje videl če bi imeli mediteransko podnebje z kakšnimi 15-20 stopinjami v decembru pa tja do aprila, precej lažje bi delal, okolje bi bilo lepše, ker nebi bilo tako golih dreves, tudi telesno nebi tako trpel, saj so mi roke v času od oktobra pa do zdaj čisto razpokale, da mi že kri skozi teče, kljub mazanju z mazili.
gendale ::
ne hvala
Pyr0Beast ::
Hvala prosim ja.
Berserker ::
ne hvala
Premisli, prešparal bi na kurilcu, drvah, premogu ali elektriki. Da ne omenjam cestnega prometa in stroškov z osebnim avtomobilom. Mesta so pozimi precej grda, če gre za suhi sneg(kar je redko) , še nekako gre, ampak MB pozimi izgleda kot ena grda greznica, povsod grda pludra...pravo nasprotje od pomladi.
Tudi klima poleti ni ravno nujna, vsaj mi je ne uporabljamo doma in marsikdo ne.
gendale ::
ne hvala
meni so poletne temperature največja muka, sploh nimam energije za nič
pozimi je pa super počutje, več energije, lepši spanec, manj golazni, ..
pa mb je greznica v vseh letnih časih
energetik ::
dexterboy ::
Včasih se vprašam, ali je večina folka tukaj na slo-tech t.i. "pussy pička", ali pa so vsi še tako mladi in jim je bilo vse postreženo na pladnju...
Ko je poletje in sonce, ste fsi veseli, ko pa pride zima in sneg (ki ga nažalost ni), pa vsi jokate. Mar vas kdo zadržuje, da ste tukaj. Saj imate južno poloblo pa "down under" in lahko komot greste...
Pač se je treba sprijazniti s tem, da ima vsako letno obdobje svoje čare in je znati treba v njih uživati. Ja, priznam, da sta se spomlad in jesen kar nekako izgubila, imamo zgolj in samo le poletje in zimo. To, da bo kmalu božič in da ne bo nič pobeljeno, zame ni božič. Bil dvakrat po mestu v LJ in so tisti štandi pa tiste lučke... to naj bi bilo vzdušje? Sej PO ni nič bolje, le zrak je veliko čistejši, pa sonca je več, ampak ko pa zapiha...
Bojim se, da se oddaljujemo od teme... zato hitro lopato v roke in kidat, da se dobijo žulji na rokah in ne bo možno miške držat pa po spvragu udarjat
Pyr0Beast ::
Očitno si tule pi*ka le ti, ko nimaš jajc da bi se postavil zase in zahteval ugodnejše vreme, raje kot to, pa zmrzuješ in kidaš sneg.
dexterboy ::
Jaz imam sneg zelo rad ter ga pogrešam in na kidanje gledam kot na obliko rekreacije. Sem pa napisal, da če komu ni tu všeč, ima na potovalnih agencijah veliko ponudbe za južne kraje, kjer se je ravnokar začelo poletje... Toliko od mene v tej temi, ki je od dveh zanimivih vprašanj krenila v izražanje osebnih mnenj o tem, kdo je pussy, da rabi črnca, da bi mu skidal sneg...
Starodavni ::
DexterBoy, če rabiš rekreacijo potem pojdi na dan s palicami hoditi 1 uro do 2 uri, garantiram ti, da se boš v nekaj mesecih boljše počutil, imel manjšo maso (če boš jedel samo do 18 ure) in trebuh se bo zmanjšal.
Mene sneg ne moti, me pa moti južni sneg, ki je težak za popizditi, še najraje bi gledal, da bi enkrat zapadlo potem pa bi bilo 2 meseca mir in zimske temperature. To pa je tudi vse.
Matev ::
DexterBoy
človek kot tak je utvtrajen ali evolviran za okolje kjer ni snega
in če ti misliš drugače je to tvoj problem
globalna80 ::
Ljudje so prilagojeni različnim vremenskim razmeram. Nekateri tipi ljudi se boljše počutijo ob malo bolj mrzlem vremenu nekateri ob toplem. Smo si različni.
Albert Einstein
Albert Einstein
Gretje je cenejše kot hlajenje, pa ko si enkrat nag nimaš več kaj, dodatne plasti pa nikdar niso problem.
Danes zjutraj sem s kolesom štartal pri -5, pa je bila vožnja nadvse prijetna, poleti pa pri 32 in ogromno vlage v zraku še vedno ne pomaga nobena tehnika.
T-h-o-r ::
letos je vreme bolj točno, kot v zadnjih letih
sneg je padel 2 dni pred uradnim začetkom zime, ne pa oktobra, kot očitno nekateri mislite, da bi moralo bit
oktobra še ni zime
mi je pa bolj všeč, če temperature niso pod 0
ne, ker so potem poletja prevroča, which sucks
in offtopic: zakaj je globalna persona non grata? kolikor vem, ni nikogar nikdar žalil/a
oktobra še ni zime
Hvala prosim ja.
- spremenilo: T-h-o-r ()
T-h-o-r> in offtopic: zakaj je globalna persona non grata? kolikor vem, ni nikogar nikdar žalil/a
Če v Z&T kot kak Thomas vztrajno limaš obscenosti, ki niti z znanostjo, niti tehnologijo nimajo nikakršne zveze, te tak ukrep prej ali slej doleti.
T-h-o-r ::
a ni za to persona rudis :P
energetik ::
Vremenske karte kažejo, da še vsaj do 29.12. ne bo padalo praktično nič, ne sneg ne dež. Po božiču bomo celo dobili še konkretno otoplitev v višinah, v nižinah pa verjetno nagravžno megleno pokrovko.
Leto 2011 bo očitno izjemno suho.
energetik ::
Jah tisto 24. je bolj kot ne zanemarljivo, par mm padavin. Mogoče bo za vzdušje, če bo v obliki snega.
| » | Smučišče 2864 (strani: 1 2 3 4 … 7 8 9 10 )Oddelek: Loža | 173082 (70837) | Zimonem |
| » | *** sneži 2016-2017 *** (strani: 1 2 3 4 )Oddelek: Loža | 47170 (30015) | krneki0001 |
| » | Leto 2013 eno izmed najbolj vročih (strani: 1 2 3 )Oddelek: Novice / Znanost in tehnologija | 53036 (48956) | donfilipo |
