Forum » Pomoč in nasveti » Težave z odpiranjem programa
Tropex ::
Pozdravljeni,
Program: Sketchbook pro 2015
Računalnik: HP PRO BOOK 470 G0
pred dvema tednoma sem formatiral windose in vse na novo naložil, ter uredil update. Nato sem naložil takoj program, ki mi je pred tem zmeraj delal normalno.
Program je delal do zadnje sobote vse normalno. Potem pa sem opazil da na laptopu nimam inštalirano možnost osvelitev / zatemnitev zaslona s tipkovnico, zato sem šel na spletno stran hpja in inštaliral potrebno, ter še nekaj dodatnih stvari od laptopa.
Naj še dodam da ta laptop ima grafično kartico AMD RADEON HD 8750M. Preko updatov mi je naložilo od intela, zato sem dodal še jaz posebej od radeona.
Ne spoznam se na računalnike, toliko kolikor na svoje delo, zato sem tudi to inštaliral.
Zdaj pa vsakič ko prižgem program, se noče odpreti in dobim obvestilo:
Error signature: - application: skethcbook pro
- version 201406030532-432968
- Error: unhandled exception
this error report includes the following:
- operating system name and version
- product name and version
- graphics configuration driver name and version
- application that were loaded when error occurred
- active command when the error occurred
- computer name ( if enabled via the deployment wizard or the cad manager control utility)
Report contents: the error report contains the following files:
- CERDmp.dmp (C:\Users\Irnes\AppData\Roaming\Autodesk\Sketchbookpro\2015\CERDmp.dmp)
File details: A minimal dump of your system's memory that will be used to diagnose this error.
- dmpuserinfo.xml
(C:\Users\Irnes\AppData\Local\Temp\dmpuserinfo.xml)
File details: Contact data (if provided) and information collected from your system.
- dumpdata.zip
(C:\Users\Irnes\AppData\Local\Temp\dumpdata.zip)
File details: Compressed file that contains the other files included in this error report.
Če kdo pozna težavo, bi ga zelo lepo prosil za pomoč.
Hvala,
Tropex Art
- dmpuserinfo.xml
- dumpdata.zip
Hvala,
Tropex Art
Tropex ::
Tropex ::
Najdi kak starejši installer in provaj.
Odstrani vse file in datoteke, ki jih pusti na disku z Revo Unistaller, potem poskusi znova.
Kako pa imaš licenco retail? Ker vidim da ima SB tudi mesečno naročnino za 10$. Kako je s tem?
A se ti zafrkavaš z crackano verzijo?
Tropex ::
Imam crackano verzijo. Ma najmanjši problem plačat teh 10$ glede na to da ga nujno rabim sam se sprašujem a bo pol delal...
Kako pa dobim / naredim ta revo unistaller?
https://www.revouninstaller.com/revo_un...
Lahko preizkusiš s free verzijo ali se znajdeš po svoje..
Pomembno je da po tem ko daš unistall, da daš advanced (scanning), ki najde vse ostanke map, za katere sploh ne veš da so ostale.
Če niti nimaš inštaliranega, provaj vseeno najti(traced programs).
Še prej pobriši vse omenjene mape in provaj šeenkrat install..
- dmpuserinfo.xml
- dumpdata.zip
- dmpuserinfo.xml
- dumpdata.zip
Tropex ::
- dmpuserinfo.xml
- dumpdata.zip
Ok bom danes probal s tem vse pobrisati pa še enkrat na novo inštalirati.
kar se tiče teh map...jih ne najdem...to je še bolj čudno :)
To so skrite mape.
https://www.isunshare.com/windows-10/sh...
Tropex ::
To so skrite mape.
Živjo,
evo probal sem...inštaliral sem ta program za unistall...mi je zbrisal ''vse'' od tega programa. Kar ni, sem našel sam tudi tiste skrite mape sem našel in vse zbrisal sploh tiste katere kaže da so težavne...
ko sem vse zbrisal sem restartal računalnik, na novo inštaliral program...in ...vse enako :)
Ima še kdo kakšno idejo?
[D]emon ::
Ja, kupi program.
Tropex ::
Ena random ideja. Sklopi firewall in AV med inštalacijo.
ngc2392 ::
Kaj pa če ti sistem program zažene z intelovo kartico in ne radeonko? poskusi v nastavitvah nastaviti radeona nastaviti, da ti bo vedno zagnal z radeon grafično?
za namestitev pa poglej, če je offline installer na voljo...
United We Stand, Divided We Fall
Mogoče pomaga:
https://forums.autodesk.com/t5/autocad-...
https://knowledge.autodesk.com/support/...
Tropex ::
No tako je.
Hvala vsem za pomoč.
Zgodilo se je tako:
Najprej sem še poskušal crackano verzijo inštalirati...ni šlo.
Potem sem kupil licenčno verzijo in mi ni želelo sploh zdownloadati oz. inštalirati.
Potem pa sem šel na pir!
Ko sem prišel nazaj sem probal 2015 verzijo crackano inštalirati. Mi inštalira...probam...dela!
Ampak me je pa morilo, ker sem plačal 2018 verzijo pa mi ne dela. Tako da sem pisal na njihov helpdesk in so mi pisali. Ko plačaš, dobiš v svoj management download file. Tam pa potem izbereš med tremi opcijami kako zdownlaodati / inštalirati. In so mi rekli naj izberem neko tretjo možnost in sem zjutri na hitro inštalirati in je vse delalo.
Tako da imam zdaj obe verziji delujoče.
Za koliko časa pa nevem.
Zgodilo se je tako:
konspirator ::
https://docs.microsoft.com/en-us/sql/ss...
Make the following actions to reduce the chances of SSMS setup requiring a reboot at the end of installation:
Make sure you are running an up-to-date version of the Visual C++ 2013 Redistributable Package. Version 12.00.40649.5 (or greater) is required. Only the x64 version is needed.
Verify the version of .NET Framework on the computer is 4.6.1 (or greater).
Close any other instances of Visual Studio that are open on the computer.
Make sure all the latest OS updates are installed on the computer.
The noted actions are typically required one once. There are few cases where a reboot is required during additional upgrades to the same major version of SSMS. For minor upgrades, all the prerequirements for SSMS will already be installed on the computer.
BivšiUser2 ::
VS2015 isolated shell je pomagal, samo ga je prekleto težko najti.
SloTech - če nisi z nami, si persona non grata.
| » | Težava z računalnikom - prosim za pomočOddelek: Pomoč in nasveti | 6054 (5783) | iloveboobz |
| » | Undo za ComboFixOddelek: Pomoč in nasveti | 2420 (2185) | MrStein |
| » | Stalni Bluescreen in pad sistemaOddelek: Pomoč in nasveti | 1933 (1824) | SLO_Matej |
| » | BSODOddelek: Pomoč in nasveti | 1781 (1673) | shark_nm |
| » | V normalnem zagonu BSOD (moder ekran); v Safe mode vse delujeOddelek: Pomoč in nasveti | 2185 (2025) | ZaLoMaT |
