Forum » Pomoč in nasveti » Msn messinger 8.5 se ne poveže
nokia6310 ::
Pozdravljeni, Danes sem prvič naletel na ta problem, inštaliram msn 8.0 in se hočem prijavit z njim, pa ne gre, ker sem ga moral updejtati na verzijo 8.5.
Ko sem to storil, sem dobil,med prijavljanjem naslednjo sporočilo o napaki:
Windows Live Messenger
Windows Live Messenger has encountered a problem and needs to close.
We are sorry for the inconvenience.
If you were in the middle of something, the information you were working on might be lost.
Please tell Microsoft about this problem.
We have created an error report that you can send to help us improve Windows Live
Messenger. We will treat this report as confidential and anonymous.
What data does this error report contain?
Error signature
AppName: msnmsgr.exe AppVer: 8.5.1302.1018 AppStamp:4717a53b
ModName: unknown ModVer: 0.0.0.0 ModStamp:00000000
fDebug: 0 Offset: 00000000
Reporting Details
This error report includes: information regarding the condition of Windows Live Messenger when the
problem occurred; the operating system version and computer hardware in use; your Digital Product
ID, which could be used to identify your license; and the Internet Protocol (IP) address of your
computer.
We do not intentionally collect your files, name, address, email address or any other form of personally
identifiable information. However, the error report could contain customer-specific information such as
data from open files. While this information could potentially be used to determine your identity, if
present, it will not be used.
The data that we collect will only be used to fix the problem. If more information is available, we will tell
you when you report the problem. This error report will be sent using a secure connection to a
database with limited access and will not be used for marketing purposes.
View the contents of the error report.
Error signature
Reporting Details
computer.
nokia6310 ::
Kaj naj še probam narediti?
Na googlu sem iskal za to napako, pa piše, da naj bi bil nek virus.
Kolikor pa vem, trenutno nimam nobenega.
nokia6310 ::
Evo tudi ta problem sem rešil.
Problem je bil v okuženi dadoteki, ki jo je panda antivirus uspešno odstranil.
Po odstranitvi sem se lahko prijavil v msn, brez problemov.
| » | Težave z odpiranjem programaOddelek: Pomoč in nasveti | 5330 (4766) | konspirator |
| » | [INFO] Windows Live Messenger/MSN Messenger (strani: 1 2 3 4 5 )Oddelek: Programska oprema | 79519 (20160) | tilinho20 |
| » | Ugašanje računalnika (samodejno resetiranjeOddelek: Pomoč in nasveti | 3049 (2404) | Aleš Ocepek |
| » | težave z inštalacijo msn-jaOddelek: Pomoč in nasveti | 1537 (1448) | Dragoyx |
| » | Apache - localhost JA, IP naslov NEOddelek: Omrežja in internet | 7284 (7143) | ManDriver |
