Forum » Pomoč in nasveti » Ugašanje računalnika (samodejno resetiranje
andrej25 ::
Računalnik se mi resetira po zagonu igre!
Napiše pa mi tole v plavem ekranu
A problem has been detected and windows has ben shut down to prevent damage to your computer
If is the problem first time you ve seem this stop error screen restart yuor computer, if thes screen apears aganin follow these steps :
Check to be sure you have adequate disc space, if a river is identified in the stop message, disable the driver or check with the manufacture for driver updates, try changing video adapters
Check with your hardware vendor for any bios updates, disavle bios memoryoptiones such as caching or shadowing, if you need to use safe mode to remove or disable components. Restart your computer, pres f8 to select advanced startup options. And then select safe mode
Tehnical information:
stop : 0x0e (0x05. 0x0f. 0b200ab30, 0x0)
begining dump of spyhical memory
psyhical memory dump complete
Hvala za odgovore, to se ponavlja vedsno bolj pogosto, formatiranje com. Ne pomaga!
- polepsal: OmegaBlue ()
andrej25 ::
NAŠU NA INTERNETU NEKE NAPAKE KAR BI LAHKO BILE ,
SHTDN_REASON_MAJOR_OTHER
0x00000000 Other issue.
SHTDN_REASON_MINOR_BLUESCREEN
0x0000000F Blue screen crash event.
SHTDN_REASON_MINOR_HUNG
0x00000005 Unresponsive
SHTDN_REASON_MINOR_OTHERDRIVER
0x0000000e Other driver event
raćunalnik pa mam :
AMD Athlon™ XP 2500+
1.82 GHz
1G ram
ATI Radeon 9200 SE
matična ASUS A7V600-X
Windows XP sp-2
raćunalnik pa mam :
1.82 GHz
1G ram
ATI Radeon 9200 SE
Windows XP sp-2
Spike Edin ::
Živjo!
Si preveril kako se temp. processorja in grafične kartice vrti? Testiral ram? Priporočen program za test RAM-a je memtest86 ( Link: http://www.memtest86.com/ !
Lp!
Lp!
The PC Doctor
andrej25 ::
Pozdravljeni , sm rešu problem !!!
Naložu sm si driverje za grafično kartico ATI CATALISTIC CENTER ! in use špila kukr more :)
vsem pa ki ste pomagali najlepša hvala !
se priporočam za še kdaj :)
LP Andrej
LP Andrej
Aleš Ocepek ::
Zdravo imam problem računalnik se mi samodejno resetira in ko se resetira se mi pokaže sporočilo... Kaj naj naredim?
Aleš Ocepek ::
Evo tole mi napiše: A log of error has been created. Please tell Microsoft about problem. Wehave created an error report that you can send to helpus improve Microsoft Windows. We will treat this report as confidential and anonymous.
Aleš Ocepek ::
Imam isti problem kot andrej 25. Prosim pomagajte
Oz. meni se firefox sesuva
- spremenil: Aleš Ocepek ()
Aleš Ocepek ::
Zdravo! Imam problem in sicer: ko grem na internet in si hočem ogledati kakšen video na yotutbu se mi adobe flash player sesuje in firefox tudi. Ko se to ponovi npr.3 se mi prikaže sporočilo A problem has been detected and windows has ben shut down to prevent damage to your computer
prosim za pomoč! Hvala
| » | Problemi...Oddelek: Pomoč in nasveti | 2480 (1810) | Cifix63 |
| » | samodejni vklop in izklop računalnikaOddelek: Pomoč in nasveti | 2893 (2717) | RuskiSnajper |
| » | plata zjebava z modrim zaslonom smrti !!!Oddelek: Pomoč in nasveti | 1853 (1640) | SavoS |
| » | Resne težave s Win XP!!?Oddelek: Pomoč in nasveti | 2365 (1850) | alyF |
| » | nasvet za XPOddelek: Pomoč in nasveti | 4283 (3875) | [t502] |
