Nakup pohodnih čevljev
12 / 18
theStranger ::
Okapi je izjavil:
theStranger je izjavil:
Okapi je izjavil:
Goretex je membrana ki naj bi bila neprepustna,
Samo dokler sredstvo za odbijanje vode na zunanji strani deluje.
Part of caring for your product is maintaining the Durable Water Repellent (DWR). GORE- TEX fabrics have an ultra-thin treatment called DWR, a durable water repellent polymer that is applied to the outermost fabric layer. DWR penetrates the fibers and lowers the surface tension of the fabric, causing water to bead up and roll off this outer layer of fabric, instead of being absorbed. DWR is necessary for the product to perform as intended, but it’s not permanent. Regular wear and tear, plus exposure to dirt, detergents, insect repellent, and other impurities can shorten its lifespan. The good news is that following our care instructions can often solve this problem and when necessary, reapplying DWR is easy. However, an old or heavily worn garment may no longer bead water, even after proper care and a DWR treatment, indicating that the product has reached the end of useful life.
Poglej ni res.
Potem se zmeni s samim Gore-texom, ker to, kar sem jaz citiral, je iz uradnih Gore-texovih navodil za vzdrževanje.
Slikca od nikwax produkta ni uradna gore-tex stran
In? Prilepil sem navodila iz www.gore-tex.co.uk
theStranger ::
How It Works
Our products are vigorously tested for reliable protection even in demanding conditions. The GORE-TEX membrane at the heart of our technologies contains pores smaller than a water droplet, but larger than a water vapor molecule. So rain and snow can't get in, but sweat can get out. Whatever happens, you can trust that your original GORE-TEX products will keep you dry.
In ravno v tem je pomen impregnacije. Če voda na zunanji strani ne ostane v obliki kapljic, se "razleze" po celi površini (jo omoči, kot se reče) in velikost molekul vode ni nič drugačna kot tistih na notranji strani. Ko se impregnacija izrabi, voda na zunanji strani ne ostaja več v obliki kapljic (ki jih skupaj drži površinska napetost), omoči material in začne pronicati skozi majhne pore v notranjost.
theStranger ::
Poglej, membrana kot taka se oglašuje kot vodoodporna tudi brez DWR zaščite. DWR je le dodaten zaščtni sloj, vendar brez more biti gore-tex ali kateri koli tex vodoodporen, saj DWR nudi le vodoodbojnost in ne vodo odpornost.
Gore tex.
Torej goretex se oglašpuje kot vodoodporen. DWR zaščite so vodoodobjen in le dodaten zašlitni sloj..mah ne da se mi vec. V glavnem, meni so do sedaj vsi texi popustili, pa znam skrbeti za cevlje, navadne usnjene namažem, z membranami našpricam s sprejom...
Xserces ::
Sam imam te Link pa zaenkrat še niso premočili. Stari so cca 3-4 leta. Jih gonim večino časa nad 2000m v snegu in ledu. Imel pa sem tudi od Alpine Lhotse z simpatexom ki mi je v 80% premočil. Za poleti pa imam od Alpine Tibet V. In isto simpatex premoči če hodim po južnem snegu.
  • spremenil: Xserces ()
theStranger ::
Xserces je izjavil:
Hmm ce ti po toliko letih se vedno drži bi bilo mogoce pametno da na svojim uveljavim garancijo, ker jaz sem imel po kratkem sprehodu po vlažni travi povsem mokre nogavice :/
Gore tex.
Kako se kaj oglašuje, in kako kdo razume oglaševanje, je druga stvar. Ampak mimo fizike ni mogoče iti, in če gre vlaga lahko iz čevlja ven, gre lahko tudi noter.
Poleg tega mi ni jasno, kaj te muči - saj si sam ugotovil, da vsi "texi" slej ko prej spustijo. Si se mogoče kdaj vprašal, zakaj potapljaške opreme ne delajo iz goretexa? Ali ribiških škornjev?
Xserces ::
In tebi se zdi to ok? :)) Gore tex mora drzat kar nekaj casa predn spusti... Še sympatex ki je za moje pojme slabši proti vodi drži par ur v snegu... Te Salewa so bile v južnem snegu tudi po več k 10 ur in niso nikoli spustile vode not.
theStranger ::
Xserces je izjavil:
Sej to ne zdi se mi ok, predvsem ker niso bilo ravno poceni cevlji...:)
k4vz0024 ::
Iz katere države prihajajo oz. izdelujejo edino kvalitetne Salomon pohodni čevlji?
k4vz0024 ::
Kateri zimski pohodni čevlji z Gora-Tex-om so kvalitetni od Salomona in jih prodajajo pri nas?
Pri tem mislim na nepremočljivost membrane, dobrega blaženja in ne drsnega podplata.
krneki0001 ::
Nobeni. Tukaj jih greš pomerit, da vidiš kako velike moraš vzet, potem jih pa naročiš iz tujine.
k4vz0024 ::
Kdo je dobavitelj čevljev Salomon za Slovenijo?
janezvalva ::
krneki0001 je izjavil:
in kje iz tujine se priporoča to naročiti? amazon? bike24? drugo?
matmel ::
Trenutno imam pohodne čevlje brez goretexa, ampak imam že ob manjši rosi, večji vlagi mokri nogavici, tako, da bom v prihodnje verjetno kupil čevlje z goretexom. Trenutno imam La sportivine pohodne čelje, evidendtno so narejene za ožje stopalo, tako, da sem jih po 2 sezonah dobesedno "raztrgal" z obeh strani čevlje, imam namreč širše stopalo. Morda kdo ve, so kateri proizvajalec dela nekoliko širši čevelj, Salomon? Mizuno ...?
kuglvinkl ::
Menda Mamut.
seminal ::
Scarpa :) isto kot la sportiva samo širša
krneki0001 ::
matmel je izjavil:
Če so čevlji brez goretexa, gre voda tudi ven, če že not pride. Pri goretexu pa notzri ostane. :))
matmel je izjavil:
Vsi proizvajalci delajo gojzarje več širin. Problem so uvozniki pri nas, ki uvozijo 3 različne modele in je to vse kar lahko dobiš. Drugač pa glej oznake čevljev.
Lowa ima oznako za wide WXL (lowa tibet gtx wxl), Merrell ima oznako za wide WTPF (merrell moab WTPF).
gregc1 ::
Tsunamii je izjavil:
Super! Hvala ti.
Mi lahko das link, kje si jih kupil..lahko tudi na zasebca, če je sporno.
Ter..si kupil 1 stevilko vecjo..? JAz vem da sem za 5.11 XPRT kupil 1.5 stevilko večje in je bilo prav. Zal jih ne delajo več. Drugače bi si iste kupil in bi brez problema naredil teh bogih 800km. Slednji so mi zdrzali 8 let orenk podvigov. So pa malo nizji bilo od sveh teh novih.. Zato verjetno kaj nizjega.. ?
http://www.group22.si/obutev/zephyr-gtx...
Na strani imajo napačno ceno. Cena 195€ je za 8" višino. 6", ki so na sliki, pa stanejo 160€. Bom pa zelo verjetno še 8" kupil.
Zakaj so pa tele tok cenej?
https://www.amazon.de/gp/product/B01JLM...
krneki0001 ::
Zato ker je rjav in očitno rjavih nihče ne kupuje, pa so znižal ceno. Če klikneš na drugo barvo je pa cena 207EUR.
Pa noben proizvajalec tega artikla ne pošilja v slovenijo.
  • predlagal izbris: madviper ()
gregc1 ::
https://www.hardloop.de/artikel/11114-l...
kaj pa tale? sprasujem ce je slucajno kasna razlika med njimi. ne zivim v sloveniji.
krneki0001 ::
Razlika je samo v barvi. Vsi so na isti način narejeni.
gregc1 ::
ok hvala. ce rabis ti lahk jaz poslem v slo. nekih 10 EUR te kosta postnina.... mogoce manj
Mi lahko se kasn dobr ruzak priporocis tam do 40l?
  • spremenil: gregc1 ()
Tsunamii ::
Spet jaz :D
Torej rad bi si kupil nizko obutev. Predvsem za daljse proge. Zdaj imam namen s frendom na 64km etapo po medvedovih stopinjah. Pred tem redno hodimo..in sem ze unicil staro obutev.
Kasneje bi s takimi sel drugo leto na El Camino.
Torej gledam recimo Salamon X Ultra 3 GTX (nasel za 100EUR), Salawela MS WILDFIREE GTX (120EUR).. Eni pohvalijo Keen TARGHEE III WP (100EUR) ..
Zanimivi so mi tudi Merrell MAIPO WP ( 80EUR) sam ti vidijo malo rose je veselica..ceprav sem tak podoben model imel 7 let nazaj in sem totalno uzival v njih dokler niso razpadli.
No..ta vikend moram kupit in sem rekel ajd da vidim kaj porečete se vi!
  • spremenil: Tsunamii ()
tomy5 ::
ADIDAS TERREX SWIFT R2 GTX, 2 leti v njih že vse Slo gore tudi najvišje, odkar imam te sem razen pozimi pospravil gojzarje.
Udobni ker so širši kot Salomon.
Tsunamii ::
tomy5 je izjavil:
ooo super. Tega model nisem opazil. Bom ob priliki ko grem v Intersport probal. Upam, da imajo vse te modele na zalogi..? JE kaksen vecji v Ljubljani ?
mailer ::
Če greš po medvedovih stopinjah priporočam 2 para obutve, obvezne ene vnošene, če te slučajno prve začnejo žulit. Mene sicer mika polovična tura. Če bo takrat dež ali kakšen dan prej bo zagotovo zjutraj rosa in potrebuješ nekaj nepremočljivega.
krneki0001 ::
tomy5 je izjavil:
Na tvojem mestu bi se zapeljal v celovec in šel v adidas outlet, ker so tam konkretno cenejši. Jaz sem dal za terrex R2 GTX celih 63€ v outletu.
Te sem vzel:
https://www.bigtree.eu/adidas-terrex-sw...
chort ::
tomy5 je izjavil:
Še dve varianti, polvisoki Garmont Vetta GTX in nizki Garmont Dragontail GTX. Malo trši podplat, nepremočljivi, udobni. Dragontaile imam že par let, Vetta pa eno leto in so vrhunski. Na nogah jih imam od jeseni do pomladi vsak dan.
Tsunamii ::
tomy5 je izjavil:
Na tvojem mestu bi se zapeljal v celovec in šel v adidas outlet, ker so tam konkretno cenejši. Jaz sem dal za terrex R2 GTX celih 63EUR v outletu.
Te sem vzel:
Hvala za nasvet glede nakupa. Celovec mi je predalec. Sem iz obalnega dela. KAr vidim jih ima edino INTERSPORT po 98EUR. ME pa kar mikajo. KAko se obnese podplat? Ker jaz samo na VIBRAM stavim..
chort je izjavil:
tomy5 je izjavil:
Za ta 2 modela bom se cekiral. Tnx.
techno ::
Tudi jaz imam Adidasove, zelo zadovoljen!
SmeskoSnezak ::
Kje pa bi clovek najdel Brooks na izbiro v Slo ali okolici? Sprobalo bi se vec modelov...
@ Pusti soncu v srce... @
AnjaNja ::
Addidas terrex so kar ozki. Jaz sem sicer pred 3 leti vzela ženski model, nizke in sem se na polovici razmočenega gozda hotla sezut in it bosa. Jaz se križam vsakič, ko moram kupit čevlje, pa naj bodo tekaški, pohodni, za sprehode s psom, lepi za v službo (tam je šele problem). Groza! Od pohodnih sem v intersportu in hervisu preizkusila vsaj 20 parov, predno sem pristala na Merrel In zdaj imam MAIPO, zračne, lahke tudi za vsakdanje sprehode s psom, za po hribih/gorah pa MOAB 2 ene z GTX in ene VENT za tople, suhe dni.
Pri nas imaš širše Merrel, tudi kak Planikin se zna najt da ustreza, ostalih niti ne poznam toliko oz. si jih nisem zapomnila. Sprobavaj jih v pohodnih nogavicah, pa morda celo spodaj navadne nogavice, ker meni recimo po več urah hoje noga, prsti malo zatečejo in je bolje, če je vsaj kak mm viška, da ni že v štartu tesno.
Tsunamii ::
AnjaNja je izjavil:
Vem groza izbrat nekaj primernega. Merrell WATERPRO MAIPO sem imel pred ufa leti..7 al 8. ZElo zadovoljen. So pa za samo suho.. Saj verjetno bom te kupil in se kaj bolj odpornega proti vlagi. Zdaj vsi priporocajo Addidaske terrex, ker naj bi bili sirsi ? Ti pravis da so ozki model pri tebi.
Bom pa ajde tudi te Merrelke Moab 2 GTX sprobal. Upam no da imajo vse te modele za probat kje :)) Pisovka..problem je ker to ni zdaj 20€ ..ampak preko 100€ za model. In nocem kupit nekaj, kar bom obzaloval prehitro. Je pa tak..da sele na daljsi rok vidis kaj in kako..
chort ::
Moje Dragontaile je za male denarje (~10e) uspešno razširil lokalni čevljar. Prej sem imel otiščance, zdej so kot copati.
Tsunamii ::
Ekola. Danes na celi obali dobil in sprobal Marrellke MOAB 2 GTX in Addidaske TERREX SWIFT R2 GTX. Merrellke so prevec mehke, ne nudijo dovolj opere. Bolj kot copat za lepe potke v katerih se nedvomno pocutis zelo udobno!
Addiaske zelo dobra opora v nogi, edino na prvi 'otip' mal trde-le to upam da mine. KAr se bojim da se v njih noga konkretno spoti? Naj to povejo tisti, kateri jih imajo. NA kratko..trenutno so mi favoritke Addidas. V njih naj bi prehodil teh 60km?..
Edin cena..pisovka je 140EUR! A so kje ceneje..ker jaz jih ne najdem. Magarik kaksna internet trgovina..ker v Celovec iz obale se mi ne splača !
Poravek: nasel za 112EUR ( sive barve...pac lepo vidna bo umazanija..)
AnjaNja ::
Ne, ne mine žal. Ker imajo utrjeno s tisto plastiko ob strani (ali kakršen koli material je že). Tako, da ostanejo trde. Ja, viš, jaz pa sem iskala/rabila mehko supergo zaradi stare poškodbe in so te Merrelke res prvi čevlji po dolgem času, ki me ne ožuli tudi po 7 urah hoje. Je pa še ena opcija Proalp-tudi po meri ti naredijo. So dragi (tam 200 eur), ampak jih imaš za 10 let. Ali pa, če vzameš usnjene (Planika recimo ima tudi širše modele). Usnje, če zanj redno skrbiš (premazi in to) ti ne bo spokalo, bo ostalo vodoodbojno in še mehki so, se bodo bolj prilagodili (gleženj, pete itd), ampak podplat mora štimat (širina, dolžina)!
Moje stopalo je v obliki plavutke skorajda, in najširši del stopala pri meni meri 10 cm od kosti palca, do kosti mezinca. In čeprav imam 40.5 povprečno številko...je križ navado najdit širino.
Spet prehiter enter. Kjer je možno vzemi ven vložek in če vložek ne ustreza širini/dolžini tvojih nog (v pohodnih nogavicah) ga odloži nazaj in si prihrani žulje in bolečine.
  • spremenilo: AnjaNja ()
Tsunamii ::
Pisovka dilema. Trenutno sem rezerviral Adidas terrex swift r2 gtx in Merrell WATERPRO MAIPO, ker so mi res lahkotni in zracni, da jih imam tudi za poletje za lahkotne ture.
Groot ::
Poglej še na spletno stran 21run.com za ceno (npr. Addidas Terrex so dosti cenejši, če jih še ujames v svoji številki).
Prav tako lahko preveriš še SportShoes in pa Wiggle.
  • spremenilo: Groot ()
Tsunamii ::
Ekola. Kupil Addidaske in ze pridno delam kilometrino.
Mnenje oz nasvet! Rad bi kupil neke res dobre nogavice..
KAj menite glede 1000 Mile 2 Season COOLMAX : https://1000mile.co.uk/Walking/1000-mil... ?
Ter ene visje pohodniske za 'gojzarje' bi rabil. KAj takega ? :https://www.ebay.de/itm/1000-Mile-Fusio...
Ter zadnja stvar..kaj uporabljate, da ne zasmradite prevec obutve..kaksen sprej ali prasek ?
tomy5 ::
Nič, samo redno preobuvaj nogavice in pa takoj posuši čevlje.
1x letno pa čevlje v stroj in na izi oprat.
Furbo ::
Xsocks, če že hočeš top shit nogavice.
Tsunamii ::
Furbo je izjavil:
Super ! >Hvala ti.
Gledam zdaj te X-socks TREKKING SILVER : https://www.intersport.si/x-socks-trekk... => ampak mi nisi jasne stevilke. Izberi veliksot 1-2-3-4 ?!! WTF ?!!
theStranger ::
Defenitivno merino. Jaz imam takšne
Tsunamii ::
o super! Ni prevec toplo da hodis ves dan v njih ? Jaz se zelo potim v noge. Drugace je super cena za merino!
theStranger ::
Za poletje imam sicer tele in mi niso pretople
Han ::
https://www.amazon.de/dp/B002P9DXU8
1 = 35-38
2 = 39-41
3 = 42-44
4 = 45-47
  • spremenil: Han ()
Tsunamii ::
Han je izjavil:
1 = 35-38
2 = 39-41
3 = 42-44
4 = 45-47
Han legenda si ! Hvala ti !
AnjaNja ::
Jaz sicer uporabljam puder za noge pred pohodi in včasih tudi v službo...Jih pa redno puščam zunaj na zraku. KO sem bila v bloku, sem jih nesla balkon, ko sem bila v študentu brez balkona, mi jih je pa uspelo zavezat skozi okno :D
12 / 18
Katere pohodne čevlje (strani: 1 2 3 4 )
15923368 (12045) WizzardOfOZ
Taktična (terenska) obutev (strani: 1 2 )
Oddelek: Šport
7612580 (7977) Okapi
Pohodni čevlji (strani: 1 2 )
Oddelek: Šport
5529327 (9322) JanezH
O gojzarjih (strani: 1 2 3 )
13529715 (24615) pegasus
