Forum » Pomoč in nasveti » izklapjanje računalnika - moder ekran ?
hlastec ::
Večkrat na dan (konstantno)se mi izklopi računalnik in se pokaže samo moder ekran, kjer mi javlja sledečo napako in sicer:
"A problem has been detected and windows has been shut down to prevent damage to your computor" (na začetku)
-itd(vmes)
-itd(vmes)
"Technical information:
*** STOP: 0x0000000F4 (0x00000003,0x89319748,0x893198BC,0x805D297C)
Beggining dump of physical memory" (na kocu)
Sem že zamenjal več komponent (osnovno ploščo,DDR RAM, Hard disk) ter že večkrat popolnoma sformatiral računalnik ter naložil nov operacijski sistem, driverje,...vendar se še vedno pojavlja enak problem (računalnik se izklopi > pokaže moder ekran z zgoraj navedeno napako > ter ponovno zažene)
Prosil bi,če mi lahko pomagate, če je kdo že imel podobne/enake težave oz. pozna bistvo problema, zakaj se to dogaja in kaj storiti?
lp David
-itd(vmes)
-itd(vmes)
lp David
[ELITE K7S5A, AMD 1600 XP+,256 DDR RAM (2100), ATI RADEON 9000 64MB]
drzni86 ::
si probal zamenjat tud napajalnik? Meni se je to dogajalo ko se je napajalnik poslavljal...
Arto ::
The CRITICAL_OBJECT_TERMINATION bug check has a value of 0x000000F4. This indicates that a process or thread crucial to system operation has unexpectedly exited or been terminated.
Several processes and threads are necessary for the operation of the system. When they are terminated for any reason, the system can no longer function.
Ni ravno preveč v pomoč, ampak tako pravi microsoft.
Vuli ::
Napajalnik zamenjaj.
drzni86 ::
Nisem še videl, da bi napajalnik delal blue screen,računalnik mrkne pa konec!
sploh ni nujno da takoj crkne!
huek111 ::
Citirano
0x000000F4: CRITICAL_OBJECT_TERMINATION
(Click to consult the online MSDN article .)
One of the many processes or threads crucial to system operation has unexpectedly exited or been terminated. As a result, the system can no longer function. Specific causes are many, and often best resolved by a careful history of the problem and the circumstances of the error message. One user, who experienced this on return from Standby mode on Win XP SP2, found the cause was that Windows was installed on a slave drive; compare KB 330100 .
Kolikor razumem je možno,da so windowsi naloženi na slave disku(poglej če imaš disk C priklopljen kot master)
detroit ::
hehe jst pa se na microsoft ne zanašam,
z memtestom preveri rame, potem lahk še pogledaš ker service proggy or whatever je mrknu to z whocrashed
ipd
ipd
Skero
hlastec ::
Downloado sem program "WhoCrashed Home Edition 1.01" ter analiziral računalnik, ki mi je podal nasledenj odgovor in sicer:
Analysis
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
No crash dumps have been found on your computer
------------------------------------------------------------Conclusion
Crash dumps are enabled and no crash dumps have been found on your computer. In case your computer does experience sudden reboots it is likely these are caused by malfunctioning hardware or power failure. Then it's suggsted you contact the support department of the manufacturer of your system or test your system with a memory test utility for further investigation.
Kaj to pomeni?
Analysis
Kaj to pomeni?
bluefish ::
Pomeni, da na računalniku ni noben zapisov o "sesutju".
Kot že povedano, zaženi Memtest.
| » | Težava z računalnikomOddelek: Strojna oprema | 2628 (2058) | BorutK-73 |
| » | BSOD minidump problemOddelek: Pomoč in nasveti | 1273 (1121) | ru7 |
| » | SSD intel 330 win7 instalacijaOddelek: Strojna oprema | 1278 (1157) | klemen1972 |
| » | Blue ScreenOddelek: Pomoč in nasveti | 1571 (1429) | Cold1 |
| » | Problem blue skrin !Oddelek: Pomoč in nasveti | 2088 (1673) | ST-777 |
