java datapool - derby
boss-tech ::
V netbeans sem naredil derby bazo, tabele ter jdbc connection pool - kako potem v javi dostopam do tega connectiona in potem delam povpraševanja? Hvala
da2sn2 ::
v META-INF ustvaris persistance.xml
<?xml version="1.0" encoding="UTF-8"?>
<persistence version="1.0" xmlns="http://java.sun.com/xml/ns/persistence">
	<persistence-unit name="unit_name" transaction-type="JTA">
		<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
		<jta-data-source>jdbc/pool_name</jta-data-source>
		<properties>
			<property name="eclipselink.logging.level" value="INFO"/>
			<property name="eclipselink.ddl-generation" value="create-tables"/>
		</properties>
	</persistence-unit>
</persistence>
nato v tvojem beanu uporabis
@PersistenceContext(unitName = "unit_name")
private EntityManager em;
isces pa z npr:
NekRazred obj = em.find(NekRazred.class, 1234); //1234=id
ali pa
String jpqlQuery = "SELECT c.objId FROM NekRazred c";
TypedQuery<Long> query = em.createQuery(jpqlQuery, Long.class);
EDIT: To gre za javo EE :)
  • spremenil: da2sn2 ()
boss-tech ::
Imam samo WEB-INF, META-INF pa ni....gre za spletno aplikacijo
da2sn2 ::
Predvidevam da imas samo web module (zaradi WEB-INF; drugace lahko META-INF ustvaris rocno)?
V netbeansu ne vem kako tocno gre, v eclipsu pa ustvaris Dynamic Web Project za web in pa Enterprise Application Project s katerim dobis EJB modul (na koncu pa iz tega naredis ear datoteko (podobno kot jar), v kateri je zraven war modul in jo lahko deployas na aplication server). V EJB modulu nato ustvaris persistance.xml, itd..
Mogoce poglej na ta link ce bo kaj v pomoc: http://www.webagesolutions.com/knowledg...
boss-tech ::
Sedaj sem naredil en data library, ter v persistance.xml dal tole:
<persistence version="2.0" xmlns="http://java.sun.com/xml/ns/persistence" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_2_0.xsd">
  <persistence-unit name="IzmenjavaDataLibraryPU" transaction-type="RESOURCE_LOCAL">
    <class>database.Izmenjava</class>
    <class>database.Student</class>
    <properties>
      <property name="javax.persistence.jdbc.url" value="jdbc:derby://localhost:1527/izmenjavaDatabase"/>
      <property name="javax.persistence.jdbc.password" value="geslo"/>
      <property name="javax.persistence.jdbc.driver" value="org.apache.derby.jdbc.ClientDriver"/>
      <property name="javax.persistence.jdbc.user" value="admin"/>
    </properties>
  </persistence-unit>
</persistence>
Potem pa zagnal test case kjer imam:
EntityManagerFactory emf = Persistence.createEntityManagerFactory("IzmenjavaDataLibraryPU");
EntityManager em = emf.createEntityManager();
Dobim pa napako:
Caused by: Exception [EclipseLink-4003] (Eclipse Persistence Services - 2.0.2.v20100323-r6872): org.eclipse.persistence.exceptions.DatabaseException
Exception Description: Configuration error. Class [org.apache.derby.jdbc.ClientDriver] not found.
at org.eclipse.persistence.exceptions.DatabaseException.configurationErrorClassNotFound(DatabaseException.java:82)
at org.eclipse.persistence.sessions.DefaultConnector.loadDriverClass(DefaultConnector.java:267)
at org.eclipse.persistence.sessions.DefaultConnector.connect(DefaultConnector.java:85)
at org.eclipse.persistence.sessions.DatasourceLogin.connectToDatasource(DatasourceLogin.java:162)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.loginAndDetectDatasource(DatabaseSessionImpl.java:584)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:228)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:369)
... 5 more
Se pravi da moram dobit jar s tem razredom? Ali je v čem drugem problem
boss-tech ::
Jaz v aplikaciji kličem metodo, ki se poveže z bazo preko: EntityManagerFactory emf = Persistence.createEntityManagerFactory("test");
V aplikaciji lepo to gre skozi in vrne podatke. Ko pa zaženem main metodo iz tega projekta in kličem to metodo pa dobim:
Exception in thread "main" javax.persistence.PersistenceException: No Persistence provider for EntityManager named test
at javax.persistence.Persistence.createEntityManagerFactory(Persistence.java:84)
at javax.persistence.Persistence.createEntityManagerFactory(Persistence.java:54)
Zakaj se to dogaja? Kje je razlika?
jlpktnst ::
javax.servlet.ServletException: Exception [EclipseLink-4021] (Eclipse Persistence Services - 2.2.0.v20110202-r8913): org.eclipse.persistence.exceptions.DatabaseException
Exception Description: Unable to acquire a connection from driver [null], user [null] and URL [null]. Verify that you have set the expected driver class and URL. Check your login, persistence.xml or sessions.xml resource. The jdbc.driver property should be set to a class that is compatible with your database platform
Zabavno, če vržem v persistence.xml direkt jdbc driver dela. Če potegnem direkt jdbc/ connection pool v program tudi dela. Očitno eclipselink ne najde baze nekako? Verjetno so kekci nekaj spremenili in jit-data-source.../ property enostavno ne potegne zadeve not? Ali pa mi manjka driver nekje... pitaj boga, napaka je res useless.
Chain: eclipse 3.6, glassfish 3.1 integrated, eclipselink jpa, mysql. Če ma kdo kake ideje je ok, ker jih meni zmanjkuje :)
[Java] JPA - transient v orm.xml
Oddelek: Programiranje
51595 (1515) dmok
Ne zazna R.class -android
171749 (1587) Marat
tomcat in datasource
132673 (2430) infiniteLoop
Java- hibernate.properties not found
112279 (1779) xsenon
[java]package doesnt exist
61236 (1119) <b>klima</b>
