Forum » Problemi človeštva » Iran - odštevanje
Iran - odštevanje
Double_J ::
http://presstv.com/detail/2012/09/16/26...
Mislim da ta fatwa več ne velja, ker Iranci denarja ne morejo izplačati, saj jim ga je zmanjkalo. Morda bo nažalost spet veljavna, če bodo ZDA dvignile sankcije...
Dve šivanki...
Double_J ::
Based on an ISIS assessment, Iran is expected to achieve a critical capability in mid-2014, which is defined as the technical capability to produce sufficient weapon-grade uranium from its safeguarded stocks of low enriched uranium for a nuclear explosive, without being detected. Iran would achieve this capability principally by implementing its existing, firm plans to install thousands more IR-1 centrifuges, and perhaps a few thousand IR-2m centrifuges, at its declared Natanz and Fordow centrifuge sites. Iran's criticality date could be achieved a few months earlier if Iran successfully deploys and operates several thousand IR-2m centrifuges and continues installing thousands of IR-1 centrifuges.
http://isis-online.org/isis-reports/det...
http://www.debka.com/article/23447/Secr...
Mislim da bodo Francozi primorani zopet blokirati slabe kupčije...
Dve šivanki...
- spremenil: Double_J ()
Isotropic ::
kljuc je v temu, kako je ta critical capability definirana.
tut ko majo enkrat enriched uran, je se vedno problem narediti tako raketo, ki bo pasala na SRBM, IRBM... in to ne majhen problem.
Double_J ::
Nekako tako, da ko se odločiš, imaš v parih tednih dovolj obogatenega urana za bombo. Pač imaš postavljenih dovolj centrifug in medtem ko IAEA ni, lahko dovolj obogatiš zadevo, preden pride spet na kontrolo.
http://www.brusselsjournal.com/node/1857
Ja... Francija zelo veliko dolguje svetu. Seveda se pričakuje, da bo zastopala zelo stroge pogoje za morebitni dogovor. Mislim ne vem kako so Iranci lahko sploh presenečeni.
Evo Netanyahu je podal usmeritve...
http://www.timesofisrael.com/netanyahu-...
Dve šivanki...
Isotropic ::
kaj ima veze, ce majo nekaj obogatenega urana?
kot dirty bomb itak ni ucinkovit prevec + v primeru uporabe bi iran itak zbrisali z zemljevida, do prave jedrske SRBM, IRBM pa rabis se ogromno casa. 10 let bp zaradi vseh sankcij.
poleg tega tut nimajo velik vec valute za placevat korejce alpa pakistance.
- spremenil: Isotropic ()
Double_J ::
Ne rabiš veliko časa... pomojem kakšno leto dni, poleg tega to ne moreš odkriti. To bodo lahko naredili v navadni garaži.
Drugače pa, kar se tiče bogatenja:
According to a Maariv report Sunday, Israeli officials have come to terms with the fact that a partial deal with Iran will be signed, possibly as soon as this month. However, they say two clauses favorable to Israel’s stance will be added, namely demanding that the Arak heavy water reactor be kept shut and the uranium enriched to over 20 percent be converted into fuel rods.
http://www.timesofisrael.com/pm-iran-de...
Ja tole ne vem če bo to lahko preprečilo karkoli, ker ima Iran instaliranih že preveč centrifug. Namreč:
Neither is a cap sufficient on the amount of 19.75 percent low enriched uranium (LEU) that Iran can stockpile. A cap is useful but Iran has installed the centrifuge capability to rapidly make a considerable amount of near 20 percent LEU, so it could overcome any cap within a few months, while professing to need this LEU for its civil nuclear program. It is in any case slowly building up toward the limit imposed by the international community, namely that it produce no more than about 250 kilograms of near 20 percent LEU hexafluoride. As of June 2013, it possessed about 180 kilograms. Iran’s stockpile of near 20 percent LEU hexafluoride certainly affects how rapidly Iran could breakout, making a cap worthwhile. By itself, however, this cap cannot prevent Iran reaching a critical capability.
Dve šivanki...
Double_J ::
Z 20.000 instaliranimi cetrifugami, kolikor jih imajo, ne bo ta stvar nikoli varna. Mogoče z 2.000, če vse ostale odmontirajo stran...
V končni fazi imajo lahko par tisoč centrifug prve generacije, ki bogatijo do največ 3,5%. In sproti se to potem pretvarja v gorivo, ne pa da se nabira po 10 ton tega materiala nepretvorjenega. No a bodo sprejeli to?
Dve šivanki...
Double_J ::
http://www.isis-online.org/uploads/isis...
Tole je pa še druga zadeva... zakaj imajo tako radi reaktor na težko vodo?
Heavy water = heavy sanctions.
Dve šivanki...
Isotropic ::
poglej, kaj se je zgodilo z arafatom, ko je opustil program jedrskega orozja.
alpa assadom, mubarakom... me nebi nic cudilo, ce bi se cez par (10) let izvedelo, da je mela 'murika prste vmes (vsaj z egiptovsko vojsko je mela kar dobre odnose).
Sakin ::
:))) Arafatov jedrski program, mislim, kaj nekateri kadite v slo.
Na Nach Nachma Nachman Meuman!
Sakin ::
Jaz sem pa mislil, da je umrl za posledicami aidsa :) Kako so našli po 8ih letih dokaze o poloniju je pa tudi kvantni problem, glede na to da ima element razpolovno dobo pol leta.
Double_J ::
No sej... Iran bo sprejel samo tak dogovor, kjer bo lahko vseeno izdelal jedrsko orožje, to je dejstvo. Če Iran sprejme... potem lahko izdela jedrsko orožje, čeprav se morda zdi, da ga ne more. Sej vidite na temle linku kako so blizu cilja... a zdej bodo pa kar odnehali? Kako lahko to verjamejo tisti naivni pogajalci v Ženevi?
http://isis-online.org/uploads/isis-rep...
Eto jaz vam prevedem v ustrezno obliko, kaj Iranci pravijo:
Iran's Rouhani warns West against 'excessive' nuclear demands
excessive nuclear demands = demands which would prevent us from building a nuclear weapon.
http://www.bbc.co.uk/news/world-middle-...
Dve šivanki...
Double_J ::
No glejte...
wtf?
Akbar Salehi, head of the Atomic Energy Organization of Iran, told Reuters that their 20% enrichment production, was going "very well," adding "There is no limit on enrichment. We can enrich up to 100% ... But we never had the intention and we do not have the intention to do so, unless we need (to)."
wtf?
Dve šivanki...
Hayabusa ::
razpolovna doba je statistično ... da bo polovica materiala razpadla na drug izotop, pa verjetno lahko v obratni smeri določijo kaj je bilo prvotno na znano časovno obdobje...
Double_J ::
Uglavnem, če bodo Iranci obogatili na 100% in izmaknili ta material, ter ga nekje skrili, da se ga ne bo dalo več najti in ga ne bodo hoteli več vrniti nazaj... potem bo Izraelu ostala samo še ena opcija. In to bo EMP napad, ki bo Iran pripeljal v kameno dobo.
Je tako ali ni?
Je tako ali ni?
Dve šivanki...
Double_J ::
Po moje ne. Dvomim, da si lahko privoščijo odkrito vojno.
V tem primeru ne bo nobene vojne. Če bo EMP eksplodiral, bo edino kar boš slišal kako pripeljati v Iran dovolj reševalnih ekip, da poskrbijo za 80 milijonov ljudi, ki so ostali brez elektrike in vseh ostalih nujnih potrebščin.
Dve šivanki...
Double_J ::
O kakem EMP ti sanjaš?
To se bo zgodilo v primeru, da Iran izmakne 100% obogaten uran in ga noče vrniti nazaj, saj bo edina preostala opcija, da se prepreči razvoj jedrske bombe.
Others have speculated that Israel will also produce an EMP that will send Iran back to the Stone Age. “If Israel chooses one of its Jericho III missiles to detonate a single EMP warhead at high altitude over north central Iran, there will be with no blast or radiation effects on the ground,” writes Joe Tuzara for Arutz Sheva, the ultra-religious Zionist media network.
Coupled with cyber-attacks, Iranians would not know it happened except for a massive shutdown of the electric power grid, oil refineries and a transportation gridlock. Food supply would be exhausted and communication would be largely impossible, leading to economic collapse. Similarly, the uranium enrichment centrifuges in Fordo, Natanz and widely scattered elsewhere, would freeze for decades.
Iran’s response to an EMP attack would be futile and uncannily tragic. Before the elite Qods force could mine the Strait of Hormuz and wreak havoc to Arab Gulf states oil refineries, the Fifth Fleet and U.S. military installations, Iran’s administrative-industrial-military complex infrastructures would have been laid to waste without the ruling clerical regime knowing about it.
Dve šivanki...
Spraviš eno vrečo srednje ali višje radioaktivnih odpadkov. Recimo napadeš skladišče slovenskih radioaktivnih odpadkov... Uspešne preneseš v eno večje mesto. Sestaviš dve ali tri bombe in jih detoniraš... Čiščenje enega Londona bo cca puno.
bluefish ::
Others have speculated that Israel will also produce an EMP that will send Iran back to the Stone Age. “If Israel chooses one of its Jericho III missiles to detonate a single EMP warhead at high altitude over north central Iran, there will be with no blast or radiation effects on the ground,” writes Joe Tuzara for Arutz Sheva, the ultra-religious Zionist media network.Besedico speculated si seveda prezrl.
Also, EMP je zaenkrat le mana orožarske industrije in je še na razvojni stopnji. Daleč od tega, da bi lahko odvrgli bombo ali izstrelili raketo, ki bi onesposobila celotno mesto, kaj šele državo.
Double_J ::
To je daleč od teoretičnega. Ubistvu bodo morali zelo paziti, da ne detonirajo previsoko, ker bi bile prizadete še vse okoliške države...
The pulse can easily span continent-sized areas, and this radiation can affect systems on land, sea, and air. ... A large device detonated at 400–500 km (250 to 312 miles) over Kansas would affect all of the continental U.S. The signal from such an event extends to the visual horizon as seen from the burst point.
Nuclear electromagnetic pulse @ Wikipedia
Dve šivanki...
bluefish ::
Dal, če že, citiraj vsaj še predhodni odstavek in bodi pozoren na odebeljeni besedi:
A high-altitude nuclear detonation produces an immediate flux of gamma rays from the nuclear reactions within the device. These photons in turn produce high energy free electrons by Compton scattering at altitudes between (roughly) 20 and 40 km. These electrons are then trapped in the Earth's magnetic field, giving rise to an oscillating electric current. This current is asymmetric in general and gives rise to a rapidly rising radiated electromagnetic field called an electromagnetic pulse (EMP). Because the electrons are trapped essentially simultaneously, a very large electromagnetic source radiates coherently.
Skratka, EM valovanje ob jedrski eksploziji ni nič novega. Sanjati, da bi Izrael kar tako za lulz poslal tako raketo nad drugo državo, pa je norija.
- spremenil: bluefish ()
Double_J ::
Seveda... edino jedrska eksplozija kakšnih 100km nad površjem, bo onesposobila Iran, da bi lahko karkoli počel s tistim ukradenim uranom.
Dve šivanki...
detonacija v ionospher-i, povzroči da večina radarskih sistemov postane neuporabnih , vključujoč marsikatera komunikacija z različnimi vojaškimi sistemi oziroma opremo... Problem je le, da rabiš kar veliko napravo, da povzroči dolgotrajno motnjo za kak teden......
Samo kot se temu reče, neuporabno ker rabiš relativno veliko napravo 10 MT da imajo kakršne koli relane efekte... Še vedno je ceneje ti. dirty bomb, ali pa onesposobiti hladilni sistem odsluženega goriva. Če uspeš sabotirati sistem, bi bil dogodek v Ukrajini, khm no rečmo nekako tako da bi bila severna polobla na nivoju radioaktivnosti kot jo danes pozanmo okoli černobila...
Double_J ::
O čemer jaz govorim je opcija šele ko Iran ukrade visoko obogateni uran in ga skrije na neznani lokaciji v državi, kjer potem gradi atomsko bombo. V tem primeru ti ostane edina opcija, da onesposobiš celotno državo.
Mislim da v tem primeru ne gre samo za motnje na omrežjih... ampak so vitalna omrežja uničena in bi celoten sistem kolapsiral.
Dve šivanki...
Sakin ::
V pol leta pade radioaktivnost na polovico, v 1 letu na 1/4 in tako dalje limita proti 0.
Res je. Ampak, tu pride še faktor razpadanja trupla in prisotnost dežja...nisem ekspert za te zadeve. Ne vem kdaj točno so se pojavile špekulacije o poloniju, sigurno pa dosti časa po smrti.
bluefish ::
O čemer jaz govorim je opcija šele ko Iran ukrade visoko obogateni uran in ga skrije na neznani lokaciji v državi, kjer potem gradi atomsko bombo. V tem primeru ti ostane edina opcija, da onesposobiš celotno državo.Naslednji ukrep pa je, da tako ZDA kot Rusija zreducirata Izrael v kupček stekla.
Double_J ::
Aja... nisem še videl da bi kdo napadel državo, ki ima jedrsko oborožitev. To se še ni zgodilo nikoli v zgodovini.
Dve šivanki...
Hm senzorji zaznajo radiokativnost kazalcev v starih budilkah, kaj misliš kako boš prinesel recimo 100g inicatorja, brez da bi zvonili vsi alarmi v pristaniščih, letališčih itd...
bluefish ::
Double_J ::
Vse je enkrat prvič.
Saj Izrael res lete v rit ZDA (ali pa obratno, kakorkoli), ampak tako pri srcu jim pa tudi ni.
ZDA ga ne bi napadle... to ti bo NissanGTR potrdil. Kar se tiče Rusije... Moskva je na dosegu izraelskih jedrskih raket. Pozabi...
Dve šivanki...
T-h-o-r ::
Je tako ali ni?
ja, iranci bojo pa to mirno gledali, lol
poweroff ::
Jao, Duble. Preberi si kakšen znanstven članek o EMP, ne znanstvenofantastični. EMP naj bi onesposobil celotno državo? Pa saj to ni Lichtenstein...
sudo poweroff
papasmrk ::
DoubleJ bi moral za kakšno leto v Bagdad, pa da bi se 100 metrov stran od njega razstrelil kak fanatik. Iz dobro delujoče države narediti reveže, kjer človeško življenje nima nobene cene. Bi to rad videl tudi v Iranu ali pa celo v Ljubljani, Mariboru...aja to je pa preblizu. Si kdaj poslušal zgodbo nekoga, ki je izgubil nekoga bližnjega v vojni. Izvoz demokracije v Iran bi pomenil nekaj desetletij bede in nasilja.
Double_J ::
Matthai, ti res nimaš pojma...
https://www.centerforsecuritypolicy.org...
Amb. Cooper warned that, given our nation’s current state of unpreparedness, if a natural or nuclear EMP catastrophe struck today, blacking out the electrical grid and other critical infrastructures for a year, as many as ninety percent of the American people could perish from starvation, disease and societal collapse. This assessment is from the Congressional EMP Commission that examined the EMP threat for nearly a decade, including performing numerous scientific experiments and producing what is widely regarded as the definitive study of critical infrastructure vulnerabilities and solutions.
Dve šivanki...
In še enkrat, brez bolnih fantazij.
Glede na DoubleJ-jevo pisanje v tej temi, me zanima, kateri njegovi posti ne spadajo v to kategorijo? Saj se trudim iskati, vendar...
In še malce resnejši pogled na pogajanja s strani vsaj malenkost priznanega časopisa (če je že tema namenjena obilnemu flamanju z biased povezavami):
http://www.theguardian.com/world/2013/n...
- spremenilo: Fritz ()
Double_J ::
Fritz... tega tudi ZDA ne izključujejo, Iran in Severna Koreja sta edini državi na seznamu, kjer se ne izključuje preventivnega nuklearnega napada.
When specifically questioned about the potential use of nuclear weapons against Iran, President Bush claimed that "All options were on the table". According to the Bulletin of the Atomic Scientist, Bush "directly threatened Iran with a preemptive nuclear strike. It is hard to read his reply in any other way."
Dve šivanki...
Once again, a je tebi za boga jasno kaj pomenijo besede preventivni jedrski napad/udar. Kaj, ko bi jaz tebi preventivno odstrelil družino, saj imate doma kuhinjske nože in me lahko napadete... Mislim, če to ni rezoniranje enega psihičnega bolnika, potem ne vem kaj je
Neizzvan napad na drugo državo je eno največjih hudodelstev:
The International Military Tribunal at Nuremberg, which followed World War II, called the waging of aggressive war "essentially an evil thing...to initiate a war of aggression...is not only an international crime; it is the supreme international crime, differing only from other war crimes in that it contains within itself the accumulated evil of the whole."
Double_J ::
Lej ne bi se spuščal v te polemike, vendar sedaj se dogajajo zanimive stvari, saj so zamenjali tako vodjo kot njegovega podrejenega, pri jedrskih silah.
Najprej tole:
http://cir.ca/news/nuclear-deputy-comma...
Potem pa je Obama namestil za vodjo črnca, ki mu bo posebej lojalen. V čem je štos tega?
Cecil D. Haney @ Wikipedia
Najprej tole:
Dve šivanki...
Double_J ::
Situacija je pa sedaj takšna...
ZDA so izgubile veliko zaveznikov v zadnje pol leta. Da naštejem samo glavne... Egipt, Saudska Arabija, Izrael. Egipt in Saudska Arabija... to je v praksi celotni arabski svet. Bushu kaj takega ne bi uspelo, kakorkoli smo že kritični do njega.
Mogoče se bodo pa zmenili z Iranom in Sirijo... da postanejo njihovi zavezniki. To je nekako še zadnje upanje za ZDA. Samo problem je... da če se te dva enkrat pobereta iz trenutnih težav, bosta spet delala vse po starem.
Dve šivanki...
Double_J ::
Dokaz:
Egypt rethinking who its 'real friends' are, Interim President Adly Mansour says
http://edition.cnn.com/2013/09/04/world...
Saudi Arabia set for diplomatic shift away from US
http://www.theguardian.com/world/2013/o...
Drifting from US, Liberman calls to diversify foreign policy
http://www.timesofisrael.com/drifting-f...
Dve šivanki...
poweroff ::
Seveda. Spregledal si pa, da tip v bistvu dela propagando, ker hoče dodatne finance za "obrambo" (razni črni fondi obveščevalnih služb namenjeni popivanju na eksotičnih lokacijah).
EMP efekt je sicer znan že od prvih jedrskih eksplozij, da bi pa imel kakšen resnejši učinek na veliko državo je pa zaenkrat čisti science fiction. Pa seveda del propagande tajnih služb, ki si želijo dodatnih financ. Etilni etanol namreč stane...
sudo poweroff
Double_J ::
Science fiction je to kar praviš ti... če nimaš prav posebej narejenih omrežij proti tej nevarnosti.
Kar se pa tiče ZDA, kako ji je uspelo izgubiti te zaveznike?
1. Egipt... Obama organizira zmago muslimanske bratovščine, namesto sekularne opozicije. Jasno, da bo vojska prej ali slej s podporo ljudi vrgla nedemokratično muslimansko bratovščino iz oblasti in se potem oddaljila od ZDA.
2. Saudska Arabija... čisto preprosto. Napoveš napad na Sirijo, potem pa se naslednji dan premisliš.
3. Izrael... poizkus sklenitve slabe kupčije z Iranom.
Kaj nas čaka v prihodnosti?
Dve šivanki...
