Forum » Operacijski sistemi » XP ukazna vrstica, ne prepozna ukaza?
madmitch ::
A mi lahko nekdo razloži, kaj sem zaj****, da mi nobenega ukaza ne prepozna.
Takole mi napiše:
Takole mi napiše:
Microsoft Windows XP [Version 5.1.2600]
© Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Miha>ping www.google.com
'ping' is not recognized as an internal or external command,
operable program or batch file.
madmitch ::
Za vse take gnoje, kot sem jaz, ki ne vprašajo najprej strička Googla.
Tkole je to:
For Windows XP:
Right click "My Computer" and click "Properties". Click the "Advanced" tab up top followed by the "Environment Variables" button at the bottom. In the 2nd list box, scroll down to the 5th or 6th entry "Path", select it and click "Edit". Add "%SystemRoot%\system32;%SystemRoot%;" (minus the quotes) to the beginning of the line. Okay the changes and try out your commands now.
Tkole je to:
For Windows XP:
| » | ping težava s start /run menijuOddelek: Pomoč in nasveti | 1334 (1246) | Duhec |
| » | Windows XP - DOS komandeOddelek: Operacijski sistemi | 1516 (1393) | JanezB |
| » | MSN datoteke čez 6GBOddelek: Programska oprema | 2036 (1853) | Vuli |
| » | Kako v Win2k premakniti mapo Documents and Settings?Oddelek: Operacijski sistemi | 2541 (2507) | Mercier |
| » | Kako obdržati linke do aplikacij, register in ostalo, ko reinštaliraš WinXP???Oddelek: Operacijski sistemi | 1963 (1711) | Lith |
