Ne zazna R.class -android
matej94 ::
Primer kaj mi naredi. Zadeva mi je delala in naenkrat mi ne zazna več r clasa..
Zgleda zadeva takole:
Mavrik ::
Poglej kaj ti piše za napake v konzoli, to nam ne pove nič. Naredi še preventivno "Clean project".
matej94 ::
Tole:
eclipse.buildId=I20120608-1400
java.version=1.6.0_24
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=sl_SI
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
Error
Thu Aug 30 11:36:09 CEST 2012
An internal error occurred during: "Launching New_configuration".
java.lang.IllegalArgumentException: Path for project must have only one segment.
at org.eclipse.core.runtime.Assert.isLegal(Assert.java:63)
at org.eclipse.core.internal.resources.WorkspaceRoot.getProject(WorkspaceRoot.java:184)
at com.android.ide.eclipse.adt.internal.launch.LaunchConfigDelegate.getProject(LaunchConfigDelegate.java:368)
at com.android.ide.eclipse.adt.internal.launch.LaunchConfigDelegate.launch(LaunchConfigDelegate.java:117)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:855)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:704)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1047)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1251)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Error
Thu Aug 30 11:29:43 CEST 2012
Unhandled event loop exception
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:4361)
at org.eclipse.swt.SWT.error(SWT.java:4276)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.NullPointerException
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.performSaveAs(AbstractDecoratedTextEditor.java:1580)
at org.eclipse.ui.texteditor.AbstractTextEditor.handleEditorInputChanged(AbstractTextEditor.java:4746)
at org.eclipse.ui.texteditor.StatusTextEditor.handleEditorInputChanged(StatusTextEditor.java:267)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.handleEditorInputChanged(AbstractDecoratedTextEditor.java:1502)
at org.eclipse.ui.texteditor.AbstractTextEditor.sanityCheckState(AbstractTextEditor.java:4905)
at org.eclipse.ui.texteditor.StatusTextEditor.sanityCheckState(StatusTextEditor.java:257)
at org.eclipse.ui.texteditor.AbstractTextEditor.safelySanityCheckState(AbstractTextEditor.java:4883)
at org.eclipse.ui.texteditor.AbstractTextEditor$ActivationListener.handleActivation(AbstractTextEditor.java:984)
at org.eclipse.ui.texteditor.AbstractTextEditor$ActivationListener.access$0(AbstractTextEditor.java:977)
at org.eclipse.ui.texteditor.AbstractTextEditor$10.run(AbstractTextEditor.java:1005)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
... 24 more
matej94 ::
Alpa še to :
  • spremenilo: matej94 ()
draciel ::
Kar si prilepil tole zadnje ne. Tam ti piše da si vrednosti barv napačno vpisal in tako kot si vpisal, tako se je shranilo v R class. Ti bi moral barve napisati s hexadecimalno kodo npr tako:
#FFFFFF
To je npr bela barva. Generator kod lahko dobiš na tej strani.
Mavrik ::
Gledaš vse napačne stvari. Kot je draciel napisal - v "Problems" oknu imaš kup napak v XMLjih ker narobe pišeš barve ("Color value must start with #"). In ker imaš napake v XML se ti razred R s teh XMLjev sploh ne zgenerira.
matej94 ::
Ne to je 200% vse prov so navedene v 16 kodi barve,..100%
Kaj mislite da bi vso kodo znova napisal, kot pa da se z tole napako srečujem:
Mi pa napiše:
The import com.pragmatouch.calculator.R cannot be resolved
import com.pragmatouch.calculator.R;
setContentView(R.layout.second);
In še hujši problem je da se napake izmenjujejo, enkrat ene drugič druge ;( ..Ko odpravim vse napake v javi se mi pojavi v xml-ju ali obratno..
Popravljam barve kaj pa je potem tukaj:
Exported activity does not require permission
 <activity android:name=".graf"
                  android:label="@string/app_name">
            <intent-filter>
                <action android:name="com.pragmatouch.calculator.CLEARSCREEN" />
                <category android:name="android.intent.category.DEFAULT" />
            </intent-filter>
        </activity>
draciel ::
a si mogoče kaj R class spreminjal kdaj, oziroma si posegal v njega na kakršenkoli način? Si odpiral kdaj R class datoteko?
matej94 ::
Alpa tole, kar v xml codi mi napko meče..
Ja sem enkrat sem mal ustvarju v njej potem sem pa zapru vse skupi pa je delal...
Včeraj pa r klasa sploh blo ni več ;( Sem vse skopiral v stari projekt pa je še enaka jebada, ...
draciel ::
Tisto ni napaka v xml kodi. Tisto te samo opozarja da uporabi raje drug "vir" za shranjevanje teksta, ki se shrani v String datoteko. Imaš jo pod /res/values in nato String. Tam notri shraniš željen tekst.
matej94 ::
Sej tam imam calculator napisano . Ampak kaj misliš da je tole narobe.
draciel ::
Kaj "tole" ? Tisti klicaji, v zadnjem screenshotu ki si ga poslal?
matej94 ::
Ob zagonu se naredi tole..
Ja pa tut klicaji vse skupaj,..Ampak pred tem je delala zadeva, sedaj pa kr nehala.. Se ti sanja, ti lahko projekt pošlem, koda bi mogla bit vsaj teoretično prava,..
draciel ::
Človek ti imaš cel kup problemov. Nekaj te vprašam, a ti prilepiš drugo napako. Sploh ne vem kako naj ti pomagam.
edit: Kaj pa če bi na primer se lotil projekta na novo / svež projekt? Očitno si moral nekaj zbluzit, tudi takrat ko si R class spreminjal. Ne vem no, moj nasvet.
  • spremenil: draciel ()
matej94 ::
Sej sem zgoraj vprašal, pa mi nista odgovrila, se mi zdi bolj pametno da začnem od začetka :p ..
draciel ::
Bo definitivno bolje ja. Good luck..
matej94 ::
Sedaj na novo ampak ne zazna r classa itd..Slikca:
Marat ::
Kater R imaš importan? pokaž katere fajle imaš pod import?
Eclipse in windows 8
121583 (1336) mihibo5
[Android]Vprasanje glede GUI ter pripadajoce XML datoteke
Oddelek: Programiranje
104424 (4310) KernelPanic
java datapool - derby
62934 (2783) jlpktnst
tomcat in datasource
132672 (2429) infiniteLoop
Java- hibernate.properties not found
112279 (1779) xsenon
