Forum » Pomoč in nasveti » Linksys WRT54GL : Transmission Rate / Basic rate
Tilen ::
Slučajno kdo ve kaj sta ti dve možnosti na Linksysu za wireless : Transmission Rate [1-54Mbps] ali pa Basic rate [1-2Mbps, Default, All]
A to pomeni, da se dejansko da omejit povezavo tistemu, ki se brezžično povezuje na 1-2Mbit ali so to samo iluzije? V primeru, da to drži, kako se potem nastavi, da je lokalno možno prenašat z "do 54Mbps", širokopasovno pa 1-2Mbit? Se da kontrolirati tudi upload?
Tilen ::
Transmission Rate
The default setting is Auto. The range is from 1 to 54Mbps.
The rate of data transmission should be set depending on the speed of your wireless network. You can select from a range of transmission speeds, or keep the default setting, Auto, to have the Router automatically use the fastest possible data rate and enable the Auto-Fallback feature. Auto-Fallback will negotiate the best possible connection speed between the Router and a wireless client.
Basic Rate
The default value is set to Default. Depending on the wireless mode you have selected, a default set of supported data rates will be selected. The default setting will ensure maximum compatibility with all devices. You may also choose to enable all data rates by selecting ALL. For compatibility with older Wireless-B devices, select 1-2Mbps.
Nič ne bo.
Basic Rate
Nič ne bo.
| » | Dishonored 2: Darkness of Tyvia (strani: 1 2 3 )Oddelek: Igre | 27046 (16950) | ahac |
| » | WiFi modem in telefon na 2.4 GHz - se motita?Oddelek: Omrežja in internet | 1986 (1592) | pirx |
| » | moč wifijaOddelek: Omrežja in internet | 2541 (2131) | Ribič |
| » | Linksys wrt160nlOddelek: Omrežja in internet | 1655 (1179) | Hayabusa |
| » | WIN XP tweaksOddelek: Operacijski sistemi | 1450 (1217) | boštjan |
