Whitler
Whitler
2
3
andrej ::
a) da - 180 dani.
b) za OC ne vem, ker ne OC, drugace pa je zadeva zlo stabilna - tako kot w2k.
c) n/a.
Jebiveter ::
3) n/a kot ne bo mogoce, ali kot bomo videli?:|
Certainty of death. Small chance of success. What are we waiting for?
andrej ::
n/a kot ne bo me v portoroz torej ne morem povedat nic pametnega
666 ::
Admini pustite te teme to je za prebrati ker je v več delih za ANDREJA - prijetno branje
PS kaj misliš katera verzija je to
Interim Build 2428 is available for download
We are pleased to announce availability of Microsoft(R) Windows(R) “Codename” Whistler interim build 2428 for electronic download. We are excited to preview in build 2428 the new visual themes that will ship with this new version of Windows. These new visual themes are the result of an intensive research project on usability and represent a vibrant new look for Windows. This new Whistler theme results in increased usability and productivity in both home and business environments.
Microsoft has recently announced that the official product name for Whistler will be Windows xp. However the code name “Whistler” will continue to be used in the product code until after Beta 2. Whindows xp is the next release of the Windows operating system for both consumers and corporate users, based on Windows 2000 technology.
This build will NOT be made generally available on CD.
666 ::
RODUCT KEYS
Microsoft Windows Whistler requires a product key to complete installation. Each Technical Beta ID will be issued a unique product key for their use in testing Windows Whistler. If you have not yet gotten your assigned product key, log on to http://windowsbeta.microsoft.com/suppor...
The product key previously issued to you should be used to install Whistler build 2428. This product key can be used to install all editions of Whistler (e.g. Personal, Professional, Server, and Advanced Server).
This product key is assigned to you and should be used by you only (or only your designated representatives if you are a corporate site). Your product key is a representation of your Technical Beta privileges. You may lose your Technical Beta privileges if your product key is published on an Internet site or otherwise becomes publicly available.
Dos and Don’ts about Product Keys:
Do save your product key in a safe place.
Do be responsible for the security of your assigned product key.
Do use the same product key when upgrading to a newer Whistler build.
Don’t share your Product Keys with others (except designated representatives in corporate testing situations).
WINDOWS PRODUCT ACTIVATION
Microsoft requests that you activate your installations of the operating system so that we may obtain adequate testing of the functionality. For testing purposes in build 2428, there is a registry key that will disable activation. If you are unable to activate build 2428 (as may be the cases in countries outside of the US for machines that do not have an Internet connection), you may use this to prevent activation. We ask that you avoid using this except in an emergency and that you inform us of your need to use it, so that we can improve product activation. This key will not be available in future builds, including Beta 2.
666 ::
The registry key is: “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Activation Required"
Activation can be accomplished via two different connection methods: Internet and telephone. The Customer service center supporting telephone activations for the US and Canada is currently operational. If you are not within the US or Canada, Microsoft recommends that you only install build 2428 on a machine that has Internet connectivity. Customer service centers supporting telephone activations for other countries will be available with Beta 2.
You may install Whistler on as many PCs as your End User License Agreement (EULA) allows. Please see your EULA for exact details.
For beta, the grace period by which you must activate is set to 14 days. For RTM, it will be 30 days as previously stated.
Please use the “.beta.whistler.product-activation” newsgroup to post any problems or technical questions pertaining to product activation.
INTERIM BUILD
This is an interim build we are releasing for ongoing development efforts. Microsoft does not recommend that you install this build. This is an "external test release interim build" provided primarily for hardware and software developers to use in lab test environments to verify recent code fixes and application and device compatibility with the upcoming Beta 2 release. If your connection to the Internet is such that you can download a build of this size, you are welcome to download, install and report any critical problems to us as soon as possible. However, this release is interim developmental code between standard release milestones. As such, much work is in-progress and many features may not be fully functional. In addition, this release has not been fully tested to the same level as a full external beta release.
666 ::
This build may not be as stable or reliable as a beta milestone release. It may contain fixes and improvements in some areas while it may have new problems in other areas that we will address prior to Beta 2. You are welcome to install and try this build at your own risk, recognizing these limitations. This build may in fact work better in some cases for a limited set of beta users.
If you have dedicated test machines, we encourage you to try this build out. If you do have the opportunity to download and install this build, please use the regular bug reporting and newsgroups to provide us with feedback and issues as soon as possible so that we have the opportunity to address key new issues prior to the broader Beta 2 release. Also, please complete an install survey for this build once you have installed it. (http://windowsbeta.microsoft.com/Survey...
You are not required to download or install this build as a part of the Whistler beta test. Interim builds are provided on an as-is basis for hardware and software developers, and for those beta testers that are interested in interim build updates.
Special notes on this release:
This release is not Beta 2. Most of the artwork and help files in the product have already been updated in preparation for Beta 2, but again, this is not Beta 2.
This build will not be available on CD. The download files are only available as CD image files (.ISO)
You can:
Use many third-party CD burning applications to burn this as a CD (refer to the individual product documentation on how to do this)
Use our VCD program to "mount" the CD image as virtual CDROM
See the VCD quick start at
http://windowsbeta.microsoft.com/docume...
Use a third party program to extract the contents of the \i386 directory to a local hard drive and run setup from there.
This release will initially be available in Personal and Professional versions only. We will alsobe releasing interim builds of Advanced Server within the next week.
666 ::
BEFORE YOU BEGIN
Please note this release is provided in an effort to facilitate your development and test initiatives only. As this is a limited interim release, it is provided as is, and unsupported except via online beta newsgroups. We recommend that you install this build on a test machine at your own risk. This build will expire 180 days after initial installation is complete.
**IMPORTANT: Upgrading Previous Whistler Builds
Do not use this build to upgrade any previous Whistler builds. If you upgrade over a previous Whistler build, a number of features and applications may not work correctly. However, you may upgrade Windows 9x, Windows Millennium Edition, Windows NT Version 4.0 and Windows 2000, or you may perform a clean installation.
LICENSE CONDITIONS
Review the online pre-release license agreements carefully before proceeding with the installation of this build. By installing this release, you agree to the terms and conditions of these agreements. As a reminder, all pre-release licenses expire when the product becomes commercially available.
The full CD image *.iso files for download from this location include:
Windows Whistler Personal Build 2428
Windows Whistler Professional Build 2428
Coming soon (in the next few days)
Windows Driver Development Kit Build 2428
Platform SDK Build 2428
Windows Customer Support Diagnostics Build 2428
Windows Whistler Advanced Server Build 2428
Using the WindowsBeta Build Download tool
Register with WindowsBeta at http://windowsbeta.microsoft.com/ by logging in with your Microsoft Passport.
If you do not have a Passport, you can get one for free by following the links from WindowsBeta. Once logged in with your Passport ID you will be prompted for your Microsoft BetaID.
After logging in with your BetaID, the contact information we have for you will be displayed. Please take a moment to verify this contact information and click “Submit”.
You are now registered to use WindowsBeta.
Follow the link under the “Downloads” menu to download the build.
Please note: You must use a Win32 based operating system (Windows 9x, Me, NT or 2000). We do not currently have clients for alternate operating systems. If you do not have access to one of the above operating systems to download the build, please email winbsite@microsoft.com for additional instructions.
Find the content you wish to download in the left hand content menu.
Click on the plus signs to expand the tree. Click on the links to display the related content.
Click on the file name to download
If this is the first time you have used the system on this computer, you will be prompted to accept the File Transfer Manager application which will quickly download and be install on your system before launching itself to download your requested content.
Please report issues or send feedback on the file transfer system to our WindowsBeta administration alias: winbsite@microsoft.com. We do not currently plan on making this build of Whistler available for download via FTP. An on-line version of this document may be found at http://windowsbeta.microsoft.com/howto....
666 ::
Thank you in advance for your participation.
Sincerely,
Microsoft Windows Whistler Product Team
releasenotes:
The following general release notes document a few of the issues you may hit installing or using build 2428. This is by no means a comprehensive list.
“Net use * \\server\some-folder” may fail on this build. Workaround is to do a "net use z: /d" to release the z: drive letter (even if it doesn't show as specifically used) or specify actual drive letter. This is fixed in newer builds.
If you have Office 10 prior to RC1 installed, ActiveSync may fail to work. Workaround is to upgrade your Office 10 to RC1 or newer.
If you have any of the following laptops, setup may hang. You should wait for the next interim build if you have one of these machines.
Toshiba Satellite 2210
Toshiba Portégé 7200
Compaq Armada M300
If you upgrade from Windows 2000 preinstalled SONY VAIO laptops, you will lose functionality of SONY utilities. We are working on fixes for future build. You will regain those features back, once we have fix in place.
If you have an error message during setup about a failure to register eventcls.dll, you should try unplugging your network cable and rerunning setup. We have seen this with machines directly connected to the Internet (DSL and Cable) during setup. This has been fixed in newer builds.
For ia64 users only:
If you dual-boot your Itanium with multiple copies of Whistler, you must upgrade your primary partition with a build >= 2428 first. Do this before attempting to install 2428 IDW to the second partition. If you try to install into the second partition before upgrading the primary partition, setup will fail to boot into text mode setup.
No andrej kaj je to
>:D
andrej ::
kot je ze povedano je to interim build 2428. To je pre-beta 2 verzija... v bistvu zadnji build poslan beta testerjem...
Eno vprasanje, kje si dobil to besedilo?
Loki ::
A ta build bo zadnji?
Kaj pa potem? Bodo odstranjevali dobljene hrosce in se propravljali za uradno izdajo?
I left my wallet in El Segundo
andrej ::
kako mislis zadnji build? To final je se zelo zelo dalec.
Drugace pa ze zdaj popravljajo hrosce.:D Cisto zares, pa bodo pocasi koncali z dodajanjem novi featurjev. Pravzaprav je zadeva feature lock - zdaj se samo stvari do konca implementirajo in popravljajo hrosce.
Loki ::
OK zdej pa ne razumem vec.
Poslal sem e-mail na M$ za beta test, kot subject sem napisal Whistler in izpolnil vsa polja (kot firmo in state sem dal - , pri state pa se (outside US)), nazaj sem pa spet dobil enak e-mail naslov kot vedno prej - takole:
Thank you for your interest in testing a Microsoft product. This
auto-reply is to inform you that your request has been received. Due to
the volume of requests we receive, you will not receive a reply to your
request.
You may apply via e-mail to test and submit bugs for a specific
Microsoft product, but due to limited testing slots, we cannot guarantee
that you will be invited to participate. To guarantee consistent,
monthly access to Microsoft beta products, you may subscribe to the
TechNet Plus program. This program does not require that you provide....
andrej ::
ta reply je cisto obicajen. to pomeni, da so dobili tvoj mail. zdaj se tvoj mail routa na posebno adreso, kjer se nahaja ze stotine drugih ljudi, ki bi radi prisli not. potem pa MS izmed teh izbere nekaj ljudi, ce je potrebno. Nazadnje je bilo dovolj ljudi za whistlerja, zato trenutno ne rabijo nic novih ljudi. Ce pa bodo rabli pa bodo malo pogledali ta kup - takrat imas mogoce kaksno minimalno sanso...
Loki ::
No ja, zgleda, da bo treba cakat na official release in na beto blackcomba.
Kako je kaj z tistimi prosnjami o pocenitvi - a je blo dost folka...
andrej ::
roberto, ce res hoces whistlerja, potem pocakaj se kaksen mesec potem pa kupi CPP - za par 10 USD bos lahko dobil RC1.
Folka je blo dosti za studentske cene - bomo probali zrihtat...
zetko ::
Upam da bo res kej s pocentivami 8-)
zetko ::
A šenka kdo zadn build od XP-jev? 8-)
luni ::
anderj pa zakaj bi ga kupil, ce pa ga dobis od pirata.. enivej, kar Roberto hoce je po moje, da dobi na dom vse nove razlicice da se ne rabi zezat s pirati hehe
Artificial Intelligentia
Loki ::
Ja, to je to.
Ce te sprejmejo v Beta test, dobivas nove verzije na dom (na CD) in se ne jebas z pirati, ki imajo vecinoma ze zastarele verzije.
Pa tut, ce odkrijes kaksen bug (10, 10 na n), ga lahko mirne vesti prijavis, ne ad bi se ti bilo treba bati, da bo en dal policija portkala na dom.
Luni ce ga kupis (ga dobis alce drazje kot pri piratu) je se zmerej original.
Andrej a bo MS Slovenija to tut prodajal?
andrej ::
Za CPP Whistlerja ne vem, ce bo MS Slovenija to prodajal...
Drugace pa lahko tudi ce nimas Whistlerja legalno prijavis buge. Lahko enostavno uporabis kar ikono na desktopu, ali pa gres na windowsbeta.microsoft.com in se registriras. Sicer ne bos mogel nic downloadat bos pa lahko poslal kaj bugov. To je tudi eden izmed nacinov kako lahko prides v naslednjo beta.
Drugace pa vseh buildov ne dobis na CD-ju. CD-je posiljajo samo za "vecje" builde, kot so Beta 1, Beta 2, RC-ji, itd. Za t.i. external interim releases pa jih lahko samo downloadas z njihovega site-a. Res pa je, da so obicajno pirati par dni odzadaj, pa se hackat mores, itd...
luni: zakaj bi ga kupo. Prvic zato da mas originale - pri piratu nikdar ne ves kaj dobis. Ce ravno ne spremljas vsega potem se lahko zgodi, da dobis kaksen star build, pa se hackat mores... eni mamo raje bolj komot zadeve:D
zetko ::
Jebiga, enim so pač bl ušeč cenej zadeve :D
andrej ::
ceneje? najceneje v tem primeru je bit beta tester - mas vse zastonj. piratu moras vsaj prazen CD dat v najboljsem primeru.:D
zetko ::
par 10 usd useen ni zastonj :D
andrej ::
to sem mu povedal zato, ker ni v tehnicnem beta programu. roberto se je skusal prijavit, vendar za whistlerja vec ne sprejemajo novih. torej naslednja najcenejsa pot do legalne kopije je CPP program. seveda ni zastonj, ampak bolje to kot pa nic:D
zetko ::
Itaq. :D
Huey P ::
Windows "codename Whistler" se je uradno preimenoval v Windows XP. Menda bo v personal različici vdelana protipiratska zaščita. Tako da, ko boš hotel namestiti Win XP boš moral poklicati distributerja Microsofta za Slovenijo ali pa boš na netu pogledal in vtipkal neko šifro ali nekaj pa ti potem oni dajo šifro da boš lahko namestil Winse. To pa se zatekne pri menjavanju ključne strojne opreme. Recimo da boš manjal disk, potem pa se nakladanje šele začne.
V bistvu me samo ena stvar zanima: ALI SE BO DALO PIRATIZIRATI WINDOWS XP ???
andrej ::
o teh zadeva je ze blo veliko napisano. Ok, tukaj so dejstva:
- verzije, ki se bodo dale kupit navadnim smrtnikom bodo zascitene z WPA - torej bos mogo sistem aktivirat. Aktiviras ga lahko na dva nacina - telefonsko ali preko interneta. po instalaciji imas 30 dni casa da aktiviras. ce v tem casu ne aktiviras ne bos mogo nic delat - samo aktivacijski vizard se ti zazene.
- ko mas sistem enkrat instaliran ga lahko ponovno instaliras brez re-aktivacije. ce pa zamenjas vec hardvera (ne samo recimo mrezne) pa bos mogo reaktivirat. to storis tako, da poklicec MS in dobis novo cifro. Zal se natancno ne ve kaj bos lahko zamenjal brez ponovne re-aktivacije...
piratiziranje bo mozno, ker bodo obstajale tudi verzije brez WPA za stranke, ki kupijo vec licenc. predvidevam, da bodo piratizirali te verzije...
zetko ::
Hmm. Mislm da je blo s tem antipiratiziranjem preveč komplikacije. Sploh zarad menjave hardvera. Po mojem bi blo bolš če bi uvedl kkšn drug postopek aktivacije.
andrej ::
res je. to uporabnikom ne bo prineslo nic dobrega. prej bo vec tezav... drugace pa ne vidim, kako bi to drugace izvedli. strojni dongli so se slabsa resitev...
zetko ::
Jebiga.Pomojem so si s tem k so zaklenil OS nardil škodo tut seb. Če se nou dal več winsov kopirat bo dost ljudi slej al prej prešlo na drug OS, ker plačeval sigurn ne bojo. Pomojem je to dejanje idealno za razvoj drugih OS-ov predvsem Linuxa. Open source is the future! 8-)
Loki ::
Dvomim, da bo veliko podjetij izobrazevalo kader, kako se uporablja Linux.
Ce bo M$ ugotovil, da mu to zmanjsuje prodajo, se bo ze kaj drugega spomnil.
andrej ::
kaksnega velikega navala na Linux zaradi tega ne bo. Mogoce si bo MS nakopal se malo vec sovraznikov, ampak to vecinoma med ljudmi, ki zdaj tako ali tako niso placevali... ta zadeva je lahko PITA, vendar vecje mase ljudi ne bo MS zgubil...
Linux bi se moral se hitreje razvijat, pa Apple bi moral Mac OS X portirat na intel platformo. Potem bi videli se vecji skok. konkurenca je vsekakor vec kot dobrodosla...
zetko ::
Hmmm. Linux bi se moral hitreje razivjat. Koko to mislš? Poglej ti linux izpred dveh ket pa poglej linux zdaj. Kot dan in noč....
andrej ::
mislo sem bolj v splosnem razsirjanju med uporabniki. Linux je sicer rasto hitro, vendar bi lahko se hitreje. se vedno mu manjka pravih uporabnih programov za mnozice, zato vecjega navala se ni. recimo igre - gres v trgovino in mas samo wins igre. potem recimo razni izobrazevalni programi, itd. tukaj bi se dalo se veliko naredit. Sam dober OS ni dovolj za uspeh.
zetko ::
Seveda. Os se širi sam brez (predvsem) programov ti ne boš prišel nikamor. Drugi hendikep so pa seveda igre. Sicer je par "tapravih" (Quaki, Civilization CTP, UT) sam to še zdaleč ni tist kar m$jev OS ponuja 8-)
andrej ::
ma saj bo enkrat boljse...:)
zetko ::
To vsi pravjo :D:D:D
andrej ::
te bo ze res:D
Loki ::
Ko smo ze pr M$, a je kdo gledal 6.dan?
>:D
andrej ::
gledal ja, kar dober film... zanimiva zgodba - samo upam, da se nebo kaj takega kdaj meni zgodilo:D
zetko ::
Jst ga nism gledu. Kaj bla fora? >:D
PaJo ::
Klonirali so Swarzenegerja:D
Ne se preveč sekirat, rajši uživat:)
zetko ::
Kaj ma to veze z m$? >:D:D
DanKick ::
Use your imagination !!!
Loki ::
A se ne spomnis, takrat, ko je gledat TV na policij al ke je ze blo......pa k je povedal na TV, da je ameriska vlada prepovedala M$, da bi kupil eno manjso drzavo...;););)
zetko ::
Hehe. Gates hotu kkšn žmnjikistan kupt :D
Huey P ::
Če že o Bill Gatesu...
Njega so aretirali, ko je bil že mlad, ker je vozil prehitro ali nekaj. Pa so ga slikali za kartoteko pa se je režal:)
Sem že našel sliko...
..::DOOM III: The Legacy::..
zetko ::
To sliko sm že vidu ja :D Model čist s porši obseden baje >:D:D
andrej ::
res je, v mladih letih je veckrat vozo bistveno prehitro. Enkrat je celo prestal noc v zaporu, pa so ga za 20.000 USD spustili ce se ne motim...
2
3
Longhorn Beta 1 (strani: 1 2 )
6510772 (8254) andrej
WIN XP: RTM (strani: 1 2 3 4 )
Oddelek: Programska oprema
16213646 (11389) Tr0n
Norton Antivirus 2001 pod win XP ne dela??
61613 (1564) Nigga
Win XP beta 2 final
Oddelek: Operacijski sistemi
141776 (1460) Yohan del Sud
WinWhistler Beta2
412685 (2181) andrej
