Forum » Loža » Chernobyl
Chernobyl
s1m0n ::
Drugo pa so vse pokradli.
Samo zanimivo je takšne fotografije videt!
Pa mislim, da tisto ni ura ampak štoparca...
- spremenil: s1m0n ()
guest #44 ::
''Among all the problems caused by Chernobyl, the genetic [mutation] problem should come first. ... It is a huge problem.''
http://www.commondreams.org/headlines02...
http://www.shortnews.com/start.cfm?id=6...
Knowledge about possible genotoxic effects of low-dose radiation on the human germline is limited and relies primarily on extrapolations from high-dose exposures. To test whether ionizing radiation can cause paternal genetic mutations that are transmitted to offspring, we enrolled families of 88 Chernobyl cleanup workers exposed to ionizing radiation. We analyzed DNA isolated from lymphocytes for mutations via DNA blotting with the multi-locus minisatellite probes 33.6 and 33.15 and via PCR in a panel of six tetranucleotide repeats. Children conceived before and children conceived after their father's exposure showed no statistically significant differences in mutation frequencies. We saw an increase in germline microsatellite mutations after radiation exposure that was not statistically significant. We found no dependence of mutation rate on increasing exposure. A novel finding was that the tetranucleotide marker D7S1482 demonstrated germline hypermutability. In conclusion, our results do not support an increased level of germline minisatellite mutations but suggest a modest increase in germline mutations in tetranucleotide repeats. Small sample size, however, limited statistical power.
http://www.ncbi.nlm.nih.gov/pubmed/1506...
Reproduktivno sposobni preživeli so mutacije prenesli v naslednji rod, človeški genom je tako bogatejši za nekaj nezaželjenih mutacij. That sucks!
Zdaj pa so tam našli modre pse:
https://siol.net/novice/slovenija/v-cer...
Zakaj so modri, še ne vedo.
V-i-p ::
Res je. Ni ura, ampak je (bila) štoparica ;).
Ni štoparca, je intervalna ura, s kazalci na 15 sekund...
Namenjena temu, da folk ne dela predolgih pavz
| » | S.T.A.L.K.E.R. (strani: 1 2 3 4 … 8 9 10 11 )Oddelek: Igre | 112114 (29994) | Meizu |
| » | Zmanjšanje radiaktivnostiOddelek: Znanost in tehnologija | 2759 (2339) | SplitCookie |
| » | Nekaj manj znanih filmov v letu 2012Oddelek: Sedem umetnosti | 6755 (4613) | oo7 |
| » | Fukušima - jedrski incident stopnje 4 v teku (strani: 1 2 3 4 5 )Oddelek: Novice / Nova vsebina | 98556 (85161) | Pyr0Beast |
