Forum » Slo-Tech » PODPIS
PODPIS
pŁexXxi§ ::
mene pa zanima kak si narediš podpis v svojem imenu,da bi se prikazal spodi ob vsakem mojem sporočilu ??
sem vse že izbrskala pa ne najdem !?
HELP.
hvala
HELP.
hvala
Jaz dobim zanimiv error
There is a problem with this website's security certificate.
The security certificate presented by this website was not issued by a trusted certificate authority.
Security certificate problems may indicate an attempt to fool you or intercept any data you send to the server.
We recommend that you close this webpage and do not continue to this website.
Click here to close this webpage.
Continue to this website (not recommended).
More information
If you arrived at this page by clicking a link, check the website address in the address bar to be sure that it is the address you were expecting.
When going to a website with an address such as https://example.com, try adding the 'www' to the address, https://www.example.com.
If you choose to ignore this error and continue, do not enter private information into the website.
For more information, see "Certificate Errors" in Internet Explorer Help.
More information
strictom ::
Bedak. Kwa pa uporabljaš https če ne znaš sprejet certifikata.
mavec ::
strictom, bolje, da se vzdržiš žaljenja.
Ni vredno tvegati za tako stvar naziva.
- spremenil: mavec ()
| » | [Opera] Unable to complete secure transactionOddelek: Slo-Tech | 3454 (2198) | pegasus |
| » | Problem pri prijavi na Slo-TechOddelek: Slo-Tech | 1381 (1260) | smoke |
| » | Storitve E-upraveOddelek: Programska oprema | 8119 (7794) | qwzyx |
| » | Spletno oko ne zagotavlja anonimnosti?Oddelek: Novice / Zasebnost | 7260 (5185) | winifred |
| » | IE 7 težave - pomočOddelek: Pomoč in nasveti | 1462 (1373) | awake |
