PODPIS
PODPIS
pŁexXxi§ ::
mene pa zanima kak si narediš podpis v svojem imenu,da bi se prikazal spodi ob vsakem mojem sporočilu ??
sem vse že izbrskala pa ne najdem !?
HELP.
hvala
LapD ::
Klikneš na svoj vzdevek zgoraj desno -> forum -> Podpis: ni podatka -> blablabla -> pošlji
STASI ::
"WAR IS PEACE, FREEDOM IS SLAVERY, IGNORANCE IS STRENGTH"
abcčdefghijklmnoprsštuvzž
Jaz dobim zanimiv error
There is a problem with this website's security certificate.
The security certificate presented by this website was not issued by a trusted certificate authority.
Security certificate problems may indicate an attempt to fool you or intercept any data you send to the server.
We recommend that you close this webpage and do not continue to this website.
Click here to close this webpage.
Continue to this website (not recommended).
More information
If you arrived at this page by clicking a link, check the website address in the address bar to be sure that it is the address you were expecting.
When going to a website with an address such as https://example.com, try adding the 'www' to the address, https://www.example.com.
If you choose to ignore this error and continue, do not enter private information into the website.
For more information, see "Certificate Errors" in Internet Explorer Help.
strictom ::
Bedak. Kwa pa uporabljaš https če ne znaš sprejet certifikata.
mavec ::
strictom, bolje, da se vzdržiš žaljenja.
Ni vredno tvegati za tako stvar naziva.
  • spremenil: mavec ()
kuglvinkl ::
Če bi imel AMD-ja, pol bi šlo, tko pa ne. A to se ti na AMD-ju dogaja??!!!
[Opera] Unable to complete secure transaction
Oddelek: Slo-Tech
243453 (2197) pegasus
Problem pri prijavi na Slo-Tech
Oddelek: Slo-Tech
61380 (1259) smoke
Storitve E-uprave
Oddelek: Programska oprema
138119 (7794) qwzyx
Spletno oko ne zagotavlja anonimnosti?
Oddelek: Novice / Zasebnost
377257 (5182) winifred
IE 7 težave - pomoč
51462 (1373) awake
