Forum » Pomoč in nasveti » core2duo in dual core
Zako ::
dualcore ni bil pravi dvojedrni procesor, mislim, da ni imel direktno 2 jedri v procesorju, pravtako dualcore nima VT in ima samo 1MB L2 cache.
http://www.tomshardware.co.uk/forum/pag...
"The Pentium Dual Core, which we found to be an excellence choice for overclockers on a low budget, is based on the popular Core 2 architecture. In fact, the processor cores are the same, but the CPU comes with only 1 MB L2 cache instead of 2 MB or even 4 MB. In addition, some features, such as Intel's Virtualization Technology (VT) are disabled. The result is a castrated Core 2 Duo processor, using the small cache size and limited to 1.6 to 2.0 GHz clock speed at FSB800 system speed."
Zako je zakon!!!
| » | Lenovo R61i Procesor ?Oddelek: Pomoč in nasveti | 2967 (2803) | solatko |
| » | acer aspire 5315 procesorOddelek: Strojna oprema | 3432 (3111) | jonyyy |
| » | Dual Core AMD/Intel (strani: 1 2 3 4 … 19 20 21 22 )Oddelek: Strojna oprema | 98733 (34041) | Isotropic |
| » | pentium dual core vs core2duoOddelek: Kaj kupiti | 7110 (6335) | Steinkauz |
| » | Razlika med procesorjiOddelek: Strojna oprema | 3146 (2346) | Blinder |
