Forum » Strojna oprema » Nakup LCD zaslona
Nakup LCD zaslona
slowfly2011 ::
Pozdravljeni,
namen imam kupiti LCD zaslon, za priklop na prenosnik. Prenosnik ima grafično kartico Geforce Go 7300 in samo VGA izhod. Kakšna je lahko maksimalna resolucija zaslona, ki jo grafična kartica podpira. Gledal sem 24" LCD zaslone, ki imajo resolucijo 1920 x 1080 - a bi to šlo?
firefox2142 ::
Jaz imam 24" monitor znamke AOC ki ima vga prikluček in resolucijo 1920x1080.
Sem pa našel nekoga ki ima podoben problem in to so mu odgovorili:
Quote:
High-Quality Scaling
Allows for upscaling of a low-resolution video to HDTV resolutions (up to 1080), while maintaining a clear, clean image. Also allows for downscaling videos, including high-definition, without experiencing any annoying flicker, while preserving image detail.
taken from http://www.nvidia.com/page/7300_feature...
Although the 7300 is capable of outputting the said resolution, you are using a card on the laptop. Although the 7300 is able, there is not any type of I/O that will (certainly) guarantee it will output 1920x1080 through VGA. You will probably be able to get 1360x768 through VGA, but 1920x1080 I doubt.
Gimme a few and I will try to hook up my laptop to my HDTV.
EDIT- just tested it with my laptop. I was only able to get up to 1600x1200 (horribly scaled). Other resolution options were 1360x768, 1280x720 and lower. The 720p didn't look too bad, but it won't be 1080.
- spremenil: firefox2142 ()
| » | VGA na HDMI? (strani: 1 2 )Oddelek: Zvok in slika | 30539 (17535) | KTr1sk |
| » | prenosnik za igre do 1200EOddelek: Kaj kupiti | 9503 (8875) | iloveboobz |
| » | Povezava grafične z HDMI ter LCD TVOddelek: Zvok in slika | 3826 (1824) | ales1977 |
| » | Full HD TV (strani: 1 2 3 4 … 16 17 18 19 )Oddelek: Zvok in slika | 124812 (41799) | Kovalchuk |
| » | Philips 32PFL5322 - Kdo jo ima in kak deluje DVI>hdmiOddelek: Kaj kupiti | 4737 (3822) | TornadoTDi |
