Problem pri prijavi na Slo-Tech
smoke ::
Pozdravljeni!
Imam težavo z prijavo na forum in sicer mi Chrome da tale error:
Error 2 (net::ERR_FAILED): Unknown error.
Poskusil sem pravtako z Firefoxom in dobil error:
An error occurred during a connection to slo-tech.com.
Unable to generate public/private key pair.
(Error code: sec_error_keygen_fail)
Probal sem z brisanjem piškotkov in zgleda ni nobenega efekta. Sistem je na novo nameščen Arch Linux z vsemi updejti. Browserja sta: Chrome (verzija 19.0.1061.1) in Firefox (verzija 10.0.2).
Kakšna ideja?
Lep pozdrav
matej_jack ::
Isti problem imam jaz na Fedori, firefox 10.0.1. Sem mislil, da sem edini :D
Vse ostale https strani delujejo brez težav, po drugi strani pa tudi slotech odpre v rekonq ali operi. :8)
technolog ::
Meni na Arch linux vse deluje.
smoke ::
matej_jack, pri meni je enako, vse ostale https strani delajo, slo-tech pa ne. Dela pa recimo v Konquerorju.
technolog ::
Aja to vi o HTTPS? Potem pa tudi meni ne dela.
Firefox:
Secure Connection Failed
  The page you are trying to view can not be shown because the authenticity of the received data could not be verified.
  Please contact the website owners to inform them of this problem. Alternatively, use the command found in the help menu to report this broken site.
Chrome:
This webpage is not available
The webpage at https://slo-tech.com/ might be temporarily down or it may have moved permanently to a new web address.
Opera dela.
amigo_no1 ::
Katera verzija FF in Chrome ne delata preko https ?
smoke ::
technolog, login.php je na https, tako da se pač ne morš prijavit :)
Ne odpre dveh strani v Firefoxu - Secure Connection Failed
61186 (1113) nsa_ag3nt
[c#] in sql baza
Oddelek: Programiranje
161757 (1256) japol
HP Pavilion dv7 reboot problem
92656 (2589) Yacked2
Preverjanje, če je spletna stran enaka
81741 (1400) Hayabusa
Firefox 3 in klik nlb
Oddelek: Programska oprema
3220906 (16725) solatko
