Forum » Hlajenje in modifikacije » Iščem thermalright slk 900a
Eddy ::
Kako medena?
Neboš poj naštimov vodnega?
Veš prej ali slej boš prišel, samo od časa je pa odvisno kok boš denarja zmetov za zračno še prej
www.ekwaterblocks.com
mihec87 ::
eddy@Veš prej ali slej boš prišel, samo od časa je pa odvisno kok boš denarja zmetov za zračno še prej
hehe tole kr drzi.
hehe tole kr drzi.
ČIP 008 ::
Ja če ima preveč denarja potem lahko gre na vodno. Medena kupi ti raje SP97 pa imaš mir tudi v bodoče za vse procesorje.
MEDENA ::
ja sam če pogledaš SP97 je skoraj 15K , en dober vent 4-5K ..kar znese 20K...eddy imam prav....saj dobiš za slabih 30K njegov BASIC komplet v akciji ...
MEDENA ::
evo dons sem ga dobil ...da vidimo to čudo..
sam kako posebno navodilo za inštalacijo ?
"Steps of Installation for SLK-700 / SLK-800A / SLK-900A
Place CPU onto the socket and have the lever arm fixed.
Stick the four static free rubber pads onto the heat sink base (note the four punch holes.) Since the narrow heat sink base will go between the black rubber stands on processor, the cutomized circular pads will serve as rubber stands on AMD processors.
Put heat sink on to the top of the CPU die/socket. (Note the step in the heat sink base. The step side goes over the Socket cam box. The other side goes over the lever arm.)
Clip in the heat sink clip to make the three holes fit in the lugs of the socket. (Use a flat bed screwdriver) First attach lever arm side, then the cam box side.
Specs of screw driver: SL - 3/16" X6"
Mount the fan onto the heat sink.First clip the top fan hook into one side of holes of the fan. Insert the other end of hook into a hole on the fins at one side of the heat sink. (For 80x80x38mm fans, use the hole marked with ?8? for 80x80x25mm fans, use the one marked with ?5?Then do the same thing on the other side complete installation of the fan clip setting. (As shown in the figure, fan at top, heat sink at bottom; fan clips on two sides.) Information subject to change without notice. Always consult authorized resellers for technical assistance. "
kaj tam piše lever arm side ? kao leva stran ? ja pa bom vedel kera je leva ?
cam box side ? w00t ? :p
aja v paketu baje manjka
Two black rubber strips, also provided in the package, will be installed on the fan edges that will make contact with the heatsink.
kaj je to kaj nujnega ?
- spremenil: MEDENA ()
MEDENA ::
thanks sej sem dojel kera je leva stran....itak ima dno tako narejeno...sam pizda je težak cca 550g....upam da bo plata zdržala :P
kaj tista tubica za ?
tube of silicon thermal goop
kajzer ::
Tista tuba je zobne pasta, če ne veš. LOL Ti kr tko, brez tiste tube namesti gor hladilnik, pol pa povej če se pri temp kej pozna. Seveda v prid silentboost-a.
Ne vem a se delaš budalo, al res ne veš kaj je?!? (ne vzet resno tale stavek) To je termalna pasta, pi pripomore k boljšemu odvajanju toplote s proca na hladilnik. Namažeš jo zelo na tanko pa proc in nato namestiš gor 550g hladilnik.
Keyser Soze ::
Moraš malo bolj natančno prebrat navodila, pa bo. Če ne drugega imaš lever omenjen že na začetku, kjer ti piše, da ga moraš fiksirat. Pa pomaga tud slovar včasih.
Kaj le bi bila ena bela tuba poleg hladilnika?
Sekundni pomoje že ne. Morda pa termalna pasta(thermal goop). Pa rajši uporabi kakšnega ASilverja. Sej dost razlike ne bo. Sam mal bolj se boš matral.
Tisti črni trakci pa pomoje nimajo druge funkcije kot da blažijo vibracije med ventilatorjem ter hladilnikom samim. Tako da isto sranje. če sam doma izrežeš dva podolgovata koščka - trakca gume in jih nalepiš na ventilator, tam kjer se stika z hladilnikom. Sploh ni big deal.
MEDENA ::
čudno....a morata tiste 2 srebrni palčki ful na "knap" it čez ventilator al kako ? nikakor mi ne uspe...krneki...
Eddy ::
Ne medena, ni kr nekej.
Tist more jet čist na knap, ker drugače ti bo ventilator ropotal, in v najspabšem primeru dol padu...
PS: Očitno si se odloču za dražjo varianto
| » | Je 57C na idle prevroče za AMD phenoma mobile?Oddelek: Pomoč in nasveti | 915 (808) | adinfinito |
| » | SLK-947U, SLK-900U, SLK-900A-Kateri je boljši??Oddelek: Hlajenje in modifikacije | 1515 (1278) | boštjan |
| » | Neverodostojne straniOddelek: Omrežja in internet | 1753 (1684) | Tarzan |
| » | SLK-900: nov kralj?Oddelek: Strojna oprema | 1284 (1225) | morphling1 |
| » | Ideja za hardcore modifikacijo oz. Ko ima človek preveč časa!Oddelek: Navijanje | 3295 (3084) | TribesMan |
