Forum » Igre » Kaj trenutno igrate?
FishFreak ::
Plants vs Zombies (ne morem se naveličat)
Dead Space (je treba še enkrat do 2x obrnit pred izidom dvojke)
DeathSpank (malo smeha:) )
mr1two ::
- Call of Duty 5: World at War (PS3)
- Sky Track (PC)
- Warzone 2100 2.3.7 (PC)
- Sky Track (PC)
bajsibajsi ::
Ponovno Call of duty ver. 1.1 na wy6.uk.com havoc serverju. :)
Jutri pa CB Rift do petka. Upam da bo Rift nadomestila Warhammer online, vsaj dokler ne pride GW2.
Jake-K ::
Assassins Creed: Brotherhood
Need for speed 2 - sicer je ful stara ampak mi je še zmer dobra
ManDriver ::
Splinter Cell: Conviction (Xbox 360)
If all the world is a stage, where is the audience sitting?
Enron x86 ::
Končal Outlawse, sedaj pa TES3: Morrowind z modi po tem vodiču in s savegami izpred 4 let.
Core i5-4690K@4.7| ASUS MAXIMUS VII HERO| 16 GB Corsair LP DDR3 1866 MHz|
ASUS 970 STRIX| SB Z OEM| Samsung 840 EVO 250 GB|
Seagate 2 TB| EVGA SuperNOVA G2 750 W| Fractal Define R4
Sandi1987 ::
- Test Drive Unlimited (PC) - Z volanom.
- Test Drive Unlimited 2 (PC) - Z volanom. Čakam na oceno v Joker-ju.
- Dead Space 2 (PC)
- Dead Space 2 (PC)
- spremenil: Sandi1987 ()
El Barto ::
World of tanks
TDU 2
TDU 2
"You cannot be a true petrolhead until you've owned an Alfa - until you've
experienced that rollercoaster of pain, disappointment, and agony for that
brief moment when everything works and you're on a nice road". Jeremy Clarkson
69charger ::
TDU1
System Shock 2
System Shock 2
rezator ::
Imam eno vprašanje. Mogoče ne najbolj sodi sem, ampak nevem kaj naj napišem drugam. A je Battlefield: Bad Company 2 Vietnam že na trgu? Ker gledam ocene in ima hude, ampak ko pa gledam, da bi jo kupil pa nikjer ne najdem...
Some people feel the rain. Others just get wet.
IvoJan ::
Rabis originalni bc2. Vietnam je samo dodatek. Dobis ga v eajevi spletni trgovini.
ahac ::
overlord_tm je izjavil:
Open transport tycoon deluxe. Kak kandidat za multiplayer?
Samo, če se igra 2cc al pa japan set.
OmegaM ::
Ce koga zanima, original kljuc za BF:BC2 stane cca. 15EUR.
Tudi sam sem ga tu nabavil.
http://www.directgamekeys.com/
LP, M
LP, M
Ni nam lahko, bo pa boljše!!!
Bor H ::
Tema je kaj trenutno igras ne kaj trenutno ne igras vec :D
Sicer pa se vedno najvec Bad Company 2, v cakanju na navdih sta pa Crysis Warhead pa Company of Heroes.
Trenutno igram Darksiders.
Igre je res odlična.
Sicer sem jaz še dokaj na začetku, včeraj zvečer sem končno po ducatih ponavljanj uspel ubiti kraljico netopirjev, srce pa sem odnesel demonu Samaelu. Če bo vse šlo po sreči, bom igro nadaljeval spet danes zvečer.
IvoJan ::
kako pa to igras?
Master Chief ::
kako pa to igras?
Stvar je taka, imam original MW2 verzijo, ki je seveda sparjena s Steamom. Dedidacted serverji so omogočeni samo preko omrežja alterIWnet, ki deluje tudi z STEAM oz originalno legalno različico.
Fajle, ki jih potrebuješ, dobiš na njihovi strani. Če ti vseeno nebo všeč igranje na aIWnet-u, lahko spet v nekaj trenutkih "ponastaviš" na originalno različico tako, da v Steamu na dotični igri označiš Verify integrity of Game Files, in spet o+bo "vanilla". Vse kar je, spremeni je to, da spremeni fajl Cashe.xml.
Dejansko je MW2 za moje pojme igralen samo na Alter IW netu, "Defaulta" se ne pritaknem več. Še enkrat IGRO IMAM ORIGINAL, in ne piratiziram.
RejZoR ::
Need for Speed Hot Pursuit online. Sem našel par odfukanih rusov (itaq jih je polno) in smo danes celo dopoldne delal štalo po cestah. Je bilo kar fajn za razliko od random špilov z random folkom. Race je sicer najbolj umirjen način kjer praktično ni neumnosti, Hot Pursuit pa je dost več khm preklinjanja ampak kadar deluje ok je prav zabavno.
subby ::
@RejZoR: jaz si nfshp nisem kupil samo zato, ker ga nimam s kom igrat... poročaj, če je multiplayer dost hud za 50EUR
IvoJan ::
Master Chief je izjavil:
kako pa to igras?
jst mam tudi original in sem spil celo igral kako leto do izida black opsa :)
| ! | Iščem igro (RPG, MMORPG, FPS, RTS, ...) (strani: 1 2 3 4 … 26 27 28 29 )Oddelek: Igre | 535775 (23750) | JanBrezov |
| » | Metro Exodus [Metro 2035] (strani: 1 2 3 4 … 12 13 14 15 )Oddelek: Igre | 177752 (61830) | oo7 |
| » | Katera je vaša najljubša igra vseh časov? (strani: 1 2 3 4 5 )Oddelek: Igre | 49470 (27489) | msms |
| » | Vaših 5 igr vseh časov (strani: 1 2 3 4 5 )Oddelek: Igre | 47891 (33607) | Sc0ut |
| » | PC igre 2014 (strani: 1 2 )Oddelek: Igre | 27078 (20049) | yayo |
