Forum » Igre » Guild Wars 2
Guild Wars 2
BALAST ::
S to hitro predstavitvijo boš dovolj informiran, četudi nisi v beti.
"You may fool all the people some of the time;
you can even fool some of the people all the time;
but you can't fool all of the people all the time."
Yaqwsx ::
cakajo, na novo generacijo graficnih in procesorjev. ker trenutni nezmorejo se kaj so ustvarli :p
Boobiz ::
BMK! Važno je da je primarno delan za PC in ne obratno, kot je danes praksa.
I'm drunk, what's your excuse?
ahac ::
Nevidim nic spornega da bo za konzole. Vbistvu upam celo da bodo player base zdruzili.
Sej bi blo fajn pwnat tiste, ki igrajo na kontrolerju, ampak... isti playerbase pomeni, da morajo izdat patche istočasno, kar pomeni, da boš na vsak patch čakal par tednov, da se MS odloči, če ga bodo dovolil releasat na Xboxu ali ne.
- spremenil: ahac ()
ABX ::
Največi in verjetno edini problem bi bil jokanje na forumu. Zato jih nikoli ne združijo.
IvoJan ::
World vs. World![]()
neki podobnega je bila ze v WoWu kjer si v outlandu zavzemal 3 razlicne tocke ce se ne motim.
Tr0n ::
Server queue-i v GW2? Fuck that! :)
http://www.guildwars2guru.com/forum/sho...
Let me explain what an overflow server is and what it does. It is a technology we also use as our version of a queuing system. When a map or a world you want to log into is at capacity limit, the game will ask you if you want to play on an overflow server - so you can actually play while you are in a queue. Once space opens on your world, the game will ask you if you want to join your friends on your world. And you keep all the progress you made while you were playing on the overflow server.
BALAST ::
Freaxx ::
It's very important that professions in an MMO have interesting ways to interact with each other. In the past this has mostly been limited to healing and buffing teammates and managing agro in combat. We wanted to expand considerably upon the types of teamwork available to our players. With this in mind, we've implemented a system of cross-profession combinations.
A warrior and an elementalist playing together could combine their abilities in several different ways. The elementalist could drop down Static Field, which is an area-targeted lightning effect. A warrior who fires a rifle bullet through the static field would cause his shot to be charged up with electricity, inflicting additional damage. If that didn't suit their style, then the elementalist might drop a Wall of Fire in front of a group of enemies. The warrior could enter the firewall and use Cyclone Axe, an attack which causes him to spin rapidly, sending the firewall outward and hitting his foes. There are literally hundreds of combinations for players to discover.
OMFG to bi znal bit epic, sploh ksni op comboti ob izidu :)
Freaxx ::
Samo ta scaling v conah nižjih za levelat ali npr višji lvl PvP. Ko dobiš lvl ustrezen za tisto stvar naredi pomen levelanja manjši, mam tak občutek...al pa so to nekak ustimal da bo delal ko more :)
Freaxx ::
Pa kdaj je mišljen release date?! Če mislejo neko public beto še umes porint, ok naj bo, sam hiter...Cant wait
Boobiz ::
Če bo sreča bomo open beto dočakali marca/aprila in bi lahko launch bil nekje maja, razen če bo izid TERE imel kak vpliv na gw2.
Freaxx ::
Mja, sam so se lotil tko na veliko...kar je pa tut prav, da spremenijo stvari ki že od začetka MMO iger stagnirajo. IMO sploh tale combo skills, namesto dual speca, in pa dinamično okolje...mislim tut če bi blo vse skup zanič, bi blo še zmer zanimivo ker je nekaj novega, še ne videnega. Slaba stran pa je to, da takšni projekti razvoja MMOjev trajajo, mi se pa že vsi slinimo, pa še open bete ni blo :)
Tr0n ::
Hja, ocitno bo za visok FPS na high nastavitvah potreben kar soliden PC, vsaj glede na trenuten press beta build. S klasicno i5/i7, 6xxx ali GTX konfiguracijo je folk imel med 15 in 60 FPS na high settingih, ko je guzva je pa zadeva precej padla. Optimizacija engina in driverjev bo upam da tole malce porihtala.
In brief, the game ran pretty smoothly on my machine (7.5 Windows rating, 3.20 GHz six-core CPU, 8 GB RAM, AMD Radeon HD 6900). On maxed-out settings I was getting about 15-30 FPS depending on where I was–high population or huge vistas slowed it down. Moving down the graphics settings, I could run 30-60 FPS no problem.
My home computer (5.9 Windows rating, 2.9 GHz dual-core, 8GB RAM, NVIDIA GeForce GTX 570) ran the game smoothly around 30 fps on maxed-out settings. The only major issues I had with performance were directly related to the amount of players in WvW.
- spremenilo: Tr0n ()
ABX ::
Mogoče je CPU ne-optimizirana.
Spet kako dual thread sranje ki potrebuje navit CPU na 4Ghz.
Boobiz ::
A vi to resno? Špil je neoptimiziran, če ma v gužvi fps drope na max settingu? HAHA. Obviously se v gužvi vklopi minimum detajl. Če špil v splošnem nebi bil optimiziran ala swtor potem bi se pa lahko pritoževali.
Pesimist ::
swtor je gnoj. Mislim da se ga bm enrkat podalsal za mesec dni, vendar bom mel zaj kako malo vejco pauzo slabi mesec. Te pa upam da bo GW2 ze tu.
spomnite me da se najkasneje pri 60tih fstrelim ce bom slucajno docako.
Ker gledam tote stare ludi kak po svetu štancajo pa si mislim "without me"...
- spremenilo: Pesimist ()
Tr0n ::
Jah, ce se prav optimizira zadeva, mora tudi v guzvi delat vredu do neke mere. Tukaj pa jim je zacelo stekat ze pri 10 igralcih recimo, kar bo v WvW kar pogost scenarij (verjetno bo se veliko vec igralcev na kupu).
Ima da to porihtajo do releasa. :)
ABX ::
2 thread = ne-optimizirano (Skyrim, WoW, Starcraft 2, ...)
4 thread = ok (FarCry 2, Dirt 3, .... )
tt2 ::
Ne vem, da se ni noben spomnil, da bi pogledal koliko jeder je beta izrabljala oz. koliko procentov CPU-ja je igra požrla. Spomnim se, da je na primer BF2 BC v beti uporabljal le eno jedro.
ABX ::
O kaksnih threadih ti bluzis?
Thread %28computing%29 @ Wikipedia
Po domače rečemo da igra/apliakcija koristi samo 2 jedra. Samo to ni tehnično pravilno.
Ker dual thread aplikacija lahko koristi tudi vsa 4 jedra, če skače iz enega na drugega, ampak pri tem nobeno jedro ne gre čez 50%. Torej je bolj pravilno označit aplikacijo kot dual thread.
Primer, narediš eno skripto ki zabije single core CPU na 100%. Ko jo poskusiš zalaufat na dual-core vidiš da oba cora sta zasedena, ampak samo na 50%, ker process skače okoli.
Tr0n ::
Dokler je aplikacija multithreaded (2 ali vec), je multithreaded. Drugo je, ali potem zna OS/CPU/jezik tole zaganjat na vec jedrih. Tole pa ni vec tolko odvisno od same high-level aplikacije, v tem primeru igre. Lahko kvecjemu delas dolocen fine-tuning in kaksne trike za dolocen sisteme, da prisilis zadevo k boljsemu izkoristeku corov.
Nemixxx ::
Kaj pomeni ta beta stran? Jaz sem se prijavil ampak na gmail še nisem dobil nič.
In če dobiš na gmail "odgovor" kaj to pomeni?Da ko pride beta lahko s tem acc igraš?
|Intel Core i5 2500k 3.30Ghz-OC-[4.60ghz]|Noctua NH-U9B SE2|
|GA-P67A-UD3-B3|R9 290x 4gb|Kingston Blue HyperX 12GB 1600Mhz|
- spremenil: Nemixxx ()
| » | Guild Wars (strani: 1 2 3 4 … 7 8 9 10 )Oddelek: Igre | 42585 (1691) | oo7 |
| » | Kateri MMO?Oddelek: Igre | 6498 (5095) | sash69 |
| » | Tera Online (strani: 1 2 )Oddelek: Igre | 16980 (10290) | r3tro |
| » | MMORPGOddelek: Igre | 2437 (2151) | BorutK-73 |
| ⊘ | Guild Wars 2Oddelek: Igre | 3595 (2335) | Tilen |
