Forum » Omrežja in internet » hišno omrežje + težave
tv6865 ::
Pred časom sempovezal vse tri naše hišne računalnike v domače omrežje. Vse je delovalo super do pred kratkim ko meni pod možnostjo = oglejte si računalnike delovne skupine = ne najde nobenga od ostalih dveh računalnikov. Pri oostalih dveh pa še dela kot mora.
Karen ::
Glede na to kar si napisal probaj najprej tole (domnevam da ti internet dela na vseh treh):
1- Open dos prompt, type ipconfig -all.
2- Look at the 'Node Type' it probably says Peer-Peer or something (this is what mine said)
... we want it to say 'Hybrid'
3- Press 'Start' button > Run... > In the box type regedit. This opens your system's registry.
4- Navigate the tree to: HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Services/NetBT/Parameters
5- Rt. mouse click and select New > DWORD Value
6- Name it 'NodeType' (without the quotes)
7- Rt. mouse click on it and select Modify
8- Set Value Data to '8' (no quotes)
9- Leave Base alone. 'Hexadecimal' should be selected
10- Press 'ok'
11- Close regedit and reboot. (Your done!)
12- Open dos prompt and type ipconfig -all
For node type it should now say 'Hybrid'
13- Do this to the other computer that you cannot network. Your computers should be able to see one another.
I do not know what 'Hybrid' is, but perhaps some of the network freaks might be able to explain. I have used this on two different occasions and it seems to be the only thing that works.
Ali pa če ne gre pa še po temle:
http://winhlp.com/node/37
Ali pa pogooglaj "node type hybrid" - mislim da moraš ene dva registry ključa zbrisat... samo poišči katera.
Upam da bo pomagalo.
10- Press 'ok'
| » | Gajba piva za rešitev mrežneag problema Vista-W2KOddelek: Omrežja in internet | 3628 (2752) | just_a_cook |
| » | Računalniki se ne vidijo preko My network placesOddelek: Pomoč in nasveti | 2446 (2307) | BaRtMaN |
| » | Ni file sharingaOddelek: Omrežja in internet | 1456 (1331) | rapvirus |
| » | Kako v Win2k premakniti mapo Documents and Settings?Oddelek: Operacijski sistemi | 2527 (2493) | Mercier |
| » | Logitech MouseWare bug (?)Oddelek: Pomoč in nasveti | 2600 (2196) | Swiwer |
