Forum » Strojna oprema » SSD intel 330 win7 instalacija
klemen1972 ::
Pri instalaciji 64bit win 7
dobim moder zaslon in sicer
A problem has been detected and Windows has been shut down to prevent damage
to your computer.
The problem seems to be caused by the following file: ntoskrnl.exe
CRITICAL_OBJECT_TERMINATION
If this is the first time you've seen this stop error screen,
restart your computer. If this screen appears again, follow
these steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer
for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware
or software. Disable BIOS memory options such as caching or shadowing.
If you need to use safe mode to remove or disable components, restart
your computer, press F8 to select Advanced Startup Options, and then
select Safe Mode.
Technical Information:
*** STOP: 0x000000f4 (0x0000000000000003, 0xfffffa8008febb30, 0xfffffa8008febe10,
0xfffff80002d848b0)
pri cemer na MB nimam nicesar razen dvd in ssd
lp k
to your computer.
these steps:
select Safe Mode.
0xfffff80002d848b0)
lp k
solatko ::
Imaš v bios-u diske na ASCHI?
Nekatere travniške verzije w7, nimajo tega gonilnika (nekateri pač malo preveč skubijo svoje verzije, poslane na torrent), zato daj na native, instaliraj in potem po postopku, uredi način delovanja diskov.
Delo krepa človeka
OZZY ::
Lahko je problem AHCI .. Samo drajverji za to so vključeni v win7.. samo imajo nekatere plate kljub temu problem. V biosu probaj izbrati IDE compatible al kaj podobnega pa potem inštaliraj in po inštalaciji v winsih usposobi AHCI.. kako pa poglej na netu.
Go with the flow.
klemen1972 ::
Na netu sem masel AHCI in IDE in ne dela
SSD normalno dela ce ga priljucim na drug racunalnik
kot dodatni disk
kot dodatni disk
| » | Kako ugotoviti kaj mi serje? Bluescreeni...Oddelek: Pomoč in nasveti | 3363 (2754) | Cold1 |
| » | Sesuvanje računalnikaOddelek: Pomoč in nasveti | 1714 (1510) | Mitch |
| » | Blue screen problem / windows crashOddelek: Pomoč in nasveti | 1191 (1103) | Xserces |
| » | win 7 bsod - okvara matične ?Oddelek: Pomoč in nasveti | 2403 (2232) | vander |
| » | Težava z zagonom računalnika (strojna napaka?)Oddelek: Pomoč in nasveti | 2221 (2014) | jat2406 |
