Forum » Znanost in tehnologija » Kriptografski problem
sverde21 ::
Torej na nekem angleškem forumu sem našel tole:
Zna kdo razvozlati vrstice od 27 do 30?? Jst gledam tole tabelo že nekaj časa pa se mi nič ne posveti
Hi all!
I ask to help with a following problem.
There is a sequence from 26 lines of "daggers-zeroes":
1. |0000X|X0XXX|0XX00|XXX00| 0241545220
2. |X0000|0X00X|XX0X0|0XXXX| 0231584075
3. |00XXX|X0X00|0000X|XX0XX| 0221924380
4. |X0000|00XXX|0X00X|XXXX0| 0232667204
5. |0XX00|XXX00|00XXX|00X0X| 0280953866
6. |0X0XX|00X00|X0X0X|00XXX| 0271221965
7. |00X00|XX0XX|0X0XX|00XX0| 0210050913
8. |X00X0|X0X0X|X000X|X0X0X| 0272521742
9. |XX00X|X0X0X|0X000|00XXX| 0272113942
10. |X000X|XX0X0|0X00X|XX00X| 0280415579
11. |X0XXX|00XX0|0X000|XX00X| 0212848616
12. |0X00X|X000X|XX0X0|X0XX0| 0291606615
13. |XXXXX|X00X0|0XX00|00X00| 0231420521
14. |X0XXX|0XX00|0X00X|XX000| 0272315227
15. |X00X0|XX0X0|XX0X0|00XX0| 0262519848
16. |0XXX0|0XX00|0X0XX|000XX| 0232773043
17. |0XXX0|0XX00|X0XXX|000X0| 0231394585
18. |0X0XX|00X0X|00X0X|XXX00| 0270522700
19. |0X0XX|XXX0X|000XX|0X000| 0250875404
20. |0XX0X|X0XXX|0X000|000XX| 0212405226
21. |XXXX0|X000X|0XXX0|X0000| 0250817941
22. |000XX|X00X0|0XXX0|0XXX0| 0210549116
23. |0X0X0|0XX0X|000XX|X0X0X| 0272561780
24. |0X00X|X00X0|XX0X0|XX0X0| 0241656421
25. |X0000|00X0X|0XX0X|X0XXX| 0211828525
26. |0X00X|XX00X|X0000|X0XXX| 0260511752
A line consists of 20 positions. To each line there is accordance of pin-code: number on the right, beginning with 02. Each line is decomposite to "5 simbols": and, there is no "5 simbols" in which there would be all the zero, even one "dagger" in "5 simbols" is present. Problem: to write down 27, 28, 29, 30 lines of sequence.
P.S. i'm sorry for my english.
<?php echo `w`; ?>
Evil mind ::
Slabo prebrau. Niti malo se mi ne sanja o tej šifri. Mogoče če bi jo natisnu in pole na listu proveravu.
| » | Pobegla baza z osebnimi in finančnimi podatki več kot polovice ameriških gospodinjsteOddelek: Novice / Zasebnost | 11961 (9603) | MrStein |
| » | Kako narediti request z "\" v URL-juOddelek: Programiranje | 2756 (2031) | Horejšio |
| » | X server in Nvidia na FC#Oddelek: Operacijski sistemi | 2466 (2293) | HellRaiseR |
| » | xserver-xree86Oddelek: Operacijski sistemi | 1884 (1796) | Skrat |
| » | Težave s pekačemOddelek: Pomoč in nasveti | 2376 (2316) | boštjan |
