Forum » Programska oprema » WIN XP: RTM
WIN XP: RTM
_Tejc_ ::
andrej: a tole kaj vela?
"WinXP's setupp.ini controls how the CD acts. IE is it an OEM version or retail? First, find your setupp.ini file in the i386 directory on your WinXP CD. Open it up, it'll look something like this:
ExtraData=707A667567736F696F697911AE7E05
Pid=55034000
The Pid value is what we're interested in. What's there now looks like a standard default. There are special numbers that determine if it's a retail, oem, or volume license edition. First, we break down that number into two parts. The first five digits determines how the CD will behave, ie is it a retail cd that lets you clean install or upgrade, or an oem cd that only lets you perform a clean install? The last three digits determines what CD key it will accept. You are able to mix and match these values. For example you could make a WinXP cd that acted like a retail cd, yet accepted OEM keys.
Now, for the actual values. Remember the first and last values are interchangable, but usually you'd keep them as a pair:
Retail = 51882 335
Volume License = 51883 270
OEM = 82503 OEM
So if you wanted a retail CD that took retail keys, the last line of your setupp.ini file would read:
Pid=51882335
And if you wanted a retail CD that took OEM keys, you'd use:
Pid=51882OEM "
Pid=55034000
Retail = 51882 335
OEM = 82503 OEM
Pid=51882335
Pid=51882OEM "
andrej ::
vse verzije bazirajo iz cisto iste kode. Celo sever verzije.
Cisto na koncu produkcije pa se produkti locijo. Z kompajlerskimi direktivami naredijo iz skupne osnove Pro, Home, etc.
Potem ima vsaka od teh verzij se svoje razlicice. Tako s preprosto zamenjavo nekaterih datotek naredijo Pro, Pro Evaluation, Pro OEM, Pro brez aktivacije (torej corporate),etc.
Enako velja za Home.
TrOn, se enkrat. Corporate NE obstaja. To je samo ljublkovalno ime za verzije, ki so brez aktivacije. Vzames Pro in potem odstranis modul, ki skrbi za aktivacijo. Na isti nacin si lahko predstavljas Home, kot Pro, ki so ji odvzeli dolocene zadeve.
Vse skupaj pa se zgodi ob kompajlanju...
andrej ::
tejc: glede na to, da to velja za w2k, XP pa uporabljajo w2k kodo potem bi reko da velja tudi za XP. Sam pa tega nisem preizkusal...
Nisem pa preprican, ce lahko kar tak spremenis eno verzijo, recimo OEM v Volume licensing, ki nima aktivacije. Po mojih podatkih VL ne samo, da jih ni treba aktivirat, ampak niti nimajo kode, ki poskrbi za aktivacijo... bi blo treba zadeve malo sprobat...
DIEUALL ::
na warezu sm zasledu windows xp RTM build 2600 pa me zanima če je ze to final verzija ker ce se ni si ne bom dol vlekel
P.s.
Andrej povej mi kako je s tem plz ?
P.s.
andrej ::
RTM je build 2600. Ampak vsak 2600 ni RTM. Zahvala gre warez stranem, ki so naredili pravo zmedo...
Tr0n ::
http://winxpnews.cjb.net/ za vec informacij. Sedaj je out ze 100% preverjena Home RTM verzija. Corp. build pa ima baje oznako 2600.6.
Tr0n ::
Yup, na strani, ki sem jo prej pastal ze lahko dobis crack za XP Pro Eval. verzijo, tako da zatem ne rabis vec aktivacije.
andrej ::
TrOn. There is no such thing as 2600.6. Vse RTM verzije so 2600. Brez kakrsnih koli oznak pa piko!
andrej ::
drugace pa ne smes vse verjet kar pise na tej strani. Dolocene zadeve sicer drzijo in presenetljivo imajo celo pravo sliko z beta strani, kjer se downloada XP-je, ampak vse kar gori pise ni res...
_Tejc_ ::
ja andrej zgleda da se niso cist prsli do dna WinXP .. ponoc bo zgleda moc dobit verzije OEM RTM ki ne bo zahtevala akt. kode in ne bo imela t.i. TIME BOMB :
andrej ::
G[e]c: vse so fake.
_Tejc_: OEM tak nimajo time bombe, aktivacijo pa bodo mele. Razen ce jo bodo hacknili...
Bolje bi blo dobit Volume Licensing verzije, ki so tak al tak brez modula za aktivacijo in brez bombe...
andrej ::
ce jim bo latalo sploh ni vprasanje, vprasanje je samo cas... hm, cudno, da se nena raje vrzejo na Volume licensing verzije...
Tr0n ::
Tudi to bo. Aja andrej, kje bos pa ti dobil svojo kopijo oz. katero bos uporabljal? Al si ze tako visoko, da dobivas finalne verzije zastonj?
Ahiles ::
Te slike je izi naredit svoji masini das ime MS pol pa posles enmu k ma en NT pogon (NT,w2k,XP) ukaz v commandpromtu (net send IP text) in mu potem tako izpise.
G[e]c ::
Sam men se zdijo pa tili winXP eno velko sranje, mogoce za luzerje k prvic vidjo raculanik mal bol fancy sam za drugo je pa tema vse neki bolj pocas dela, sej mogoce sm sam mal zivcen sam u bistvu mam raj win98se, kdaj je treba resetirat sam drugace pa bols delajo k XP.
ABX ::
Sej je vedno tako! Vsakič ko prešaltaš na nov sistem je vse bolj počasno, pač čudežev ni za pričakovat. Sej čez eno leto bomo vsi furali 1Ghz+ in 512rama+.
OrlyTM ::
Marija Pomagaj !!! (pa sm popolen ateist)
Vele GEC primerja XP-je z Win98SE in pravi, da bo raje ostal pri slednjih. Pa da so XP eno veliko fancy sranje za luzerje k prvič vidjo comp.
hmm
kako naj komentiram, da ne boš užaljen ... ah, raje ne bom !!!! Samo prosim, da se vzdržiš tako bednobednih komentarjev.
OrlyTM
hmm
OrlyTM
<b>Fear is in The Eye Of The Beholder. Don't let it be You!</b>
OrlyTM ::
seveda so, če pa nečeš, pa niso, se da vse izklopit !!! Mal jih probite preden jih pljuvate ...
OrlyTM
OrlyTM
DIEUALL ::
OrlyTM nekaj mi povej a je to pravi evalute al je kak fake
Windows.XP.Pro.2600.Evalute.Fixed.ISO- SiNiSTER.internal.release
thanx for answer
thanx for answer
OrlyTM ::
To pa iz imena fileta ni možno zvedt. Žal, sam se ubadam z istimi težavami. Res je na warez sceni prava zmeda.
OrlyTM
OrlyTM
hot-stuff ::
Ja jaz sedaj te tol dajem:Windows XP Home XP RTM,Fixed Repack ,SiNiSTER iNTERNAL Rel. protection:NONE,Sorry for the mixup with the other Home release. It turned
out we had been given an older pro release. Here is the
real iso. No crack is needed just use the key to install.
Zej nevem a so dobil novo verzijo res al so sam mal pocrackal prejsen relise pa sedaj dal kao tapravga. Kdo ve ce je dober te relise?
file je pa :usa_2600__x86fre.per_whistler.rari...
Huey P ::
Vi se tolk zajebavate s temi verzijami, ka ne veste, če je ta pravi RTM ali ne... sem rekel, da raje počakajte na 29. oktober
jaz grem spat...
jaz grem spat...
..::DOOM III: The Legacy::..
Matty ::
hot... sm dal dol pred nekaj dnevi isto HOME fajl, pa se ko sm nehal DL so gor ze uppal "repacked" release... tko da, jest se do nadaljnega vzdrzim downloadanja XPjev in bom pocakal da gre zmeda mimo...
Sicer pa, M$ je naredil super zadevo, ko je (hote ali nehote) izdal koncno verzijo z oznako 2600, ker sedaj se ne ve ali imas pravo verzijo ali ne... Vsaj do oktobra
Tr0n ::
Zato se je dobro prej malce pozanimat na IRCu. Amerkoti imajo itaq same T3, OC,.. linije, kar pomeni da si en ubogi ISO potegnejo dol v par minutah al pa se hitreje in lahko tako stestirajo zadevo :). Sinister release dela 100%, za druge pa ne vem. Verjetno cakajo na corp.
Ahiles ::
Here’s the deal with RTM
Build 2600.0 was leaked to the web last Saturday (18 August). This build was later (i.e. once XP went gold) declared as RTM. There were two new versions of this build compiled. One version is the evaluation version (which has been leaked and is available). The other version is the OEM Version. The following differences exist:
A. 2600 Build Leaked 18/8 – This build is beta software. As such it has a 180 day timebomb. It also has evaluation on desktop. You can use 2542 keys on this build. BX6HT-MDJKW-H2J4X-BX67W-xxxx
B. RTM Evaluation Build – This build is not beta software. It has a 120 day timebomb. It does not contain evaluation on desktop. CDWVP-GBJRG-PDJRG-Y6CMB-xxxx is the key for this build.
C. RTM OEM Version – This build has not been leaked. It has 30 day activation time, no timebomb. This is the version that will come installed on new computers produced by computer manufacturers. There is no estimated time for the arrival/leak of this build.
There are two cracks available for 2600 Evaluation version as well. The first removes the 120 day timebomb and allows you to use a 30 day key (the same key as for 2600 Leaked). The other replaces the 120 day timebomb with a 180 day. This also allows you to use a 60 day key - KR2X8-M8MGV-FQBRR-322YQ-xxxx. However, the first keeps all file versions at 2600, the second replaces 4 files with 2535 versions. Both of these cracks are PRE-INSTALL cracks.
Torej prave verzije se ni na netu to je vse neki skrekan in napol narejen zmixsan z starimi fajli itd. Zato tudi isonews ni objavu se nobenga. Treba j epocakat da pride prava verzija oem.
bzagozen ::
Jaz sem z Edonkey2000 potegnu dol 2600 verzijo (tisto, ki bi naj bila OK - ker je tam na voljo več drugih verzij), jo inštalirar in mislim, da je kar RTM. Na general lastnostih piše, da je Windows XP Professional Version 2002. Če koga zanima katera je ta verzija na Edonkey-u (usa_2600__x86fre.pro_whistler.iso)
www.alkoma.si
hot-stuff ::
Ma Matty sem dl repack verzijo in je isti bullshit..evolution copy pa se skoz mi tezi z registracijo mislm jaki repack ki pise da ni nobene protekcije pol pa vidm da je vse skupaj en drek ehh grem unnistal pa win2000 gor:)
G[e]c ::
Majo ja sam winsow sploh ni not. Kaj pa kdo kej ve kaj Plus vsebuje kej uporabnega al je bolj beda?
Ahiles ::
Isonews ponavad ne daje beta oz skrekanih stvari na stran so kdaj izjeme zaenkrat se winxp niso pravilno uzun to kar je na netu je vse al beta, eval, konbinacija raznih verzij, potem razni ckreki itd to zame niso final wisi in za isonews tud ko pa pride ksn oem al pa ksna druga verzija ki je potrjeno final brez ksnih "dodatkov" bo pa tud na isonews
Ahiles ::
Aja pluspack
[ Description ]
"the plus pack includes new themes, screensavers, and games..
for those who are tired of looking at the blue shit"
quote: Kame`Leon
That sums it up, prety much like he 95/98 Plus Addons
Great my keyboard is dieing....
Nekje na netu je bil en link ki opisuje bol natancno keri spili itd sam ne vem tocn kje sem bral.
[ Description ]
| » | Windows Update Control V4Oddelek: Operacijski sistemi | 1305 (1169) | Quickbeam |
| » | windows Xp - problemOddelek: Operacijski sistemi | 2864 (1881) | Maxtor |
| » | Microsoft Windows XP Corporate Ed.Oddelek: Programska oprema | 2307 (1868) | Tr0n |
| » | Microsoft začel pošiljati WinXP OEM partnerjemOddelek: Novice / Ostala programska oprema | 2747 (2747) | AvAkI |
| » | win XP wallpapersOddelek: Programska oprema | 1951 (1755) | lukaf101 |
