Ali Xabre goljufa?
Ali Xabre goljufa?
TheJack ::
Zanimiv članek (test) na to temo na Tech Reportu. Izgleda, da se gre SiS podobne igrice (oz. še hujše) kot se jih je šel ATi nekaj časa nazaj...
Še humorna slika z dotičnega testa (ki sicer nima nič opraviti z zgoraj omenjenim goljufanjem):
It doesn't really matter that there are no heat sinks on the rear RAM chips because the heat sink doesn't actually make physical contact with memory chips on the front of the card. The gap between the heat sink and memory chips isn't a result of a sloppy heat sink installation; the top of the GPU and memory chips simply don't line up in a manner that lets the flat base of the heat sink make contact with both.
Je 57C na idle prevroče za AMD phenoma mobile?
9924 (817) adinfinito
Iščem thermalright slk 900a
211972 (1688) burkiburke
Tisto, kar je ostalo od obširne najave procesorjev GF4
Oddelek: Novice / Procesorji
73244 (3244) Alec999
Nasvet
93816 (3646) Huey P
