NLP na posnetku CNN?
clancy ::
Ali je to resnično ali fake?
http://cnn.com/video/?/video/us/2011/07...
Ni mi jasno, da je CNN objavil ta posnetek, če je gor NLP, no vsaj videti je tako. Nikjer pa ni nič omenjeno.
popster ::
mislim da je odsev na steklu helihopterja, drugače pa precej prepričljivo.
Brane2 ::
U, mater. Sem se že ustrašu, da je NLB na CNN-ovem posnetku, uffff 8-O
enjst ::
clancy je izjavil:
Ali je to resnično ali fake? Ni mi jasno, da je CNN objavil ta posnetek...
Tole
Haboob @ Wikipedia
je razlog za objavo posnetka.
clancy ::
popster je izjavil:
Če bolj pogedaš začetek posnetka, se lepo vidi, da je kamera pripeta zunaj, na spodnji strani helikopterja, tako da odse na steklu helikopterja ne more biti.
@enjst
poanta ni Haboob, ampak dva leteča objekta, ki se pojavita.
  • spremenil: clancy ()
Vikking ::
So what is it? A UFO? An airplane? Helicopters?
The truth is, the two "orbs" are actually airplanes.
"I saw the planes the whole time and I actually heard the pilots describing the low visibility conditions as they were making their approach into Sky Harbor," said Air15 Photojournalist Jesse Rutherford who shot the video in question.
We found some of the links posted on the UFO websites do not include the entire clip of the video.
Air 15 was positioned about 400 feet off the ground over Tempe facing east. At the time, the airplanes are at a higher altitude and at the end of the video clip one of the planes is clearly seen flying in the direction of Sky Harbo
slika drugega opazovalca ter njegov citat se glasi: "Here is the link to the photo I took. Clearly you can see the two airplanes in their normal landing patter. "
  • spremenilo: Vikking ()
radiculus ::
Človeška neumnost je brezmejna.
jest10 ::
clancy je izjavil:
popster je izjavil:
@enjst
Pa tako lepo se vidi, da sta to le letali. Daj malo bolje opazuj ob 0:52 ter 1:40
RazzorX ::
radiculus je izjavil:
+1
Danes je očitno že vsaka stvar na nebu UFO, kaj bo šele leta 2012. Pamet v roke!
clancy ::
Trenutno je res obsedno stanje z raznimi NLP-ji, Elenini, konci sveta...
Vsaka malo bolj nenavadna stvar je že lahko nlp, največ so pa zato krivi mediji.
Ne mine teden ko se na 24kur vsaj enkrat nebi pisalo o kakih izvenzemeljskih zadevah.
http://24ur.com/ekskluziv/zanimivosti/s...
guest #44 ::
And the UFO nutjobs got owned again...but will they ever learn? No fucking way!
carota ::
NLP pomeni "neidentificirano leteče plovilo". Torej če ne veš za kaj gre, je to NLP.
NLP pa ne pomeni "nezemeljsko leteče plovilo, ki je prišlo iz daljnega vesolja na Zemljo, da bi Damjana Murka prosili za avtogram na svojo zeleno rit".
guest #44 ::
carota je izjavil:
In theory...v praksi pa že masturbirajo na misel novih overlordov iz planeta Xansx!
Fantazija naj ostane v risankah, pravljicah, filmih, glasbi, video igricah,...
RazzorX ::
Če bi šlo vsaj v večini res za nepojasnjene ali zelo redke (naravne) pojave, bi te tepce še mogoče razumel. Ampak danes je to vsako letalo, helikopter, naravni pojav itd., ki ga mimoidoči vidi na nebu. Da ne omenjam novice iz pred nekaj časa na 24ur, ki je govorila o vesoljskih ladjah, ki se približujejo zemlji na najbolj neumni osnovi kar sem jih kdaj videl (na napaki na leči teleskopa, katerih je še ogromno). Folk so pa po večini ovce in verjamejo vsaki neumnosti, ki jih pišejo mediji.
radiculus ::
carota je izjavil:
Neznanje ne upraviči neumnosti.
enjst ::
clancy je izjavil:
Odgovoril sem ti kot se mi je zdelo najpametneje. Na tistem linku ki si ga dal ni besedila, video je pa vsaj pri meni "mute", tako da... vsekakor je razumneje pričakovati da je CNN imel namen gledalce seznaniti z ogromnim (ampak res ogromnim) oblakom prahu, kot pa z nekimi svetlimi lisami na posnetku o ogromnem :) oblaku prahu.
Sicer pa tisto na začetku videa kar naj bosta UFO-ta, samo potem naj bosta UFO-ta tudi tisto dvoje spodaj od 02:08 pa do konca posnetka (premika se nekje od sredine slike (v višini spodnjega dela oblaka) proti desni).
  • spremenilo: enjst ()
NLP-neznani leteči predmeti !!??
387331 (4615) nightrage
Moon, hoax or real? (strani: 1 2 3 4 )
16225949 (22971) Loocas
Poročila FBI o strmoglavljenih NLP
418683 (6951) petrus
NLP 30.06.2009 nad Slovenijo? (strani: 1 2 )
939676 (7252) Gandalfar
UFO tehnologija (strani: 1 2 3 4 5 )
20220164 (15454) dukenukem
