Forum » Konzole » Red Dead Roleplay(PS3)
Dr_Andy ::
Živjo!
Z enim britancem na forumu reddead.net ustvarjava roleplay(kot nekakšen second life,kjer si svojemu liku izbereš delo,kupuješ hiše,ropaš banke...skratka kot v realnem življenju. Vsi ste lepo vabljeni,mikrofon ni potreben,potrebno je le minimalno znanje angleščine. Poglejte si moj opis na http://www.reddead.net/forums/thread-re...
Dr_Andy ::
ti ropaš banke v realnem življenju? :P
ne,dal sem primer
hahahahaha, ti bi v rdr igral wannabe simse? =)
Neke vrste. Preberi opis,zna bit zanimivo.
- spremenil: Dr_Andy ()
sejmon ::
Im locking this for the following reason:
You clearly stole everything I put in my thread word for word, including the title, and published it as your own. There would be absolutely no problem if you decided to make your own RP and used YOUR creativity but instead, you chose to use someone elses. This is simply unacceptable and anyone else would be just as upset as I am. Dont do it again or you will face some sort of ban.
CLOSED
Dr_Andy, same bedarije delaš po forumih...mal heca
| » | Še en osebnostni test?Oddelek: Loža | 5960 (4768) | piromanček |
| » | Okradli prvo bitcoinsko banko FlexcoinOddelek: Novice / Kriptovalute | 11575 (8502) | FlyingBee |
| » | Bančništvo že v osnovi nepošteno? (strani: 1 2 )Oddelek: Problemi človeštva | 22907 (19205) | Iatromantis |
| » | Protivideonadzorna sončna očalaOddelek: Novice / Zasebnost | 7522 (5606) | edge540 |
