SSD disk
SSD disk
BRBR ::
wiki ...
Solid state drives that use flash memory have a limited number of writes over the life of the drive.SSDs based on DRAM do not have a limited number of writes.
Nekdo mi je razlagal da se mora vsake toliko časa (bolj pogosto kot na navadnem disku) naredit kot ene vrste defragmentacijo ..., sicer stvar postane počasna.... in da za to kao obstaja free software, oz ga dobiš zraven ko kupiš SSD.
SSD write performance is significantly impacted by the availability of free, programmable blocks. Previously written data blocks that are no longer in use can be reclaimed by TRIM; however, even with TRIM, fewer free, programmable blocks translates into reduced performance.
Razlaga telih dveh navedkov ?
Sssaga ::
Malo nižje v Wiki linku piše
Disk defragmentation should be disabled because the location of the file components on an SSD doesn't significantly impact its performance, but moving the files to make them contiguous using the Windows Defrag routine will cause unnecessary write wear on the limited number of P/E cycles on the SSD. The Superfetch feature will not materially improve the performance of the system and causes additional overhead in the system and SSD, although it does not cause wear.[101]
SSDs do not benefit from defragmentation because there is little benefit to reading data sequentially and any defragmentation process adds additional writes on the NAND flash that already have a limited cycle life.[62][63]
Da bi ga imel jaz za Fraps snemanje po 200 GB+ na teden... ne hvala :))
  • spremenilo: Sssaga ()
BRBR ::
Torej ne defragmenatcijo, ampak nekaj podobnega. Kao, stvar sčasoma, če se velik piše in briše, (npr. po moje, če imaš tam swap file al pa kakšen working folder od photoshopa), postane počasna.
  • spremenil: BRBR ()
Mavrik ::
V bistvu je preprosto: pri flash celicah (s kerih je sestavljen SSD) je brisanje izjemno počasna operacija (konkretno počasnejša od česarkoli pri navadnih HDDjih) obenem pa tudi nekoliko poškoduje celice (kar je krivda za omejeno število pisanj pri SSDjih).
Kontrolerji SSDjev to kompenzirajo na ta način, da vse spremembe datotek preprosto zapišejo v druge prazne celice, stare polne pa izpraznijo kasneje, ko je čas in ni aktivnosti na disku. Problem pa nastane, ko ti datoteke izbrišeš: namreč operacijski sistem samo izbriše vnos v tabeli datotek, kar pomeni da kontroler diska ne ve nič o tem, da lahko tiste celice izprazni. Tu pride v igro ukaz TRIM, s katerim operacijski sistem pove kontrolerju, da so celice izbrisane datoteke proste in jih lahko izprazni.
No, pri pogostih pisanjih pa je težava potem v tem, da kontroler nima časa, da bi praznil nerabljene celice. Posledično se ti lahko zgodi, da ti praznih celic zmanjka in boš pri naslednjem pisanju v datoteko moral čakati na praznjenje celic, kar močno upočasni delovanje diska.
Druga stvar tule pa je - moderni SSDji imajo velikost celic nekje med 1MB in 4MB. To pomeni, da mora biti celotna 1MB-4MB celica zapisana (izbrisana) skupaj v paketu - posamezni koščki ne morejo biti. Tudi če ti zapišeš datoteko, ki je velika samo 1KB ali spremeniš 15B v datoteki. Na dolgi rok se ti zato lahko zgodi, da imaš vse 1MB celice v SSDju (hipotetično) zapolnjene s po 1KB datotekami in ni več nobene proste (pa čeprav je cel disk zaseden samo kakih 5GB).
Orodja o katerih ti govoriš potem poskrbijo, da se najprej pobrišejo vse nerabljene celice in se podatki pomaknejo v čimmanjše število celic, tako da imaš po zagonu orodja prostih čimveč celic za nadaljno uporabo.
RejZoR ::
Ko sem bral uradni dokument od Microsofta je pisalo, da ni potrebno ničesar tweakat in spreminjat. Čeprav pri meni ni zaznalo SSD-ja in je defragmentacija ostala vklopljena. To sem potem ročno izklopil. Drugo pa sem vse pustil, od prefetching mehanizma, superfetcha, pagefajla, system restore itd.
SmeskoSnezak ::
Ja, samo ta P/E oz. writes limit imajo flash SSD-ji, kar ni stvar pri DRAM SSD-jih, kolikor zdaj berem. Kje bi našel informacije, koliko stanejo DRAM SSD-ji oz. kje piše, da ima SSD DRAM namesto flash storage?
@ Pusti soncu v srce... @
RejZoR ::
A? Kakšen DRAM? To je NAND FLASH, ki je non volatile, kar pomeni ko zmanjka štroma (ko ugsneš oz če zmanjka elektrike) podatki ostanejo. RAM je volatile spomin, kjer se ob izgubi napetosti v slednjem vse pobriše.
Taki SSDji so zelo dragi + ram se zbriše če ga nimaš pod napetostjo.
Dans majo kontrolerji tulk poštiman wear leveling, da ti je skrb, da odmrejo celice na zadnjem mestu.
Prej boš menju SSD, ker bo premajhen, kot pa da se ti bojo iztrošle celice.
Zdej če se res menijak in pišeš non stop po disku, si lahko omisliš SLC SSD, sam tud ti niso poceni..
SmeskoSnezak ::
Beri zgornji wiki citat. Obstajajo tudi SSD-ji z DRAMom namesto flasha. SLC SSD, kje najdem več informacij?
SLC ni nic posebnega. Razen pri ceni.
http://geizhals.at/?cat=hdssd&xf=1195_S...
BRBR ::
Imam eno ponudbo za tole , okrog 150 EUR
SSD disk Intel 80GB
vmesnik: SATA2
tip diska: SSD
kapaciteta: 80 GB
hitrost prenosa: branje do 270MB/s, zapisovanje do 90MB/s
dostopni cas: 75 ?s
MTBF: 1.200.000h
velikost: 2,5", višina 9,5mm, 88g
BOX pakiranje - nosilec za vgradnjo v 3,5", SATA kabel, Intel Data Migration program
A to pomeni da če temu zmanjka štroma, papa vsi podatki, in kaj je tistole čudo MTBF ?
Gwanaroth ::
Nič papa podatki.
MTBF - mean time between failures oz. koliko ur deklarirano zdrži, preden gre v k..
Pyr0Beast ::
Naj bi zdržal
Statistično povprečje
Ne drži pol piskra mrzle vode
RejZoR ::
Mja no, če je teb crknil ni treba zdej tko posploševat. Je pa res da je pri SSD-jih tko, da ponavadi krepnejo brez opozoril. Navadni diski pa to redko storijo, ker vedno začnejo prej kazat simpome. Take in drugačne.
Sam sem se tud vdal v SSD manijo in sicer za netbooka in zaenkrat kaže dobro. Če pa bo pri tem ostalo pa je vprašanje. Upam da bo.
LuGi ::
Moj že dela 2 leti brez težav ;)
smejko ::
Kateri SSD predlagate za v Lenovo ThinkPad W520?
Predvsem izbiram med OCZ Vertex 3 120GB in pa Intel 510 120GB
RejZoR ::
Vrzi v izbiro še Corsair Force 3 120GB...
Vzdržljive Compact Flash kartice (strani: 1 2 )
9217425 (16317) misek
Konec OCZ-ja (strani: 1 2 )
9724247 (19142) Skyman
Micron izboljšal vzdržljivost NAND-flasha (strani: 1 2 )
649399 (8458) Pyr0Beast
Intel in Hitachi skupaj na SSD-trg
Oddelek: Novice / Diski
155431 (4688) PrimozR
