Forum » Programska oprema » internet explorer in bittorent
slemo ::
Imam težavo pri odpiranju bittornadota.
Ko hočem iz spleta klikniti na totrrent povezavo za download mi takoj explorer javi napako.
Če torrent shranim na disk pa deluje in zažene program in začne download.
Printscreen napake -
http://www.wikiupload.com/download_page...
marsovcek ::
a. v objavah delaj normalne povezave
b. sliko napake daj na shrani.si ali mojalbum.com ali kaj podobnega, kjer se jo bo dalo normalno(!) videti
c. Poskusi sledeče:
1. Open Explorer, Tools -> Options -> File Types
Look for TORRENT in the list, then change the association to µTorrent
2. Make sure you associated torrents with µTorrent (button greyed out in General Options)
3. in µtorrent try going to Options-->preferences-->General tab.
push "associate with .torrent files".
4. also check "check association on startup".
try opening your torrent file again and see if that helps
5. Try enabling gui.compat_diropen in the Advanced Preferences.
6. And try re-associating torrents with uT in the preferences.
c. Poskusi sledeče:
| ! | [P2P] BitTorrent - Naslednja generacija P2P (strani: 1 2 3 4 … 36 37 38 39 )Oddelek: Omrežja in internet | 539779 (1050) | karafeka |
| » | Kateri program za Torrent uporabljate? (strani: 1 2 )Oddelek: Programska oprema | 14464 (11428) | "KeKc" |
| » | BitTorrent TrackerOddelek: Izdelava spletišč | 2470 (1802) | hamax |
| » | pocasnost brskanja pri uporabi utorrentOddelek: Pomoč in nasveti | 2696 (2467) | mmaestro |
| » | BITcomet 0.84, nima IE address bara (iskalniika)Oddelek: Programska oprema | 1847 (1798) | adisitko69 |
