java igre na internetu- ne zažene
kl82 ::
Problem je nastal ko sem po dolgem času spet želel igrati kakšno igro na www.miniclip.com ko sem ugotovil da nakaterih iger več ne morem igrati. Vedno pridem do sporočila LOADING JAVA APPLET FAILED ko kliknem na sliko se mi odpre možnost Open Java Console v kateri me pričaka tole:
Java Plug-in 1.5.0_06
Using JRE version 1.5.0_06 Java HotSpot™ Client VM
User home directory = C:\Documents and Settings\programerji
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
p: reload proxy configuration
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to < n >
load: class loader.class not found.
java.lang.ClassNotFoundException: loader.class
at sun.applet.AppletClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadCode(Unknown Source)
at sun.applet.AppletPanel.createApplet(Unknown Source)
at sun.plugin.AppletViewer.createApplet(Unknown Source)
at sun.applet.AppletPanel.runLoader(Unknown Source)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.io.IOException: open HTTP connection failed.
at sun.applet.AppletClassLoader.getBytes(Unknown Source)
at sun.applet.AppletClassLoader.access$100(Unknown Source)
at sun.applet.AppletClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
... 10 more
Exception in thread "Thread-4" java.lang.NullPointerException
at sun.plugin.util.GrayBoxPainter.showLoadingError(Unknown Source)
at sun.plugin.AppletViewer.showAppletException(Unknown Source)
at sun.plugin.AppletViewer.showAppletStatus(Unknown Source)
ker o tem nimam pojma bi prosil da mi kdo razloži ali pa kaj naj naredim.
Javo sem tudi že izbrisal in ponovno namestil in ni pomagalo (najnovejšo verzijo). Poskusil sem tudi z Opero, Mozilla in Mozilla Firefox in povsod isto. (No pri operi ma vsaj vpraša ali naj dovolim javi privilegij da se zažene)
Pri java Control panel/advanced imam izbrano podporo za Internet Explorer in Moziolo.
Tudi v Internet Explorerju imam izbrano pod ''internet možnosti/dodatno/java'' - klukco
Že v naprej hvala za pomoč pa prosim ne mi pisat naj naredim formacijo...:)
Internet je bil postavljen za združevanje ljudi, ne zaradi korupcije in drugih smrtnih grehov. kl82
farko ::
Zgleda da imaš dobro zaščiten pc.Malo poglej nastavitve in poskusi še enkrat inštalirat javo.Mislim pa da ni problem v javi ampak v macromediji flash player.
odgovor če hočeš
farko
kl82 ::
V macromediji flash player-ju nebi reku da je težava čeprav sem ga po tvojem pismu reinstaliral in ni pomagalo. Tudi java mi po četrti reinstalaciji iz različnih internet strani ni uspela prikazati rezultata. Še vednoo isti problem.
Prosim še kakšno idejo.
Pa hvala za tole četudi....
kopernik ::
Čist možno, da so nekatere starejše igre odvisne od nečesa, kar ni več prisotno v JRE 1.5. Napaka ClassNotFoundException že kaže na to. A nič ne piše na tisti strani, kakšne so zahteve za posamezno igro ?
kl82 ::
Ja za mojo igro potrebuješ vsaj 300mhz in 64mb (minimalno). Sicer pa je do sedj še vedno delala na Win XP. Za več info. pa da se izdam to je igra rune scape.
http://www.miniclip.com/runescape_game....
No ja hvala
kopernik ::
Sem preizkusil in z JDK 1.4.2 dela ok. Torej je očitno problem to, kar sem že omenil in sicer je JDK 1.5.x novejši, zato najbrž igra ne dela. Tudi, ko berem razne dokumente na googlu (za to igro) se povsod omenja javo 1.4.x. Očitno še niso priredili igre za jdk 1.5.
Rešitev : namesti si Javo 1.4.2.
kl82 ::
Hvala za rešitev čeprav ti bom rezultat povedal šele po novem letu ker zapuščam računalnik tako da lepo praznujte...
ps: hvala kopernik
kl82 ::
Java Runtime Environment Version 5.0 Update 6 - pri frendu dela s tem men pa žal ne...
Pa tudi po naložitvi in inštalaciji ''j2eesdk-1_4_02_2005Q2-windows'' oz Java 2 Platform, Standard Edition, v 1.4.2 (J2SE)
ni nič drugač :'(
kl82 ::
Odkril sem kaj je bilo izgleda da nisem imel nameščenega Microsoft Virtual Machine (mislil sem da se on avtomatično namesti na računalnik ob inštalaciji) no skratka tale stran me je po 6 dnevem iskanju rešila http://www.delta-knight.co.uk/ms_vm.sht...
Hvala vsem ki ste mi pomagal:)
Zdej pa igrat!!
edavki ubuntu 13 chrome
Oddelek: Omrežja in internet
186124 (3779) harvey
[Java]Problem z zaganjanjem aplikacije na sterzniku
Oddelek: Programiranje
122322 (2131) KernelPanic
[Java]java.lang.NoClassDefFoundError
81483 (1386) KernelPanic
Težave z java klepetalnico
52199 (2079) gokky
E-davki in oddaja dohodnike (bliža se dan) (strani: 1 2 )
869778 (7741) kriko1
