Edonkey2000 ID ?
Edonkey2000 ID ?
AIDS ::
LP, zanima me kaksne IDje imate ostali pri Oslu2000
Baje ce imas vecji ID je boljse ... ?
Djuro ::
3328122580
Jep, več je bolje! Sam ne smeš bit za proxyjem.
Tiger ::
No, takole je - ne velja ravno, da je večji ID boljše temveč je ID v bistvu nekakšen izračun tvojega IP-ja. Zato če imaš stalni IP potem je tudi ID stalen, vedno enak.
Vendar pa, če je ID zelo nizek, manj kot 6-mestna številka, potem to pomeni, da lahko downlodaš samo od uporabnikov z nizkimi ID-ji. Nizkega ponavadi dobiš na kakšnih zanič serverjih, ali če si za požarnim zidom, routerjem (ki ga nisi pravilno nastavil) itd...
Hux ::
Kaki ID? Kje te mate kake IDje?
  • spremenilo: Hux ()
Binji ::
kasn username. Klikni na uni velik vprasaj pa se ti bo pokazou ID
Kdor ne navija ni Slovenc, hej, hej, hej!
Hux ::
ja kake 4 miljarde je. In kaj ma to zaj veze z downloadom. Mislim no kdo vas je to napizdo ej lol. :8)
perci ::
Hux2: ne bos verjel, ampak tista stevilka dejansko ima pomen
Hux ::
eh daj no ta stevilka je smao identiteta da se program ne zmoti pri downloadu in nima dobene vze kak hitro ali kolk na enkrat dol vleces.
zile ::
What is an ID?
Your ID is one of two things, either
a number that is the result of your IP through a mathamatical equation (this number should be in the millions) This type of ID is a High ID
a number given to you by the server that you have connected to so that it can identify you, and contact you to instruct you to connect to other clients so they can send you files. (This is present when you are behind a firewall or the server is otherwise having problems opening new communications with you.
Recognizeable by a LOW ID (less than a million).
Its all in the manual. :D
  • spremenil: zile ()
frudi ::
server version 16.38.p36 (lugdunum)
Welcome @ SYLVER
This is a SuSE Linux 7.2 Anti-BOT-Server located in Germany
Low-ID-Clients are rejected, Client-Versions allowed: 59-61
Have fun, bc
BaRtMaN ::
2380942785
Jst pa tega dela v manualu/FAQjuju nism videl, ko sem ga bral
Hux ::
ja dobri ID je identiteta do tega spoznanja smo ze prisli ko so prvic uvedli rojstne liste mapak nikjer ne pise da ma kaj veze z donloadom. Ce zaj en kmet umeji svoj server smao na high IDje to nic ne pomeni razen da je malo neumen v glavi.
bodom ::
hehe...ma kaj res nimaste kej druzga napisat kot neke bedarije in pametovanje okol ID na edoneyu.
sej ne d bi se hvalu, sam jst mam ID kolkr sm uspel parkrat vidt vedno pod 1000 (trenutno 221)...pa mam zmer download in upload na max:D
Gandalfar ::
Hux2: obstaja neka teorija po kateri tisti clovek ni kmet. Gre za to da na server spustis samo ljudi z high IDji tako da nimas enih bednih bendih firewallanih userjev gor. Tak server naj bi bil potem seveda boljsi za povezat se gor.
Potem se pogledas kolk ima fajlov sharanih. Ce ima preveliko stevilo (cez 1000 recimo) ti to ze prevec obremenjuje streznik in search ni vec tako zelo effektiven.
Pa se ene par takih for je.. malo si poglej po ed2k forumu..
Hux ::
in smo spet tam. Tema je bila low ID prakticno nic download veliki ID hitri download ce se ne motim? To zaj kaj si poveod nima nic veze z velikostjo IDja. On lahko omeji na 1000 usersev z IDJi pod 1000 ali pa z IDJi nad miljardo. Kaj ma zaj to veze razen da dolocene osebe nemorejo gor? Pa btw serveri so omejeni na stevilo usersev ne glede na ID. ID omejitve se nisem vido dozaj nikjer. Ce pa jo ma kdo pa je kmet.
btw jaz se nisme mel IDja pod 300 miljonov od kar opazujem to.
matic ::
Ma daj folj preberite najprej manual in FAQ potem pa sprasujte!!!
Hux ti pa tut ze nehi.. s kmeti pa ni nic slabega ce jih nebi blo, bi ti salbo meso jedu! .. postavi svoj ed2k server pa daj mir.. ce te pa zanima kaj vec pa preberi FAQ na ed2k strani pa lih tko vsi ostali vsa ta vprasanja so miljonkrat ze odgovorjena...
Gandalfar ::
Hux2: uradni serverji so res omejeni z stevilom userjev. Ampak obstajajo tudi modificirani strezniki kjer se da nastavit taksne omejitve.
Zakaj bi zelel imet tak streznik? Zato, da gor nimas userjev ki so firewallanih in lahko downloadajo samo od vsakega 100 uporabnika. Ker ti userji ti samo bw tratijo pa zelo malo prispevajo v sharing ker so firewallani. Pa se med sabo se ponavadi ne morejo povezat..
Hux ::
No tak kot vi tu radi FAQ berete bi te ze lahko vedli da firewall za Osla nic ne pomeni ker jo skratka obide. Celi cajt na firewallu in mi upload terja kr veselo z 10k
AIDS ::
LP, hvala lepa za odgovore :-)
btw, koncno sem prisel na visok ID .. :-)
4055059905
bodom ::
hmm...ma od kje vam tako visoki ID-ji?
jst mam ID zadnje dni vedno okol 2008-O in mi veselo louda povprecno 40kb/s.
ne vidm jst, da bi visoka ID cifra kej pomagala. jst je se nism mel vec kot 1000.
je pa res, da mam max connections tm pod options nastimano na 800 - 1000:D
[P2P]eMule , eDonkey, Overnet, DC++ & co. (strani: 1 2 3 4 … 69 70 71 72 )
Oddelek: Omrežja in internet
3558439928 (23212) Freakylion
Pomoc pri nastavitvi routerja za eMule ...
442374 (2166) CaqKa
eDONKEY oz. eMULE in okupiranje diska
Oddelek: Programska oprema
161921 (1410) bodom
Battlefield 1942 kot igra!
Oddelek: Igre
191739 (1308) kivi113
edonkey2000 & win XP
151435 (1147) JLP
