tomcat in datasource
boss-tech ::
Zanima me kako v tomcatu (linux), nastavim datasource, ki ga potem uporabim v nekem projektu?
DavidJ ::
Kaj konkretno bi pa rad? Naredil connection pooling? Če slednje, potem uporabi tole
WebContent/META-INF/context.xml
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE connection-pooling PUBLIC
	"-// Apache Tomcat //DTD Connection-pooling Configuration 2.0//EN"
	"http://struts.apache.org/dtds/struts-2.0.dtd">
<Context debug="5" reloadable="true" crossContext="true">
	<Resource name="jdbc/trustguard" auth="Container" type="javax.sql.DataSource"
		maxActive="100" maxIdle="30" maxWait="10000" username="user" password="pass"
		driverClassName="com.mysql.jdbc.Driver"
		url="jdbc:mysql://localhost:3306/baza?autoReconnect=true" />
</Context>
Naredi singleton za pridobivanje povezave iz poola:
import java.sql.Connection;
import java.sql.PreparedStatement;
import java.sql.ResultSet;
import java.sql.SQLException;
import java.sql.Statement;
import javax.naming.Context;
import javax.naming.InitialContext;
import javax.naming.NamingException;
import javax.sql.DataSource;
public class Jdbc {
	private static DataSource ds = null;
	static {
		Context initContext, envContext;
		try {
			initContext = new InitialContext();
			envContext = (Context) initContext.lookup("java:/comp/env");
			ds = (DataSource) envContext.lookup("jdbc/trustguard");
		} catch (Exception e) {
			System.err.println(e);
			System.exit(1);
        public static synchronized  Connection getConnection() throws NamingException, SQLException {
		return ds.getConnection();
Kako uporabljas singleton
public List<Operator> getAllOperators() {
	// Jdbc je referenca na razred za dostop do baze
	String query = "SELECT * FROM tabELca";
	Connection connection = null;
	Statement statement = null;
	ResultSet rs = null;
	List<Operator> operators = new ArrayList<Operator>();
	try {
		connection = Jdbc.getConnection();
		statement = connection.createStatement();
		statement.executeQuery(query);
		rs = statement.getResultSet();
		int id;
		String operatorName, description;
		while (rs.next()) {
			id = rs.getInt(1);
			operatorName = rs.getString(2);
			description = rs.getString(3);
			operators.add(new Operator(id, operatorName, description));
	} finally {
		Jdbc.closeResultSet(rs);
		Jdbc.closeStatement(statement);
		Jdbc.closeConnection(connection);
	return operators;
edit: popravil getConnection v synchronized
"Do, or do not. There is no 'try'. "
- Yoda ('The Empire Strikes Back')
  • spremenil: DavidJ ()
DavidJ ::
Sori, pozabil na web.xml :)
WebContent/WEB-INF/web.xml
<web-app xmlns="http://java.sun.com/xml/ns/j2ee"
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xsi:schemaLocation="http://java.sun.com/xml/ns/j2ee
http://java.sun.com/xml/ns/j2ee/web-app_2_4.xsd"
    version="2.4">
  <description>MySQL Test App</description>
  <resource-ref>
      <description>DB Connection</description>
      <res-ref-name>jdbc/trustguard</res-ref-name>
      <res-type>javax.sql.DataSource</res-type>
      <res-auth>Container</res-auth>
  </resource-ref>
</web-app>
Drugače pa:
- http://onjava.com/pub/a/onjava/2006/04/...
- http://developer.spikesource.com/blogs/...
- http://www.crazysquirrel.com/computing/...
- http://tomcat.apache.org/tomcat-6.0-doc...
- http://www.hisham.cc/articles/2008/01/0...
Pa jasno, da moraš za MySQL in ostale baze imeti ustrezen JDBC dirver.
boss-tech ::
Sem naredil na ta način. Imel sem nekaj problemov glede jdbc driverja, sedaj pa sem naletel na tole napako in me zanima če kdo ve kdaj približno bi lahko bil problem:
28.8.2009 9:28:10 org.apache.catalina.core.StandardContext listenerStart
SEVERE: Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'pService' defined in ServletContext resource [/WEB-INF/applicationContext.xml]: Cannot resolve reference to bean 'daoService' while setting bean property 'dao'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'daoService' defined in ServletContext resource [/WEB-INF/applicationContext.xml]: Cannot resolve reference to bean 'loginUserDAO' while setting bean property 'loginUserDAO'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'loginUserDAO' defined in ServletContext resource [/WEB-INF/applicationContext.xml]: Cannot resolve reference to bean 'hibernateTemplate' while setting bean property 'hibernateTemplate'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'hibernateTemplate' defined in ServletContext resource [/WEB-INF/applicationContext-hibernate.xml]: Cannot resolve reference to bean 'sessionFactory' while setting bean property 'sessionFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in ServletContext resource [/WEB-INF/applicationContext-hibernate.xml]: Invocation of init method failed; nested exception is java.lang.ExceptionInInitializerError
Related cause: org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'hibernateConfig' defined in ServletContext resource [/WEB-INF/applicationContext-datasource.xml]: Unsatisfied dependency expressed through constructor argument with index 1 of type [java.lang.ClassLoader]: Ambiguous constructor argument types - did you specify the correct bean references as constructor arguments?
Related cause: org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'hibernateConfig' defined in ServletContext resource [/WEB-INF/applicationContext-datasource.xml]: Unsatisfied dependency expressed through constructor argument with index 1 of type [java.lang.Class]: Ambiguous constructor argument types - did you specify the correct bean references as constructor arguments?
infiniteLoop ::
Mislim, da bos moral z nami deliti vsaj tisti del spring konfiguracijske datoteke, ki se tice beana "hibernateConfig".
None of us is as dumb as all of us.
boss-tech ::
<bean id="hibernateConfig" class="org.springframework.core.io.ClassPathResource">
	<constructor-arg index="0">
		<value type="java.lang.String">hibernate.cfg.xml</value>
	</constructor-arg>
</bean>
boss-tech ::
src/main/resources/hibernate.cfg.xml pa ima tole vsebino:
<!DOCTYPE hibernate-configuration PUBLIC
		"-//Hibernate/Hibernate Configuration DTD 3.0//EN"
		"http://hibernate.sourceforge.net/hibernate-configuration-3.0.dtd">
<hibernate-configuration>
    <session-factory>
        <property name="hibernate.dialect">org.hibernate.dialect.PostgreSQLDialect</property>
        <property name="hibernate.query.factory_class">org.hibernate.hql.ast.ASTQueryTranslatorFactory</property>
        <!-- property name="hibernate.hbm2ddl.auto">create-drop</property -->
        <property name="hibernate.show_sql">false</property>
        <property name="hibernate.default_schema">test</property>
        <property name="hibernate.jdbc.batch_size">30</property>
    </session-factory>
</hibernate-configuration>
infiniteLoop ::
Katero verzijo springa pa uporabljas? Jaz sem probal na 2.5.6 in dela OK. Zgleda, da je problem z argument za hibernateConfig bean sodec po stack traceu.
Zakaj pa sploh poskusas ustvariti poseben ClassPath resource? To lahko zate opravi spring implicitno. Primer:
<bean id="sessionFactory" class="org.springframework.orm.hibernate.LocalSessionFactoryBean">
    <property name="dataSource"><ref local="dataSource"/></property>
    <property name="configLocation">
        <value>classpath:hibernate.cfg.xml</value>
    </property>
</bean>
boss-tech ::
Imam 2.5.4. Stvar je v tem da mora sessionFactory dobit ta configLocation v obliki objekta(ker bean hibernetConfig je objekt razreda org.springframework.core.io.ClassPathResource), ne vem ali je ta classpath:hibernate.cfg.xml objekt ali string?
		<constructor-arg>
			<value>hibernate-itrackpersonal.cfg.xml</value>
		</constructor-arg>
</bean>
infiniteLoop ::
Spring bo string "classpath:hibernate.cfg.xml" implicitno spremenil v resource.
boss-tech ::
Sem naredil takole:
<bean id="sessionFactory" class="...core.spring.annotation.AnnotationSessionFactoryBean"> //lokalni razred ki extenda     org.springframework.orm.hibernate3.annotation.AnnotationSessionFactoryBean
	    <property name="dataSource"><ref bean="dataSource"/></property>
		</property>
Pa dobim napako:
1.9.2009 14:14:31 org.apache.catalina.core.StandardContext listenerStart
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'Service' defined in ServletContext resource [/WEB-INF/applicationContext.xml]: Cannot resolve reference to bean 'daoService' while setting bean property 'dao'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'daoService' defined in ServletContext resource [/WEB-INF/applicationContext.xml]: Cannot resolve reference to bean 'loginUserDAO' while setting bean property 'loginUserDAO'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'loginUserDAO' defined in ServletContext resource [/WEB-INF/applicationContext.xml]: Cannot resolve reference to bean 'hibernateTemplate' while setting bean property 'hibernateTemplate'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'hibernateTemplate' defined in ServletContext resource [/WEB-INF/applicationContext-hibernate.xml]: Cannot resolve reference to bean 'sessionFactory' while setting bean property 'sessionFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in ServletContext resource [/WEB-INF/applicationContext-hibernate.xml]: Invocation of init method failed; nested exception is java.lang.ExceptionInInitializerError
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:275)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1244)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1008)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:470)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:220)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3843)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4338)
at org.apache.catalina.manager.ManagerServlet.start(ManagerServlet.java:1247)
at org.apache.catalina.manager.HTMLManagerServlet.start(HTMLManagerServlet.java:604)
at org.apache.catalina.manager.HTMLManagerServlet.doGet(HTMLManagerServlet.java:129)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at sun.reflect.GeneratedMethodAccessor57.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil.java:244)
at javax.security.auth.Subject.doAsPrivileged(Subject.java:537)
at org.apache.catalina.security.SecurityUtil.execute(SecurityUtil.java:276)
at org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:162)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:283)
at org.apache.catalina.core.ApplicationFilterChain.access$000(ApplicationFilterChain.java:56)
at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:189)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:185)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:525)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:636)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'daoService' defined in ServletContext resource [/WEB-INF/applicationContext.xml]: Cannot resolve reference to bean 'loginUserDAO' while setting bean property 'loginUserDAO'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'loginUserDAO' defined in ServletContext resource [/WEB-INF/applicationContext.xml]: Cannot resolve reference to bean 'hibernateTemplate' while setting bean property 'hibernateTemplate'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'hibernateTemplate' defined in ServletContext resource [/WEB-INF/applicationContext-hibernate.xml]: Cannot resolve reference to bean 'sessionFactory' while setting bean property 'sessionFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in ServletContext resource [/WEB-INF/applicationContext-hibernate.xml]: Invocation of init method failed; nested exception is java.lang.ExceptionInInitializerError
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
... 49 more
infiniteLoop ::
Ko postas stacktrace je najbolj zanimiv ozr. uporaben root cause. Torej zadnji del stack tracea ozr. zadnji "Caused by" in do konca. Ce hoces pomoc nam ga zrihtaj ;)
boss-tech ::
Tule je celoten stacktrace
infiniteLoop ::
Eh majster to ti je pa spet novi stack trace, ki kaze na to, da imas spet probleme z "hibernateConfig". Flikni to ven in poskusi z implicitnim resourcom. Potem pa postaj stack trace od napake, ki si jo dobil tam.
Ne zazna R.class -android
Oddelek: Programiranje
171752 (1590) Marat
[Android]Vprasanje glede GUI ter pripadajoce XML datoteke
104436 (4322) KernelPanic
java datapool - derby
62937 (2786) jlpktnst
java, zajem podatkov iz DB
101551 (1283) l0g1t3ch
Java- hibernate.properties not found
112281 (1781) xsenon
