Forum » Programska oprema » java error
java error
Piksi79 ::
Ko odprem karkoli na netu kar je pisano v javi mi jave ne zažene ampak napiše application failed to run. Če pogledam v java konzolo imam izpisano sledeče:
load: class com.objectplanet.chart.LineChartApplet not found.
java.lang.ClassNotFoundException: com.objectplanet.chart.LineChartApplet
at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unknown Source)
at sun.plugin2.applet.Plugin2Manager.createApplet(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.protocol.https.HttpsClient(Unknown Source)
at sun.net.www.protocol.https.HttpsClient.New(Unkn... Source)
at sun.net.www.protocol.https.AbstractDelegateHttp... Source)
at sun.net.www.protocol.http.HttpURLConnection.pla... Source)
at sun.net.www.protocol.http.HttpURLConnection.get... Source)
at java.net.HttpURLConnection.getResponseCode(Unknown Source)
at sun.net.www.protocol.https.HttpsURLConnectionIm... Source)
at sun.plugin2.applet.Applet2ClassLoader.getBytes(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.access$000(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
... 7 more
Exception: java.lang.ClassNotFoundException: com.objectplanet.chart.LineChartApplet
Sam na žalost ne znam nč kar se javi tiče zato bi prosil za pomoč. Ima kdo idejo kaj bi bilo lahko narobe?
Probal sem javo reinštalirat ampak napaka ostane... to se dogaja tako v firefoxu kot v internet explorerju.
Hvala za pomoč
... 7 more
Hvala za pomoč
- spremenilo: Piksi79 ()
rgv45vg4t335 ::
V Google odtipkaj 'java classpath'.
MSI K9A2 Platinum@260MHz, Athlon X2 4850e@3GHz, 4GB RAM@1000MHz
Radeon HD 4850
Radeon HD 4850
netanyahu ::
To se ti ne dogaja povsod, samo na točno določeni spletni strani. Java ne najde razreda com.objectplanet.chart.LineChartApplet, ki ni standardni del Jave, ampak plačljiva knjižnica za prikazovanje grafov. Natančneje, HTML se sklicuje na datoteko LineChartApplet.class (lahko znotraj arhiva charts.jar), ki pa je brskalnik ne najde. Zateži avtorju spletne strani, na jo spravi v delujoče stanje.
| » | edavki ubuntu 13 chromeOddelek: Omrežja in internet | 6124 (3779) | harvey |
| » | [Java]Problem z zaganjanjem aplikacije na sterznikuOddelek: Programiranje | 2322 (2131) | KernelPanic |
| » | [Java]java.lang.NoClassDefFoundErrorOddelek: Programiranje | 1484 (1387) | KernelPanic |
| » | Težave z java klepetalnicoOddelek: Omrežja in internet | 2199 (2079) | gokky |
| » | java igre na internetu- ne zaženeOddelek: Pomoč in nasveti | 2097 (2001) | kl82 |
