Težave z java klepetalnico
Kajbipadal? ::
Živjo. Ko skušam odpreti klepetalnico na klepet.si, mi napiše napako,
v kateri piše tole:
Java Plug-in 1.6.0_10-rc
Using JRE version 1.6.0_10-rc Java HotSpot™ Client VM
User home directory = F:\Documents and Settings\xxx
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
p: reload proxy configuration
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to n
java.lang.ClassFormatError: Incompatible magic value 1008813135 in class file irc/ParameterProvider
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at sun.applet.AppletClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at sun.applet.AppletClassLoader.loadCode(Unknown Source)
at sun.applet.AppletPanel.createApplet(Unknown Source)
at sun.plugin.AppletViewer.createApplet(Unknown Source)
at sun.applet.AppletPanel.runLoader(Unknown Source)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
java.lang.SecurityException: class "IRCApplet"'s signer information does not match signer information of other classes in the same package
at java.lang.ClassLoader.checkCerts(Unknown Source)
at java.lang.ClassLoader.preDefineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$000(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
Kaj naj naredim, da mi bo klepetalnico odprlo?
Hvala
<b>klima</b> ::
Probaj uninstalirat Java plugin in na namestiti še enkrat. Mogoč potem bo :)
Kajbipadal? ::
Nič ne pomaga.
gokky ::
Počisti brskalnikov in java cache.
Kajbipadal? ::
Pobrisal sem tisto mape v program files od jave, ki sem jih lahko. Skušal sem potem znova inštalirati javo. Ponudi mi reinstall jave, potem pa pove, da je to dejanje veljavno le za izdelke, ki so nameščeni, in okno zapre.
Kako naj zdaj dokončno zbrišem javo z računalnika?
Nihče?
Nihče?
Nihče ne ve?
gokky ::
Si že zamočil. Napisal sem, da pobriši Java Cache (prostor, kjer se medpomnijo programčki, ki jih je JVM izvajal), ne pa programsko kodo za Javo (JVM kot tak). Pa tudi, če si to delal, je vedno prvi korak pri odstranjevanju programov iz Win$, da jih poskušaš odstraniti preko nadzorne plošče, nikakor pa kar brisanje programov iz Program Files.
Sedaj poskusi namestiti Javo brez reinstalacije (torej, da mu rečeš, naj instalira na novo). Če to ne gre, ne bo druge, kot čiščenje registra.
edavki ubuntu 13 chrome
Oddelek: Omrežja in internet
186131 (3786) harvey
[Java]Problem z zaganjanjem aplikacije na sterzniku
Oddelek: Programiranje
122326 (2135) KernelPanic
[Java]java.lang.NoClassDefFoundError
81485 (1388) KernelPanic
E-davki in oddaja dohodnike (bliža se dan) (strani: 1 2 )
869791 (7754) kriko1
java igre na internetu- ne zažene
82099 (2003) kl82
