Emgeton in koliko Hz zvok zares prenasa
HaBiba ::
Zivio, imam eno vprasanje v zvezi z multiplayerjem Emgeton CULT E9. Potrebovala sem flac player za binaural beats zvoke, pri katerih je pomembno, da se ne izgubi kvaliteta (flac fajli so dovoljeni, ker ni izgube) in pri katerih je denimo rpav tako pomembno,d a uporabljas slusalke, ki prenasajo zvoke od 5 Hz navzgor.
Zdaj me pa zanima, ali tale player Emgeton CULT E9 sploh zmorej rpedvajati zvoke od 5 Hz naprej (ceprav itak uporabljam z njim slusalke ki prenasajo ofd 5 hz naprej), ker podatki proizvajalca navajajo sledece (http://www.emgeton.com/product110.htm):
Specifications:
Display:
- TFT-LCD 2.4" 320x240 262k colors
External slot:
- microSD/T-Flash slot for memory cards up to 2GB
View: JPG, GIF, BMP and TXT files
Playback:
- MP3(VBR) 8 ~ 320kbps
- WMA(VBR) 8 ~ 340kbps
- FLAC, APE
- Recording: 8 ~ 128kbps
- Video: AVI/MP4/3GP/MOV/MPG/FLV/RM/RMVB/WMV files
- SWF Flash 7.0 playing
High speed USB 2.0 interface
High capacity USB flash storage for mobile disk
Accumulator: built-in Li-Pol
Playback Time:
- Music Up to 13 hours continuous playback
- Video Up to 6 hours continuous playback
Hi-Fi treble & bass compensation system
Multi-language Supported. ID3V2, ID3V1
File name Supported there are Czech, English languages
Storage capacity: up to 5.000 files for playback
FM Radio (optional):
- FM Receiving Frequency 87.5MHz - 108MHz
- Recording
Photo album, Games
SN Ratio: >85dB
Frequency range: 20Hz ~ 20kHz
Earphones Output: 15mW + 15mW
Weight: 68g (with accumulator)
Size: 85 x 48 x 10mm
Supports Windows 2000/XP/Vista
Supplied Accessories:
Earphones, User's Manual, USB Cable, Installation CD, Fashionable Necklace
Troej, ali to pomeni, da ceprav uporavljam tak format fajlov, pri katerih se nizke frekvence od 5 Hz naprej ne bi smele zgubit in ceprav uporabljam slusalke, ki te frekvence prenasajo, da sama naprava ni sposobna predati naprej tako nizkih frekvenc?
hvala
chittax ::
5Hz ne boš slišal. Človeško uho začne slišno zaznavati (odvisno kakor kateri) nekje 20 do 30 Hz. Praviloma pa so te frekvence 20 - 20kHz napisane kr neki, ker jih realno predvajajo le hi-fi naprave visokega cenovnega razreda. (BTW je Hi-Fi standard po DIN nekje 30 Hz pa do 16 kHz)
sploh če pri frekvencah nimaš napisano +/-dB slabljenja signala.
HaBiba ::
zivio, hvala za odgovor a to kar se slisi ali ne slisi ni vazno. Gre za to, da uporabljam holosync meditativne programe, ki z binaural beats tehnoogijo spravijo mozgane, da delujejo sinhrono (obe polovici) v theta (4-8Hz) ali alfa stanju. Princip je enostaven - v enem usesu slisis 505 Hz, v drugem 500, potem pa naj bi tvoji mozgani izravnali to nesoglasje tako, da ustvarijo tretji "ton", ki je razlika med obema - torej v nasem primeru 5 Hz, v okviru katerega potem delujejo. Samo problem je v tem, da ce pogledas na spletno stran proizvajalca tega programa Holosync (Centerpointe), pise, da je potrebno od dolocenega nivoja tega program uporabljat slusalke od 5 hz naprej, ceprav mi ni jasno zakaj. Zato pac sprasujem... Ne vem zdaj kaj mi 5 hz slusalke pomagajo, ce pa sama naprava ni sposobna oddajat takih zvokov... ???
Hvala! :D
Pa se to, a ce poslusam iz racunalnika, a potem pa je ok in racunalnik prenasa zvoke od 5 hz naprej? Saj ne vem ali ima racunalnik prenos glasbe po prinicipu Hi fi ali je morda kvaliteta boljsa/drugacna??
Hvala in se opravicujem za splosno nerazumevanje teh principov.
  • spremenila: HaBiba ()
echo ::
Bianuralni toni na Slo-techu
Saj ne potrebuješ takih slušalk, niti playerja. Fora je ravno v tem, da predvajalnik ustvari 500 in 505Hz zvok, ki ju brez problemov slišiš in ju tudi oprema ustvari.
Tistih 5Hz pa ustvari glava.
Katere slušalke pa so zmožne ustvarjati 5Hz?
Računalnik je ok.
Imaš link, kjer je ta zahteva o teh petih hercih? Ker to je zelo zelo malo.
Infrasound @ Wikipedia
Pyr0Beast ::
Za 5Hz rabiš že zelo veliko membrano. Tam do 7Hz še gre z 50cm, nižje (3HZ) se pa skoraj ne občuti (sliši), saj se ne izrine dovolj zraka.
Drugače se pa ne sliši kot en ton ampak kot 'bobnenje'.
Fenomen binauralnih tonov (strani: 1 2 3 )
10219526 (15155) Jst
Komarjevo zvonjenje (strani: 1 2 )
588727 (6283) OwcA
Znanstveniki odkrili pojoči ledenik (strani: 1 2 )
509447 (8116) BigWhale
Kateri 2.1 zvočniki za računalnik
453259 (2548) glinik
