Forum » Programiranje » VB problem
VB problem
turce28 ::
Mene zanima ce mogoce obstaja kaksna funkcija za pretvarjanje stevil iz Long v Single, ampak ne po vrednostih temvec po bitih. NPR: iz long &H 40C1 999A v Single 6.05??
Tnx
Tnx
StratOS ::
Uporabi pointerje !
Dim d As Single
Dim lPointer As Long
Dim iLen As Integer
Dim B() As Byte
d = &H40C1999A
lPointer = VarPtr(d)
iLen = LenB(d)
ReDim B(iLen - 1)
CopyMemory B(0), ByVal lPointer, iLen
For iLen = 0 To iLen - 1
MsgBox B(iLen)
Next iLen
Dim d As Single
Dim iLen As Integer
Dim B() As Byte
d = &H40C1999A
iLen = LenB(d)
ReDim B(iLen - 1)
MsgBox B(iLen)
Next iLen
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
| » | Kraj rojstva in pošta Slovenije (strani: 1 2 )Oddelek: Loža | 11119 (9042) | Cange |
| » | Napis "1. Dostop" na položnicahOddelek: Loža | 7065 (3998) | mHook |
| » | Drugačni načini reševanja krizeOddelek: Problemi človeštva | 5450 (4852) | Kamran |
| » | Pomoc v C-juOddelek: Programiranje | 1694 (1606) | rfmw |
| » | Odpiranje dat.exe v VBOddelek: Programiranje | 3836 (3629) | webblod |
