Forum » Igre » Pomoč pri shaun white snowboarding
soldier111 ::
Ko grem v igro (imam original) mi pokaže ubisoft firmo vse uredo nato pa imam črn ekran najdlje sem čakal 5 min.(še v menu ne pride)Aja pa še to imam dosti dober pc ker mi napiše d mi more ta igrca run perfectly.
Prosim pomoč!!
Prosim pomoč!!
- premaknil iz Pomoč in nasveti: Rotaidal ()
Rotaidal ::
http://forums.ubi.com/eve/forums/a/tpc/...
Če kaj pomaga.
Če kaj pomaga.
SOLUTION:
uninstall the GAME,
Reinstall the Game
Don't launch the Game from the DVD or the shortcut.
Go where your game is installed EXEMPLE:
( c:\program files\shaun white snowboarding\ )
Then look for the file named:
ShaunWhiteSnowboardingGame.exe RUN THAT ONE not the other one.
Then wait a bit and your game should start ( depending of your system it can take 5 seconds - 1 minute, so be patient.....! Also don't click on the blackScreen just let it do it's trick, if this fix your Issue please let me know.And Also Rate my Post, that way everyone can fixed it..!
| » | Far cry 2 (strani: 1 2 3 4 … 9 10 11 12 )Oddelek: Igre | 132730 (86542) | Assass1n |
| » | Might and Magic: Heroes VI (strani: 1 2 )Oddelek: Igre | 12444 (10096) | detroit |
| » | Letalske igreOddelek: Igre | 3463 (2770) | Robert_S |
| » | Kako ugotoviti, kateri programi jemljejo RAM?Oddelek: Pomoč in nasveti | 2873 (2495) | nokia6310 |
| » | Zakaj Rayman ne dela v win XPOddelek: Igre | 1764 (1661) | dav |
